Question about Epson Stylus Photo R220 InkJet Printer
Printer cd problem Epson R220
Please could somebody help me with my cd tray the problem is when i line the arrows together the tray is taken in slightly then pushed back out and I am told to realine but there is nothing else i can do the arrows are together has anybody else had this problem and please could you help me. Thanks Alan. Oh and by the way I know it sounds silly but the printer is not up against the wall stopping the tray going right in.
  • Jafthockey Jan 08, 2009
    I have a epson Stylus R220 and until recently has worked fine. Now it will feed the tray in but then it pushes it all the way out. Any ideas, do I need a need a Tray?
  • Anonymous May 09, 2009
    I have the same problem. Bought a new style tray but it still won't even take the tray in a bit. Just kicks it out and the center red light comes on solid and the green flashes. The software says to remove tray/realign then push red lit button on printer. Pushing this button does nothing at all. I have to cancel print, close tray door and reset printer. Nothing I've tried works...HELP!
  • Epson Master
  • 705 Answers
Hey Nala1, Try a print job again, but this time try helping the tray into the printer with a little push. Be gentle and do not try to force it in. If the tray is taken in and works fine, you should try cleaning the rubber roller at the front of the machine that pull the tray in. If the tray feeds part way and the print head runs back and forth a couple of times before the tray is ejected again, try cleaning the white marks on the tray. Use something like windowlene (windex) and a piece of kitchen paper. Also, if you have the old style tray with the thin clear plastic strip on the leading edge, make sure it is straight and in good health.
Posted on Mar 11, 2007
SOURCE:
Printing to adhesive CD labels
you need software like Nero to print on cds
Nov 05, 2013 | Epson Stylus Photo R220 InkJet Printer
I'm having trouble printing on cds (they won't load) with my epson stylus photo r220. I've followed the directions, lined the tray up properly. Set the settings for cd/dvd. Tried old and new software.
Depends how long you have had your printer, epson are well know for the rollers that takes the paper in getting worn, and so does the cd/dvd tray, eventually you have to push the tray in by hand to get the thing started, somtimes changing the disk tray helps, if youve got a spare one,
Dec 21, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson r220 dvd tray
This happened to me when there wasn't enough space behind the printer for the tray to stick out as far as it needs to.  I just moved the printer and it worked.
Dec 29, 2008 | Epson Stylus Photo R220 InkJet Printer
R220 printing on cd tray instead of disk
double check how you are inserting the tray into the printer. It should be with the cd in the holder, facing upwards and cd in first.
Gremlin11
Dec 10, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220 print to cd
try to download the reset of the printer
Dec 09, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
R220 printer will not take cd/dvd tray
I know this sounds daft but make sure that it's not hitting the wall on the back of the printer
Oct 15, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus photo r220
Hi - have you tried giving the tray a little push; I had to do it with my R200; one minute it was fine the next I received the same message as you - Might work - brand
Sep 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220 cd
You can actually buy an original software/driver cd disk for your printer if you call Epson's technical support line 562-276-4367.
As I called them it was just around 10 bucks and I have all the software bundled with my R260.
Jun 06, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
474 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
