My problem is about router configuration. I have 4 computers that i want to connect using a router. When i directly connect the modem to my single computer, i can access to internet but when it connects to router all computers have no connections to internet. What steps should i do in router configuration so I can easily browse webpages fast and easy. Please assist me... Hoping for your immediate reply. Thank you!
  • Lailei  Pasiona
    Lailei Pasiona May 11, 2010
    Hi!
    Router configuration depends on who is your ISP (Internet service provider - cable or DSL). It also depends on what brand/model number of your router. Also, the brand.model of your modem.
    Please indicate the name of your ISP, brand of your router. I can give you the step by step instruction in setting up your router.
    I hope to hear from your soon.
  • Alexander Banaag II
    Alexander Banaag II May 11, 2010
    There are two major types of configuration depending on your ISP and your modem.
    1. DHCP - This is the easiest. Since the router will just automatically detect your modem's configuration.
    2. PPPoE - This setup is usually used by AT&T. With this setup, you still need to put your modem into bridge mode before you can access your router.
    Please state the brand/model of your modem and router as well as the name of your internet service provider.
    Thanks, ArnWuLF
    Problem Solver:
  • 13 Answers
Can you get into the router setup page? Connect the modem to the WAN port of the router. Then connect one pc (to start do not connect to a switch port beside the WAN port). Get into the setup page (usually http://192.168.1.1), and ensure that your modem is connected (to internet), that you have internet access enabled, and that DHCP is turned on. If all of this is ok, try turning the power off to modem and router; then power on modem, and when it has reset, turn on the router.
Posted on Nov 26, 2008
My computer is not connecting to my Dynex wireless router. I've called my locate cable subscriber and they told me that it's a router problem. I've disconnected the router several times and it shows that...
First off, verify that you can connect to your cable modem directly. After that, hook up your Dynex wireless router and reboot your cable modem. After this, directly connect your computer to the Dynex router (using a cable). If you cannot get an Internet connection, then there is some issue with your Dynex router configuration. It's possible that there might be an IP address conflict with the cable modem. It would be best to contact support for configuring the Dynex.
If you can connect to the Internet with your computer connected directly to the Dynex router, then there must be some router configuration problem affecting your ability to connect wirelessly. You'll have to check the configuration--might be a good idea to completely reset the router and start over. If that doesn't help, you should contact Dynex customer support, as each router has its own configuration specifics. Good luck.
Nov 07, 2010 | Computers & Internet
Tip
Configuring Belkin routers without installation CD for Cable ISP: ·
Configuring Belkin routers without installation CD for Cable ISP :
  • Connect the cable Modem/ Ethernet cable from ISP to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:Check for the internet status at the top right hand corner. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
If it is not connected then we need to configure by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next.
Step 3: HOST NAME leave it blank or you can type anything there and click on APPLY CHANGES.
Step 4: Click on MAC ADDRESS or MAC CLONE (found right below the connection type on left side of RSP).
Step 5: click on the button CLONE (once you click on clone the MAC address will get changed) and click on APPLY CHANGES.
Step 6: Before doing MAC clone one important thing has to be noticed. Check whether you are able to go online when you connect the computer directly to the cable modem. Because Cable ISPs uses a particular kind of authentication called MAC authentication. Hence, only the particular computers whose MAC addresses are registered in their database will be able to go online directly from the modem.
***MAC clone is a feature that copies the MAC address of your computer and pastes it in the router. So the router will have the MAC address of your computer and it will get connected to the internet.
Step 7: Now check for the internet status at the top right hand corner. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
  • Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
  • If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected.In this case you need to repeat the above Network power cycle by unplugging the cable that is going into the cable modem from the wall outlet.
  • Still if the internet status is not connected, then connect your computer directly to the modem and check whether you are able to go online.
  • If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
your wired part is configured completely now.To configure the wireless part click here
on May 05, 2010 | Computers & Internet
My belkin router says the internet is not connected when I connect the modem to it, but when I connect my modem directly to my computer it works. What is wrong?
the problem is that your router is not configured for your internet service...
click here to configure the router on your own...
select the appropriate tips and configure your router perfectly...
Any issues, comment me back...
Aug 02, 2010 | Belkin (F5D7230-4) Router (587009)
I have a wireless-n 150 router. I have tried to use it with a Toshiba Windows Vista computer and I cannot get the wireless to work. I have unplugged it and plugged it back in and that doesn't do it. The...
The wireless router needs to configured with the wireless settings, SSID, encryption etc. Then the wireless card in the Toshiba needs to be configured with the wireless router's SSID, encryption etc.
To secure your wireless router from unauthorized access and to configure the wireless card in your computer so it can connect to your wireless router, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Jun 11, 2010 | Office Equipment & Supplies
How do I connect it to a motorola 2210 modem
This FAQ is for configuring a BellSouth supplied Motorola/Netopia 2210-02-1006 with a generic third-party router that isn't specifically covered in the existing FAQs. If you have a router that is covered in the FAQs, I suggest you use that FAQ. This initial setup is all that is needed to configure and connect your generic router based network for FastAccess DSL. Any additional setup for features like DHCP IP ranges, port triggering, etc is out of the scope of this FAQ.
This FAQ has 4 Major sections:
Section 1 - Overview
Section 2 - Motorola/Netopia 2210 modem configuration
Section 3 - Third party router configuration information
Section 4 - Connections and power up
•The best configuration for networking a router with the Motorola 2210 is to set the 2210 to "Bridged Ethernet" mode and allow the third-party router to do the routing and DHCP functions. The 2210 is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
Before proceeding both the 2210 modem and third-party router must be reset to default. Despite what the help desk tech tells you, resetting the modem does not put it into Bridged Mode.
• The BellSouth Installation CD and Connection Manager are not required to use this configuration.
• The third-party Installation Wizard CD should not be used in this configuration.
• Since BellSouth assigns static IPs via your username the configurations shown are applicable to both dynamic and single static IP customers.
• You must connect the 2210 directly to the computer's NIC to make the necessary changes before you connect the router, because you will probably be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where the 2210 is connected). Additionally, they may be on completely different subnets. After you have made the changes to the 2210 you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the 2210's PPPoE and DHCP functions. Click here for more information.
•If you encounter any problems simply reset the 2210, connect it directly to your NIC, restart your computer, log into the interface, and start over again.
Section 2 ? Motorola 2210 Configuration
bred.gifStep 1
Verify that NIC cards (wireless or wired) are set to "Obtain IP Address Automatically". Completely power down the 2210 and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the 2210 to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter "192.168.1.254" in the address field to access the 2210 GUI interface.
bred.gifStep 3
Enter your BellSouth Username followed by "@bellsouth.net" in the User ID field. Enter your BellSouth Password in the Password field. Re-enter your BellSouth Password in the Confirm Password field. Click on Next. Update the Auto Calender Update Configuration as desired and click Next. The modem will try to initiate a session and then return to the main menu.
bred.gifStep 4
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the 2210.
Section 3 - Third-Party Router Information
bred.gifStep 5
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the third-party router and then the computer.
bred.gifStep 6
Open a browser session to access the router interface as per the router's user guide. Even though the interface will vary from router to router you must use the following configurations as a basic rule:
- Select Obtain an IP address automatically. Important Note: Use Obtain an IP address automatically even if you ordered a static IP.
- Select PPPoE connectivity. Do not select any other choice, even if you have a static IP.
- Enter your BellSouth Username followed by "@bellsouth.net"
- Enter your BellSouth Password
- Select "Keep Alive" or "Always On" (if available)
- Set "Maximum Idle Time" to "0" which is similar to "keep alive" and "always on" (if available)
- Select a redial or reconnect period of "180 Seconds" (if available)
- Enter "1492" in the MTU Field (if available)
- Save your settings (which will probably restart your router)
Section 4 - Connections and Power Up
bred.gifStep 7
Power everything down and physically connect the 2210, wired or wireless router, and any computer(s).
Pictures by Andy Houtz
bred.gifStep 8
Power up the network equipment in this order:
1) Motorola 2210 Modem (wait for DSL synch)
2) Third-party Router
3) Computer(s)
Open a browser session and go surfing!
bred.gifImportant Additional Information
•The 2210 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Motorola. Since you are using the Netgear to establish the PPPoE session the light will stay off. This is normal.
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network.
bred.gifCool Stuff
An online, html-based menu simulator program is available here. The simulator recreates the Motorola 2210 user interface and provides the ability to navigate menus; just like the real modem interface. It is for simulation purposes only and will not make any changes to your actual modem.
Jun 09, 2010 | NetGear WGR614 Wireless Router
I have Comcast cable modem. The router was
HI,
follow the below steps to configure your router:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port). 2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable). 3. Power off the modem and the router after making the connections. 4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox). 2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com. 3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive). 4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section. 5. Click Apply. 6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
Hope this allows you to resolve the issue. If you need further assistance then let me know.
Regards
Anand
May 15, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
No ip address
Many people need to connect additional computers or game consoles. To do this, most use a home network router, which shares a single IP address across multiple computers. No special configuration of your Shaw service or modem is required.
For information on how to configure a home network, consult the manufacturer's documentation included with the hub or router you have purchased.
  • Access the router configuration page.
  • Set the router to use Cable as Internet connection type.
Apr 07, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have a dlink router and I want to connect my usb modem to it
is this an additional router?
Verizon are issuing modem with built in wired and wireless modem.
Try this;
How do I properly set up a D-Link Router with a Westell Modem? (#7125)
This FAQ is for setting up a BellSouth supplied Westell 2100/2200/6100 modem (Models A90-210030-04, B90-220030-04 and B90-610030-06/C90-610030-06, respectively) with a D-Link DSL router. Although actual screen shots vary throughout the DLink line, the instructions below are applicable to all models. Important Note: These procedures and pictures are based on the most recent firmware for the Westell. Other Westell firmware menus and screenshots are slightly different but the bridge options and functions are still available. It is highly recommended that you click here and update your Westell firmware.
This FAQ has 3 Major sections:
Section 2 - Westell modem configuration
Section 3 - D-Link router configuration information
bred.gifImportant Note: Due to some known operational issues it is VERY important that you have the latest firmware on your D-Link router. Please go to the D-Link Support Site for firmware updates.
bred.gif The best configuration for networking a router with the Westell is to set the Westell to "Bridged Ethernet" mode and allow the router to do the routing and DHCP functions. The Westell is also a router with full DHCP functions and may not function correctly when connected directly to another router. Not changing the modem to Bridged Ethernet will result in double NAT'ing, increased latency, possible IP conflicts, or possibly a network that doesn't work at all.
bred.gif Before proceeding both the modem and router should be set to default. Despite what the help desk tech tells you, resetting the Westell does not put it into Bridged Mode.
bred.gif The BellSouth Installation CD and Connection Manager are not required to use this configuration.
bred.gif Since BellSouth assigns static WAN IPs via your username the configurations shown are applicable to both dynamic and single static IP customers. Select dynamic PPPoE regardless of your setup.
bred.gif You must connect the Westell directly to the computer's NIC to make the necessary changes before you connect the router, because you will be unable to access the modem interface after you connect the router. The reason is that the modem interface is 192.168.1.254 which is a local IP. By default, most routers do not have the capability to route a local IP out of their WAN port (where your Westell is connected). Additionally, they may be on completely different subnets. After you have made the changes to the Westell you can then connect the router and configure it for use with FastAccess. There are several alternatives around this problem. One method involves extra equipment (second NIC and a hub) and major configuration changes. The second method requires you to utilize the router as a simple switch and use the Westell's PPPoE and DHCP functions. Click here for more information.
bred.gif If you encounter any problems simply reset the Westell, connect it directly to your NIC, restart your computer, log into the Westell interface, and start over again.
bred.gif More information about the Westell is available here.
Section 2 - Westell Configuration
bred.gifStep 1
Verify that your NIC card is set to "Obtain IP Address Automatically". Completely power down the Westell and the computer(s). Power up the modem and press the reset button on the back of the modem. After the modem has fully initialized connect the Westell to the NIC and then power up the computer.
bred.gifStep 2
Open a browser session and enter 192.168.1.254 in the URL address field to access the Westell interface. If you are unable to access the interface make sure your NIC is set to "Obtain an IP address automatically". This may require you to reboot the computer (or release/renew) to obtain a proper IP.
bred.gifStep 3
Click on Broadband DSL Line from the top menu. Click on Configure Connection from the right menu. Select "Bridged Ethernet" from the Protocol pull down. Click on Save and restart the connection at the bottom. This will automatically restart the modem and the interface will return after the changes are saved. Note: functions like NAT, DHCP, IP Passthrough, and username and password will be disabled or irrelevant and can not be selected. After the modem has restarted, power down both the computer and the modem then physically disconnect the Westell.
Section 3 - D-Link Router Information
bred.gifStep 4
After the PC is powered down connect one of the router LAN ports to the computer NIC and power up the router and then the computer.
bred.gifStep 5
Use the following steps to configure your D-Link DI-604 Router. Important Note: You must use the username@bellsouth.net format for your username. If you do not add "@bellsouth.net" after your username you will be unable to connect to the internet.
bred.gifStep 6
Power everything down and physically connect the Westell, the router, and any computer(s).
Westell 2100 shown. Pictures by Andy Houtz
bred.gifStep 7
•Westell Modem (wait till the Ready light is a steady green)
•D-Link Router
•Computer(s)
bred.gifAdditional Imformation
•You should check your tweak settings to optimize your new network. Reminder: If you are required to change your MTU, make sure that it is identical on all equipment (PCs and routers) in the network. For more information about changing MTU on a D-Link please click here.
•The 6100 has an "Internet" light that is green whenever there is an active PPPoE session initiated by the Westell. Since you are using the DLink to establish the PPPoE session the light will stay off. This is normal.
Mar 13, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Doesnt connect
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support. :-)
Jun 08, 2008 | Linksys WRT300N Wireless Router
Configuring EDIMAX 6104 for Aztech 600E Router
Does your router automatically set the ip addresses for each computer, or do you have to set them up yourself? Is the computer that can connect the one that is directly connected to the modem? if it does and you asked windows to repair the connection it probably is messed up. check in the router settings to see if your pc's are on the same ip address route (e.g 192.168.x.x), but not all the same last digit; and the subnet masks are all the same (eg 255.255.255.0)
Oct 25, 2006 | Edimax BR-6104 Broadband Router. One...
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
