Question about Kenmore 53642 / 53644 Side by Side Refrigerator
KENMORE SIDE BY SIDE REFRIGERATOR. QUESTION REF WATER FILTER
HELLO, WATER AND ICE FILTER SYSTEM. HOW OFTEN DO I NEED TO CHANGE THE FILTER? DOES SEARS HAVE THEM ON HAND? DOES WALMART?
THANK YOU
  • desforge Dec 26, 2008
    Whirpool Refrig. muat turn off the water to change the filter
    Sergeant:
    Champion:
  • 291 Answers
Need to replace the filter every six months and yes you can get them at Sears but not Walmart
Posted on Nov 26, 2008
Low water pressure & ice maker problem
Hi! you don't say how old the refrigerator is, but if it has a water filter, the problem may be that the water filter needs replacement. If there is a water filter, it may be inside the refrigerator side, usually up top towards the back.
If you see a filter, you can buy a replacement at Sears. While your there, check out their water filter subscription. They'll send a water filter to your house on schedule, so you can replace it when needed.
Oct 28, 2013 | Kenmore Refrigerators
Water dispence slow
do you know if it is a whirlpool made model, 27ft french door, ice maker in ceiling, they had issues with a seal between ice compartment and ref side- leaks freezing air to water tank area, freezing tank. other wise if its not the filter -then water flow to unit. ck where it connects to ref, if good( should have steady stream with press. replace ref valve if bad look at your valve in wall or at sink.
Sep 14, 2012 | Kenmore Refrigerators
Hi I have kenmore side by side fridge and I want to change wtaer filter but I cannot locate it. Model series noo is 55771. can u please help thanks
It depends who made that refrig for sears,the 3 leading manufactures for sears are Whirlpool and all their filters are in the grill below the the freezer door.,General Electric their filters are in the fresh food (frige) compartment on the ceiling in the upper right corner OR Frigidiare and theirs is right inside of the ref door in the upper right corner by the controls
I hope this helps,
Gene
Aug 04, 2011 | Kenmore 57029 Side by Side Refrigerator
I have a side-by-side ref. It use external filter. I notice that water out of filter (before going into ref) is clear but when I collect water from water dispenser of my ref is cloudy and some very tiny...
was the outside filter factory? by this I mean does the unit have an internal filter ? if no, then you need to flush the system, clean the outside dispenser components, lime or rust has accumulated on the dispenser if the water from the outgoing side of the filter is clear ( is the ice clear and fed by this same water source? if so,, its just outside build up that needs to be cleaned
Jul 03, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Small ice cubes
The water is not reaching the ice maker in a sufficient quantity. If you have a water filter, change it. Thank you.
Sep 17, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Moldy Ice from Ice Maker
Hi: Does it have a water filter? Sears parts is offline at the moment, so I can't tell. Most of the newer models do. The 596.xxx tells me that it was built in the Amana factory for Kenmore. Most likely there is a water filter in the top of the fresh food compartment. It has been growing mold in storage, and the lines too. It's on the upper right side, behind a housing with a tab to release it. Lower the housing and remove the water filter. Did you receive the bypass plug with the ref.? It looks like a large plastic wing nut with the same fitting as the water filter. If so put it in and flush the system with city water. Most city water has chlorine to clean your lines. If you install a new filter without flushing the lines it will remove the chlorine as it's supposed to do, but the lines from the filter wont get clean. If you don't have the plug, buy one. Flush the system and then install the filter. I hope this helps, Jeff
Jun 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Water Dispensor leak on Whirlpool Refridgerator
The solenoid valve needs replacing, located at the back of the refrigerator. If you have well water you will need to install a filter on the supply line.
Jan 04, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Did you try to disconnect the water filter and try if its working? Check the line if its twisted or something disrupt the water to go in and make sure you open the tap water valve to supply your Ref.
Aug 06, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
200 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
