Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
I Need to Print
I only have black ink installed. Can't I just print in black and white. I can't afford all the colors.
  • 67 Answers
Sadly in a word, 'No'.
Here is the exact answer from Brother:
Your Brother machine is designed to stop ALL printing operations
(printing from the pc, printing received faxes and printing copies or reports) when any of the ink cartridges are empty. This is to ensure the life of the print head and maintain premium print quality. If the unit were to continue printing, print jobs and cleaning cycles would suction air from the dry cartridge and damage the printhead. Even if you print in black only or change the print settings to MONO or GRAYSCALE to avoid printing in color, the programmed cleaning cycles would still suction the dry cartridge, because they are programmed to clean ALL the ink nozzles.
The only way to continue printing is to replace the empty ink cartridge or cartridges.
While memory is available, black and white faxes will continue to be received into memory. If a color fax is being received, the Brother machines HANDSHAKE will request the fax be sent as black and white fax.
All faxes received into memory will automatically print once the ink cartridge is replaced.
NOTE: Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorized third party ink and/or cartridges.
Posted on Dec 02, 2008
pagebor
  • 2785 Answers
SOURCE: Won't print with only 1 cartridge empty
sorry you can print unless all your cartridge are having some ink
Posted on Dec 17, 2008
billfox1966
  • 231 Answers
SOURCE: cant print in black and white when out of a color.
disregaurd any prior solutions in cleaning any contacts. that model doesnt have an electrical contact to clean. there are little magnets inside each color and black cartrige that work off a float mechanisim inside each one. when the levels get low the magnet indicates to the printer it is empty. unfortunately for you this stylis model as with all brother model printers wont work even if the color your setting up in the properties or settings feature are set to black and the black is full. its the companies way of forcing you into buying new ink. be aware though that my brother catriges cost 78.00 for the 3 color and one black set. i found these cartriges online through ebay but with one more additional black cartrige for a total of 5 not for ,for a total cost of 13.11 with free shipping. sounds too good to be true but for 13.00 it was worth a try. i have now purchased several 5 packs from them and couldnt be happiere.
Posted on Jul 10, 2009
jennerina
  • 86 Answers
SOURCE: Can't print in black and white
Hi Aaron,
There should be a setting in your PREFERENCES that allow you to set it to black print only. Select it as your default setting so that you don't have to change the settings each time you print.
Hope this helps. Good luck!
Posted on Jul 31, 2009
  • 22 Answers
SOURCE: I'm out of magenta ink and can't afford another. I
Tell the machine to only print in greyscale. This is done on the printer driver. The machine will then ignore the amount of colour toner in the colour cartidges.
Posted on Mar 07, 2010
  • 3 Answers
SOURCE: Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Posted on Aug 02, 2010
My printer will not print anything. I have a full cartridge of black ink, but low on the other colors. Will it not print with the colored ink out?
Assuming the test print page prints using the black ink, printers have a setting that allows you to select black and white printing. If you need further help you need to include the manufacturer and brand of the printer. If the test page doesn't print the black ink and Since you say you have a full black ink cartridge I would also check that you completely removed the plastic tab/sticker that covered the hole the the inks comes out of and that the ink cartridge is securly installed.
Dec 06, 2016 | PRINTER Office Equipment & Supplies
My school room printer Dell 5130cdn is out of color ink, however it does still have black ink, how can i get the printer to print with just the black ink?
when in print section go to settings and click on black or unclick color
be aware that color is need to get black and white reproductions ( copies)
Aug 17, 2016 | Dell 5130cdn Color Laser Printer
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Can I print black and white without having color cartridges?
You need to have color cartridges installed for your printer to function. You can however print black and white with empty color cartridges. If you do this you may damage the print head and not be able to print in color again. If you can live without color printing I recommend a monochrome laser printer. It will never print color, costs 1/2 as much to print with, won't dry out, and the cartridges last way longer than ink cartridges.
Sep 28, 2010 | HP Officejet 6500 Wireless All-in-One...
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I want to print in only black but my printer keeps telling me to install my color cartridge. How can I get my printer to work/print using only the black cartridge
You can print in only black and white by choosing the grayscale option in the print properties, but you still have to have ink in each of the color cartridges. Even if you are only printing black, the machine will not let you print if any of the colors are out.
Replace the empty ink cartridge, and then select "grayscale" to print only in black and white.
Jun 14, 2010 | HP PSC 750 All-In-One InkJet Printer
Won't print because color cartridge is empty and l don't need color
Try changing printing preferences/properties. Click on option for color, then click on box for "black ink only" or similar. Try now. If you still cannot print after changing preferences/properties, you will need to replace color ink cartridge due to manufacturer's built-in software that prevents printing when ink is low. Great for the ink companies!!!
May 18, 2009 | Cannon i70 Printer
Dec 17, 2008 | Epson Stylus Color 740 InkJet Printer
Lexmark z1300 printer - one cartridge
if you look at the options in the printer there should be an option to use the color cartridge to print black. How does this work? Well what the printer will do is mix all three colors to make a light black. This will eat up your color cartridge faster but is useful when you are out of black ink and you need to print
Apr 23, 2008 | Lexmark Z1300 InkJet Photo Printer
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
565 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
