Question about PNY Technologies GeForce 6200 256MB AGP Graphic Card
Blank screen when moving windows
I have a few stability issues within windows but otherwise it works quite well. Specifically: 1) When I move windows around, or scroll the contents of windows (basically anything that requires changing the screen) I frequently (every 10-30 seconds) get a blank screen for up to a second and then it works. It does not hang, or otherwise interfere with my work. The GPU temperature as reported by the Advanced Settings is around 40C so it does not look like an overheating issue. 2) Sometimes my machine hangs (possibly due to a graphics card issue, as the screen often gets corrupted before the hang) and when I reboot into windows it hands with vertical blue lines across the screen. I then have to turn the machine off, wait a while, turn it back on. I then get asked whether I want to go into safe mode, I select normal mode and start windows up, at which point it complains about display settings (I presume that is because it has reduced the settings because it failed to start windows previously). I ignore those, shutdown and the reboot my machine at which point it is ok. Machine is as follows: Windows 98 SE MSI-6340 motherboard. 256MB memory. AMD Athlon 1000MHz
  • Paul Duffin Jan 06, 2007
    BTW. I ran both 3DMark01 and 3DMark03 and they both ran perfectly giving results of 3300 and 1400 respectively (not the fastest in the world but 4 times faster than with my previous graphics card).
    Sometimes, when I log in I get the task bar but no Desktop because explorer has hung, when I kill it then I get the desktop but every non built in icon has a little black square in the bottom left hand corner. In this case I also get corruption (random pixel blocks) and scrolling and dragging windows is very slow.
    Problem Solver:
  • 17 Answers
First, check out this link -- http://www.pcguide.com/vb/showthread.php?t=25482 That board is known for bad caps, the link will show you what to look for.
Posted on Jul 18, 2007
SOURCE:
Console reads "Program Error 1" and otherwise won't operate normally or move out of that mode..
This issue is more than likely being caused by either a faulty PCB or PCBA. It could also be caused by a combination of both of these boards being bad. Below is a link to see these parts. PCB for C40 Console SM27130 SPORTSMITH net
PCBA with LCD Screen for C40 Console SM40070 001 SPORTSMITH net
Jan 10, 2015 | Stairmaster 4600 Cl Cordless Freeclimber
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
Have a Consew 206RB-1. Seems within the span of a few hours today that whenever I'm turning while sewing any material, it will drop a stitch. When sewing in a straight line, it's perfectly fine. Can't seem...
It is probably because you need to move slower when moving the material around, as otherwise the thread beneath will just stretch over and make a new stitch. just slow down loads and should work! this probably isnt the right answer but hope i may of helped! :)
Oct 28, 2010 | Consew 206RB
Hi i cant move my torque setting its just stuck on hammer and drill,speed ie 1 to 3 is okay but i cant get it to move to 1 to 21 is this a common problem thanks
You have an internal issue in the housing. Sometimes they will move while slowly operating the drill. If that does not work, the housing has to come apart, more specifically the head.
Jan 16, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Screen blanks out after a few seconds. If I turn
Fixya:
My IE 8 loads the correct odds on the tote-board and then suddenly the odds go blank.
I have to click down to another track and then click back up to get the odds working again.
The issue happens again at another track that I click on. Forces me to go through the same proccess over again.
This bug related issue is very aggravating so if there is a fix I would appreciate it.
oppusone
My IE 8 loads the correct odds on the tote-board and then suddenlly the odds go blank.
oppusone
oppusone
oppusone
Aug 31, 2009 | AOC LM720 17" Flat Panel LCD Monitor
Windows Xp wont boot up
try starting windows in safe mode and go to an earlier system restore point if that wont work try installing windows again if windows wont respond to this it will be a hard drive issue it will need replacing
Jan 22, 2009 | HP Pavilion dv9000z Notebook
Pokemon will Not Set Up
DO NOT breathe or move ur thumb/stylus after a few seconds it'll work
took me a while 2 figure out that it knows if u move or breathe
Dec 25, 2008 | Pokemon Mystery Dungeon : Explorers of...
Philips 170b 17" LCD Monitor
Does the screen go to the top of the page by any chance if so their is a possible cable problem that links your PC to your monitor, to repair this you must take it to a electrical repair shop, its quite a small job and your screen should be back up and running in no time, it happened to my packard bell monitor aswel and i managed to get it repaired.
Hope this answers ur question John.
Nov 21, 2007 | Philips 170B4MG 17" LCD Monitor
Canon PowerShot A460... screen resolution
Ok, couple of ways, I'll start with the easy one - Go to a blank space on your desktop (anywhere its blank) and right click. You get a drop down window, go to the bottom where it says Personalize (it says Properties in windows XP)
Windows Vista - You get a window with a buncha links - the bottom should be display settings. click it. You'll see a long bar where u can drag a notch across from left to right... move it over to the right 1 notch, click apply (screen may get smaller, but its normal, just zooms out) Then click yes if a windows asks u if its ok. then click apply, and ok on the display settings window. Then try running the disk again... if it give u the same error, repeat the steps, just moving it over to the right a notch (just 1) each time.
Windows XP - You'll get a window with a buncha tabs. click settings tab. You'll see a notch to drag left and right. move it over to the right 1 notch, click apply (screen may get smaller, but its normal, just zooms out) Then click yes if a windows asks u if its ok. then click apply, and ok on the display settings window. Then try running the disk again... if it give u the same error, repeat the steps, just moving it over to the right a notch (just 1) each time.
Hope it works out! My grandma just now asked me how to do it, and since i love her so, and don't want anyone stuck on this error either, I'm posting it for yas:-)
Sep 21, 2007 | Canon PowerShot A460 Digital Camera
Computers & Internet Logo
Top PNY Computers & Internet Experts
Thomas F. Schneider
1400Slugg
Are you a PNY Computer and Internet Expert? Answer questions, earn points and help others
