Question about Compaq Presario Notebook
Your compaq presario lcd screen problem
Did u every find out what to do bout your screen cause i have the same problem, only thing is if i hold the top left corner inward kinda hard with my left hand which gets old fast. the full display comes back in aand i can one hand it.
How an what kind of glue do i need to replace a part that has came apart
if it is plastic then one of the regular "super glue" thing will do.
If it is metal then soldering might be possible.
Jul 13, 2014 | Compaq Presario sr1403wm AMD Sempron 3000+...
How do I remove the LCD cable from my Compaq Presario C700? Which tape do I remove / What do I do?
You have to remove the keyboard. Most laptops have the keyboard screws at the bottom or underside of the pc and right next to the screw hole is a little keyboard picture thing or illustration that tells you that screw is to hold down the keyboard. once the keyboard is removed, you can easily get the LCD screen wires disconnected.
Aug 25, 2011 | Compaq Presario 700 470024-192 Notebook
I have Compaq presario CQ60 notebook pc.When the lid of screen is moved it starts flickering. What should I do ?
This is typically caused by a loose cable inside of your screen. I do not suggest tinkering with it as you could possibly damage it more. In case you're feeling brave, here's a guide on how to get to the LCD on your model of laptop:
Again, I don't recommend trying this unless you have some prior experience with this sort of thing. Take it into a certified technician or call Compaq (HP) @ 1-800-HP-INVENT
Mar 31, 2011 | Compaq Presario Notebook
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
Compaq Presario CQ50-110US...blank screen, no display
Can you see what's on the screen if you hold it under a light? Did the screen die suddenly or were there more symptoms?
May 05, 2010 | HP Compaq Presario CQ50-110US Laptop
My compaq presario f557us hard drive is working butI have no screen any help please?
Replace the memory sticks one at a time in each slot one at a time. If that doesn't work, reseat the lcd cable from the back of the lcd and to where it connects to the motherboard.
If the hard drive light is still running like its loading up windows then at that point, replace the lcd screen and cable cause that means voltage isn't getting thru the cable to get to the screen.
Dec 30, 2009 | HP Compaq Presario 730US Notebook
Screen flashes on Compaq laptop
It may be the cable that attaches behind the screen is loose. If you type in your model# and "lcd replacement" in Google you will often find a tutorial on how to take it apart. Patience though our you will break something!
Apr 13, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 700 Screen works but multicolored & hard to see things.
If you have a short or loose cable in the LCD assembly, it would be a good idea to have a local tech check it out, specially if you "fix" it by pressing or moving the screen around.
Sep 27, 2008 | Compaq Presario 700US Notebook
How much will it cost to repair lcd laptop compaq presario 2200
Narvie, The problem you are describing can be caused by a couple of things ranging from a loose connection (< $100) to a faulty component (>$100). If you take it into your local repair shop they should be able to give you a decent estimate before actually working on it. If you work on it yourself you save money on labor, however, you?ll probably spend a lot of time. Compaq used to have a program where you would pay a flat fee, ship them your old laptop and then would ship you a working one. Sorry I couldn?t give you a better answer but without having the laptop in front of me it isn?t possible to give a closer estimate.
Mar 20, 2007 | Compaq Presario 2100T Notebook
Compaq Presario Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
