Question about Kenmore 93142 Gas Dryer
Need to remove the front panel of a kenmore 90 series gas dryer
I need to check why the dryer won't heat up.
4 Suggested Answers
  • 101 Answers
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
Posted on Jan 22, 2009
Sea Breeze
  • 4655 Answers
SOURCE: how to remove front panel from kenmore 90 series gas dryer
Gently pry top of dryer in front corner area. Disconnect door switch inside front. Remove 2 sheet metal screws from inside front. Let me know, Thanks, Sea Breeze
Posted on Mar 21, 2009
  • 2694 Answers
SOURCE: kenmore gas dryer no heat
unplug the dryer,remove the lint filter,take off the bottom panel and remove the duct that the lint filter slides into,clean the duct out,while you have the duct off on top and to the right of the blower wheel housing you'll see a 3390719 thermal fuse,remove one of the wires and check it with your meter to see if it's good,most of the time if the dryer hasn't been cleaned out the fuse will blow,the dryer runs to hot and the fuse is a safety so you don't have a fire and so the dryer doesn't run hotter than it should. vac out the inside of dryer and if you have a shop vac it blows on the other side,blow off the motor and blow the lint from the back forwards so you don't have to remove the drum,next you have to clean out the vent line,if it's a long run from the back of dryer to the outside flapper i use a leaf blower to blow out the line,you should clean the dryer once a year,if the fuse is good you need to check with your meter the ignitor,the sensor and the gas coils to see what's bad,if you need anymore help let me know,good luck,when you're reading anything out with the meter make sure you remove at least one of the wires or you'll get a false reading
Posted on Mar 17, 2010
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? -
Looking Inside My Dryer -
Exterior Exhaust Duct -
Oct 10, 2014 | Kenmore Dryers
Take the back off and look at the heater is what I would do If your filter comes out the top the dryer breaks down like this:
If your dryer has the filter down in front then your dryer comes apart like this:
Oct 03, 2012 | Kenmore 73952 Gas Dryer
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Aug 02, 2011 | Kenmore Dryers
Dryer barrel turns no heat this is a gas dryer 90 series kenmore
remove front cover, this will allow you to remove top cover, then take off drum belt and you will see the gas valve,follow the gas tube to the fire funnel and you will see the ignitor, check for continuity, if its good, then it could be a flame sensor or the control board at fault
Sep 24, 2009 | Kenmore 75944 Gas Dryer
My Kenmore 90 series dryer's pilot light is out. What can I do? I have a Kenmore 90 series gas dryer and its not getting heat.  If I look at the igniter which is a carborundum igniter and I don't see...
Hi, You should first check the fuse. If the back comes off try this:
UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If the rear panel does not come off, please get me model # and I can assist you further.
Please let me know if this helps you.
May 28, 2009 | Dryers
How do you open front panel?
you need to remove the top of the dryer in order to remove the front.
May 05, 2009 | Dryers
How to remove front panel from kenmore 90 series gas dryer
Mar 21, 2009 | Kenmore Dryers
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Dryer not getting hot
fist make sure the fuses are good.. unit will run on 110 but not heat.. check connectores and cables or pigtail. it not.. then check heater coils and or thermostat...
Jun 13, 2008 | Kenmore Dryers
Kenmore 93142 Gas Dryer Logo
48 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
