Question about Refrigerators
Amana bottom freezer model BR18vw
Our amana bottom freezer is cold but not enough to keep everything on the door frozen even at the coldest setting. The refrigerator seemes to be working ok. can you give us any help?
  • JEFF SIEGEL May 11, 2010
    Is there frost on the back freezer wall?
the dr
  • 447 Answers
SOURCE: My refigerator and freezer are not cooling enough
Is the fan in the freezer running?? Is there frost on back panel of freezer??
Posted on Oct 03, 2007
dididsaythat
  • 291 Answers
SOURCE: freezer works fine but no cold air in refrigerator...
Check make sure evapurator fan is blowing and nothing blocking any return vents in refrigeratro side prevent air from recirclating
Posted on Dec 01, 2007
textonor
  • 130 Answers
SOURCE: amana bottom freezer
Hello ghilitho, what you are having is an issue with the defrost cycle. There are 3 parts to this, heater, thermosat,and timer. Sometimes on the newer units the timer is the electronic control. What you are seeing is after you defrost the unit, it works for a time, this is because the evap fan pushes the air thru the unit. With the evap coil froze solid, the cooling drops. You will need a ohm meter to check the heater and thermosat, the heater & thermosat should show to be closed. Also make sure if this unit has a over heat thermosat that it is closed. It may have open up. If all this is good, then the timer is the issue. Hope this helps
Posted on Jan 28, 2008
  • 1214 Answers
SOURCE: amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Posted on Jan 20, 2009
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
Freezer not uniformly cold
Check the fan vent to see it's not blocked or frozen. Sometimes a defrost will clear ice temporarily, but it will happen again if you have a bad fan.
Mar 26, 2014 | Amana 19.6 cu. ft. / 555 liter Upright...
Everything in the refridgerator is frozen,
Can you hear the refrigerator cycling on and off or is it running continiously? It it is not cycling the cold control/thermostat is defective.
Oct 08, 2012 | Amana AFI2538AEB (256 cu ft) Bottom...
The bottom freezer is not getting cold even though I set it on the coldest setting. The refrigerator is not getting cold when I set to the coldest temp.
If there is no cooling at all , check to see if compressor is running, if not check for power at compressor if no power see if themostat is open
Jun 22, 2011 | Amana ABB1927DE Bottom Freezer...
Fridge & freezer not cold enough
EASY FIX. TAKE ALL FOOD OUT OF FRIDGE AND FREEZER AND STORE IT.
THEN UNPLUG YOUR FRIDGE FOR 24HOURS WITH DOORS OPEN.
YOU WILL HAVE TO CLEAN UP ALOT OF WATER. THEN CLEAN THE FRIGE.
WHEN YOU PLUG IT BACK IN IT WILL WORK.
BUT THIS IS JUST A TEMP FIX. IT WILL HAPPEN AGAIN IN ABOUT A YEAR OR TWO.
TO GIVE U A MORE PERMANENT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
Apr 30, 2009 | Amana ARB220ZC Bottom Freezer Refrigerator
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Kenmore refrigerator won't cool, but freezer does.
by closing that small door you are starving the refrig of cold air . you should be getting a heavy whisper of air through that door. place all controls in the middle position, close the freezer door and check for airflow through that vent.
Feb 24, 2008 | Refrigerators
Refrigerators Logo
176 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
