Question about Whirlpool GU2400XTP Built-in Dishwasher
The top rack on my dishwasher goes up or down but i dont know how to get it to do that.
  • 338 Answers
If there are no blue tabs at the top of the rack around the area of the wheels the you have a stationary rack. see if there is another digit at the end of your model number
Posted on Nov 26, 2008
Makes a loud noise but when we take the top rack out it runs quietly.
Hello Karen, thank you for your post!
I understand that your Electrolux dishwasher is making a noise when the top rack has been installed. It could be a possible issue with the rack or glides within your dishwasher. I would recommend reviewing your glide and rack to make sure there is no visible damage. You may need to replace those components. I hope this information is helpful to you. -OOS
Apr 24, 2015 | Electrolux Dishwashers
Top rack slides all the way out
Most likely your dishwasher is not level, but is tilting forward. Just extend the front leveling legs down further to raise the front end of the dishwasher. Otherwise, the rack glides may be damaged or bent.
Sep 18, 2014 | Dishwashers
Top rack not getting water or washed
Check (or have someone check) your impeller - it is probably located under a cover in the bottom of the dishwasher - you might need a hex screwdriver to access it.
Anyway, this needs to spin, if it's stuck, your water pressure goes WAY down, and the top rack just gets a little wet instead of sprayed.
Mar 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The top rack dishes do not get cleaned. I have run the vinegar rinse. The bottom rack dishes get cleaned. It doesn't even look like the top rack dishes get wet. I ran the washer without the top rack in and...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Nov 06, 2010 | Dishwashers
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Nov 25, 2009 | Whirlpool Dishwashers
LG LDS5811 top rack not cleaning
I Have the same issue, it sounds like the arms try and start up 4 times then each time power back down, the top arm is not spinning at all. On the fifth time a I hear grinding and then the mid and lower arms spin, soap streaks down the door, nothing stuck in any of the arms, 16 months old, 750.00 out of pocket for junk!
Oct 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Top rack whisperquiet dishwasher no water
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
Sep 27, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
Middle spray arm not spraying
unlikely that 2 dishwashers would have the same fault but is of course possible
could it be to do with how you are loading? quite common is for a knife or similiar to stick down thro the rack and jam the arm
Nov 19, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
99 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
