Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
Light not going out in viking frig when door is closed
Frig was over heating I was getting high temp alarm. The inside around lights was very hot. Unscrewed bulbs and frig cooled off. Can not find what trips lights when door is opened or closed
  • 42 Answers
You have a micro switch at the top of door by the door hinge.must remove top vent cover to access. i've found that if the screws (2 or 3 phillips ) get loose the door is not aligned to open and close the light switch . or maybe the switch itself has failed
Posted on Dec 21, 2008
My built in Viking frig/bottom pull out freezer overflowed water recently. The alarm keeps going off with "freezer temp" light coming on. Please see details below.
that guy is ripping you for service calls it need recharged with gas and he knows it . being that only certified tech can do that task
Jun 08, 2015 | Viking DFBB363 Bottom Freezer Refrigerator
My kenmore refrig (freezer on top) has started dripping from tube near temp control inside of frig. I think it might be related that one month ago - electric was off since not at apt for one month. Doors...
Your defroster inside the fridge may not be doing a good enough job to keep the drain from freezing up. Check to see if the drain pan is frozen over in the freezer section. I took the cover off the inside of the freezer and wrapped a piece of uninsulated 14 gauge solid copper wire around the heating element and pushed one end down the inside of the drain tube and wrapped the other end around the heating element. No problems since.
Aug 16, 2013 | Kenmore Sewing Machines
My samsung frig suddenly started clicking (the bell that lets you know the frig door is opened.) checked to make sure all doors were closed but bell keeps ringing and now the temp. is rising inside. what's...
Can you pull the gasket back slightly (flat screwdriver or dull knife, don`t cut/rip the gasket) from the side of either fridge door and tell me if the cabinet light is on inside ? I need to know if the light is on without opening either door.
I`ll watch for your reply.
macmarkus :)
Feb 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
Freezer not maintaining temp
sounds like the evap thermistor took a ****. in the back of your freezer you have cover that sits over the refrigerator coil. under this coil sits a heater element that is turned on and off to defrost the refrigerator coil based on how long you've had the door open. the evap thermistor reads the temp inside the freezer.. close to the refrigerator coil.. and tells the heater element to turn off after it reaches a set temp where it can be sure that the ice has melted off the refrigeration coil which is about 60 deg. if your thermistor has taken a ****.. your heater element will only shut off based on the "fail safe" time (which is based on how long you've had your fridge door open) leading to a hot freezer.
i suspect your at home more on the weekend.. inside the fridge.. getting cold beers.. and that is why it ends up hotter on the weekend.
Jun 14, 2009 | GE Energy Star PDS22SIS Stainless Steel...
Refrigerator and freezer not cooling
sound like side by side check compressor for starting up check defrost timer
May 30, 2009 | Viking DFBB363 Bottom Freezer Refrigerator
GE refrigerator tfx27zp or 25zp or 22zp not sure.
The drip pan is located under the front of the frig.
open both doors, remove the panel that is across the bottom of the fridge( there are release tabs over the left and right front corner areas close to the hing sides
after removing the panel you should see a tray that slides on rails under the fridge
remove the panel and inspect to see (use a flash light)if you can see the drain tube
I believe your drain tube is freezing up somewhere inside the frig
If you can determine where this drain tube fishes up through the back inside wall of the frig
remove all of the trays and observe the back panels there should be some type of collector tray
near the frig light Some models have a hot bulb to do the defrost
I suggest that you tun frig off with both doors open take a hair dryer and blow hot air where you think the drain is located to melt any ice and look down in the drain pan to see if it starts draining
Hope this helps
Good luck ( ps cal ge customer service and give model number I bet they have a design poblem
If they do they may have a work around
God Luck
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Viking all refrigerator
I just started having the same problem with my 48" frig/ freezer Viking Designer series 2 years old- this has been a hot summer, we were not home much and the AC in the house was set higher 78 degrees so the frig I guess had to work a bit more - when I open the door to the frig water droplets acually run down the interior of the door and the box insde is always damp - I also have stress cracks in the interior shell of the frig - repairman is trying to get Viking to fix it- it has been a year now and it still is not fixed- the stress cracks were caused by improper insulation application to the inside of the frig according to the repair people- Also my handles have pealed - like the stainless steel is not really stainless steel - Any ways could the temp in the house changed - does not mean the frig should not work well - For what it costs, I expected better
Sep 11, 2008 | Viking 42 in Built In Professional...
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
67 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
