Question about Sony Handycam DCR-TRV22E Mini DV Digital Camcorder
Unable to eject tape. error c:32:10. not listed in manual
I have put in a new tape, amd after about 2 minutes of taping, I turned the cam off. Some 5 minutes later, I tried turned unit on and tried to tape. The following error was indicating on the screen (c:32:10)and I was unable to eject the tape. Can you pls advise. Cheers Joe
  • 169 Answers
SOURCE: Eject is flashing with fast beeps. Won't eject tape or open compartment.
sad to say that the problem of your camera is the timing gear is already need to disassembly the camera to fix the timing gear....go to the qualified service center for fixing or replacing the timing gear..
Posted on Aug 21, 2007
  • 217 Answers
SOURCE: c:32:11 message flashes, cassette eject won't work, camera doesn't work
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Posted on Nov 25, 2007
SOURCE: Flashing code C:32:11
Posted on Sep 04, 2008
SOURCE: Error code on DCR-TRV530 - C:32:10
Thanks Tonrey11, it worked to me, as well.
Posted on Sep 15, 2008
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
Posted on Oct 21, 2008
  • 10594 Answers
SOURCE: Sony Handycam DCR-HC32 Not Working, Not Ejecting Tape, LCD Flicker
DCR-HC32 need new tape mechanism as shown in below exploded view.
Its part number is as follows..
A-1082-424-A MD (Z210) SUB ASSY
Posted on Nov 06, 2008
0 characters
1 Points
When the cam is put on recordning mode a error on the screen shows the following- eject sign followed by ...D , On top on screen its written EJECT LP
The error display shows that the camcorder has some mechanical fault.Follow the instructions below.
1. Eject the Tape
2. Set to OFF
3. Detach the battery
4. Reattach the battery
5. Power ON as usual
Simple faults will be recovered when performing the above procedure.Good Luck
Jun 04, 2011 | Samsung VP-D361 Mini DV Digital Camcorder
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
I can't get tape out of cam corder
Let me know the error message. Go down further on the error message check for numeric code. If you see ''02". I'm sorry you need a qualified personnel to do the job. if it shows "03" keep the cassette door open(5 sec or more and make sure to put power on it) and wait until it open.If it ejected, try with another tape, it could be your tape causes problem. Good luck
Dec 31, 2009 | JVC GR-D290 Mini DV Digital Camcorder
I have a jvc gr-sxm26u camcorder and it has two problems... the tape door will not open when the eject button is pushed to the left. 2nd problem. the screen indicates that there is a problem labeled as "...
E01 Mechanism has not fully loaded up to the stop position
E-01, E-02, E-05, or E-06 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code which is to inform a technician which area of the camcorder to examine in order to ascertain the nature of the problem. Try the following steps:
1) Remove power source for 1 minute. 2) Reattach power source. 3) Try operating the camera.
The indication E-03 or E-04 is an Emergency Error Code. In the event of a malfunction the unit will shut down and display a code. This is to inform an independent JVC authorized service center which area of the camcorder to examine in order to ascertain the nature of the problem.
The E-03 or E-04 code relates to one of the tape spindles not turning. This could be the result of too much slack on the video tape. If E-03 or E- 04 is displayed it may be possible to correct the problem by removing the tape slack. In order to do this follow these steps:
4) Repeat above steps until tape ejects.
5) Tighten and insert a new tape."
A common E01 problem with the JVC is caused by electrically conductive residues on the very end of the connector strip which connects the small front circuit panel to the main circuit panel (this residue can only be seen under a microscope). Symptoms are, the mechanism remains closed or the cassette holder will not latch down and remains permanently raised. Basically the micro cannot read the mechanism position data. The connector strip needs to be taken out & carefully cleaned with alcohol.
If all else fails then its a trip to JVC service and a biil of between $`100 and $250 depending on what the problem is. My last E01 was a motor change and cost $180 but the cam has been fine ever since but next cam will be a Canon..
Oct 14, 2009 | JVC GR-SXM260U Camcorder
Camera won't record a D comes on screen and eject tape comes up.
I have a cam corder model VP-D361 PAL, since i brought i could not use it even a single time, for the past 2 yrs it was kept as it was brought in packed condition, i was using other cam corder of jvc, when i opened and start using it, i found a triangle and a D on the screen, several attepts made by taking out battery, and casset. but still same thing appears,(AFTER REFERING TO USERS MANUAL) it may be a simple problem, or a defective one, since brought a single minute is also not used, kindly help me to solve this problem from a local serviceing mumbai, india.
My address as below,
TEL NO. 91-22-2520 5842
MNO: 9892004970,9987904458
Jan 18, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Error ....D
This error is a mechanical malfunction, try this:
  1. Eject the tape.
  2. Set to OFF.
  3. Detach the battery.
  4. Reattach the battery.
Here is a link to your manual:
Mar 13, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
Apr 21, 2007 | Canon ES900 Camcorder
E03            TU & SUP REEL FG
In the case no REEL FG is produced for 4 seconds
or more in the capstan rotation mode after
loading was complete, the mechanism mode
is shifted to STOP with the pinch roller set off.
This error is defined as [E03].
However, no REEL EMG is detected in the
1. The idler gear does not engage with the reel disk well.
2. Though the idler gear and reel disk are engaged with
each other, the tape is not wound because of overload
to the mechanism.
3. No FG pulse is output from the reel sensor.
4. No power is supplied to the reel sensor.
5. Tape transport operation takes place with a cassette
having no tape inside.
6. The tape slackens and no pulse is produced until the
slack is taken up and the tape comes into the norma
Dec 09, 2006 | JVC GR-D290 Mini DV Digital Camcorder
Sony Handycam DCR-TRV22E Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
