Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Tv brightness Well i have mitsubishi wd 52327 dlp 52 inch tv, its 2 years old and watching a hight def channel the picture has a light haze to it.I had explain the situation to a authorized mitsubishi repair shop and the said i might be the light engine is going out, what is the light engine on the tv i would like to know. I have a Mitsubishi WD-62525 and it is getting a hazy picture and is also has a few dark spots on the back side of the screen. The bulb has been replaced but it has not helped the picture.
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Posted on Nov 27, 2008
2 Suggested Answers
SOURCE: Tv brightness
the light engine is that part that displays the picture on the screen. its like a filmprojector. if you need the complete LE, you run in about 1200-1600 dollars.Mitsubishi DLP's are known for collecting great amounts of dust, so try to clean the filters first and remove all the dust you can find.be careful,do not use a vaccuum as they can damage the electronics and the fans.....
Posted on Jan 11, 2008
Tv turns on works for awhile then shuts down
it seems cooling problem check if fan is working or not
and check the english user guide
http://www.manuals365.com/swf/mitsubishi/wd-62327.html?page=50
Mar 17, 2015 | Mitsubishi Wd-52327 52" 1080i Hd Dlp...
I have to change the lamp on my mitsubishi dlp tv. where is the lamp located?
Here is a link to the owners manual for lamp cartridge replacement. Specifically go to page 65 for instructions. Good Luck : )
http://support.mitsubishi-tv.com/files/oguide/WD-52327.pdf
Jul 26, 2011 | Mitsubishi WD-52327 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture getting darker over the years
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Mar 11, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Tv brightness
Jan 11, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-52327 Picture flickers and goes blue
In your case I've seen this and it was a electrical issue between the DLP fan and board. The tv could have a problem with the digital tuner and not kicking a code due to low voltage ... it isn't expensive to fix, just hard to diagnose.
Do you smoke? The fans suck in smoke and it gets tar build up on the connections and that causes this in some cases too.
Dec 28, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
348 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
