Question about Canon BubbleJet i560 InkJet Printer
Black print head not working well after transporting.
It is only a few months old, and hardly used. I transported it by air freight long distance recently, and the black print is missing bits on the nozzle test print. I left the cartridges in during transport, and left it as is - they packed it well. Surely I don't need to buy another print head? Any help would be greatly appreciated! Many thanks
  • Pete Gill Jan 08, 2007
    Tom
    Thank you for taking the time for such a comprehensive response - I'll try it, and then respond.
  • Pete Gill Jan 16, 2007
    Thank you -got the printer working. I also tried it on an older one though (s450), which had the same problem when I transported it overseas about a year ago, and has not been used since. unfortunately it did not work here - the black and yellow heads print intermittently, even after windex soak, a few nozzle cleans and deep cleans. Any ideas on this older printer would be gratefully appreciated, thanks.
  • 624 Answers
Hi Pete, your're printer is probably still good. If you haven?t done so you should run the nozzle cleaning utility a few times. Compare the first on with the second or third and see if it?s getting better. If yes some of your nozzles were clogged. If it?s close to being back to normal you can run the cleaning utility again or you can remove the ink cartridge carrier and clean the nozzles. I had a Canon printer similar to yours so it?s probably similar to yours. Your ink cartridges plug into a carrier which actually contains the ink nozzles. Remove the ink cartridges from the carrier, place a piece of tape over the bottom ink output hole and store them oriented as if they were in the printer (up). This will prevent the ink from draining to the top of the cartridge and possibly causing flow problems later. Tank the cartridge carrier and place it in a small plastic bin and fill with Windex till the nozzles are covered. Make sure you also put some Windex in the carrier itself in case the blockage is there. I use straight Windex (window cleaner containing ammonia for non-American types); I find the real stuff is better than the store brands when it comes to removing stubborn clogs. I also use a sealable plastic food container to soak the print heads in. When I?m done I snap the airproof lid on so I can save and reuse the Windex again. Once you?ve done that use a Q-tip to gently scrub the surface of the nozzles and let soak overnight. After the soak is done shake off as much of the Windex as possible and reassemble the printer. Make sure you don?t let the cartridge carrier dry out, that will probably re-clog your nozzles again. Run a couple of nozzle cleaning cycles to clean out the residual Windex and start the flow of good in again. If it worked your printer should be back to normal again. Let us know how it turns out and don?t forget to rate the posting.
Posted on Jan 06, 2007
SOURCE:
Hi I need help obtaining documentation that the blackweb product w upc of 6**********0 is not hazardous and safe to ship
It is hazardous to ship as it contains a Lithium Ion battery. Certainly not permitted to be carried on an aircraft unless in hand luggage. Can't be sent as hold luggage. Ground freight only.
Did you know that Lithium Batteries are ... - Transport Canada
https://www.tc.gc.ca/eng/tdg/lithium-batteries-are-dangerous-goods-1162.html
  1. Cached
  2. Similar
Apr 11, 2018 - In Canada, the shipping and importing of lithium batteries are subject to the ... A charging lithium ion battery exploded on a mini-submarine designed to carry U.S. .... To simulate air transport under low-pressure conditions.
[PDF]Shipping Dangerous Goods - Lithium batteries by Air - Purolator
https://www.purolator.com/.../Shipping-Dangerous-Goods-Lithium-batteries-by-Air.p...
  1. Cached
  2. Similar
Lithium Ion Batteries (packed with or contained in equipment)1 - UN3481. Lithium Metal Batteries - UN3090. Lithium Metal Batteries (packed with or contained in equipment)1 - UN3091. The following information is related only to the shipment of lithium batteries by air transport.
[PDF]Shipping Dangerous Goods - Lithium batteries by Ground Lithium Ion ...
https://www.purolator.com/.../Shipping-Dangerous-Goods-Lithium-batteries-by-Grou...
  1. Cached
  2. Similar
Lithium Ion Batteries - UN3480, UN3481. Lithium Metal Batteries - UN3090, UN3091. The following information is only for the shipment of lithium batteries by ground transport. If you are shipping lithium batteries by air transport, please refer to the Purolator document "Lithium Batteries by Air".
How To Ship Lithium Batteries in Canada ' Dangerous Goods Packing
www.dangerousgoods.ca/how-to-ship-lithium-ion-or-metal-batteries.html
  1. Cached
We are Transport Canada Air Cargo Security Approved ... So, come April 1st, if you have to ship lithium ion batteries by air which are not packed with equipment, ...
IATA - Lithium Batteries
www.iata.org/whatwedo/cargo/dgr/Pages/lithium-batteries.aspx
  1. Cached
  2. Similar
The ICAO Council has confirmed the recommendation of the ICAO Air Navigation Commission (ANC) that prohibits, on an interim basis as of 1 April 2016, lithium ion batteries (UN 3480, PI 965 only) as cargo on passenger aircraft.
Air Transportation of Li-Ion Batteries ' PAG Ltd - Batteries and Lights ...
https://www.paguk.com/content/air-transportation-li-ion-batteries-0
  1. Cached
  2. Similar
The International Air Transport Association (IATA) in association with the ... PAG Ltd. hereby declares that its Lithium-Ion batteries have been tested and certified ...
Jun 22, 2018 | The Computers & Internet
What is the role of freight rate management software?
Freight management is the system for optimizing the efficiency of commercial transport and freight. People have the tendency to think that it is only the heavy vehicles involved in between to carry out the transportation job with such aptness. However, one forgets to think about the system that lies behind the transportation.
A number of approaches are used to effectively implement freight management when the goods are transported. Freight Rate management Software the tool that is employed to minimize the expenses and determines the set price of transportation.
Freight costs are important considerations that need to be taken into account when the one producing the goods and transporting it wishes to calculate the fair price, yet profitable pricing, to charge for the goods. This is where logistics come to play its role. It is the logistics services which consider the shipping process, as the whole, including the vehicle type, shipment size, facility sites, mode of transport and the shipment frequency.
May 13, 2016 | Applied Logistics Android Apps
Which is the best sea freight service providers?
Ntllogistics Plus is the best sea freight service provider in India.It offers services at best market rates. Read more..http://www.ntllogisticsplus.com/
Mar 12, 2014 | Office Equipment & Supplies
Amigo handicap scooter -- loosing distance with in use
you'll need new batteries plan on replacing them at 1-1/2 to 2 years
Oct 14, 2012 | Amigo Health & Beauty
Won`t play movie, skipping sound.
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shiney. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not applie to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laserhead and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
May 09, 2009 | Mintek MDP-1815 Portable DVD Player
Does not work always says check disc after loading
May 08, 2009 | Zenith DVP615 Portable DVD Player
Plz help refrigerator not working properly after transporting it
time to get a new defrost timer or heater element the ice is causing most of the issues. if the freezer is staying cold then there is a fan that blows the cold air into the fridge side that could be out.
Apr 27, 2009 | Refrigerators
My dvd player model dvp615 doesn´t play dvd discs. Only play cd´s and mp3 cd´s. Could any help me to get a solution to this problem? Tank you Eddie
You need to try to clean the laser head and the transport. To do this you will need cotton swabs, isopropyl alcohol and small cans of lithium grease and compressed air.. Open the up the compartment that the dvd discs are placed. In the center of the compartment you will find the spindle and a laser transport. In the transport you will see the laser head. Take a cotton swab and put a small amount of alcohol on the tip. Rub the tip of swab gently across the head of the laser. Do this until the head look bright and shines. Use the other end of the swab to dry the excess moisture off the laser head. Take another swab and use a small amount of alcohol on the tip and go around the transport device cleaning the dust and dirt from it. Use a small can of compressed air to blow away any dust and dirt in the compartment. Once the laser head is cleaned and the transport is cleared of dust and dirt, Move the transport to the outer most point and bring it back in to its closest point. Do this several times. Do not apply to much pressure while doing it.If you find ruff and uneven action. Clean the areas of problem and return the transport action to smooth and easy operation. If still not smooth and easy. Take another cotton swab and use some lithium grease in very small amounts to lubricate the transport rails. Again move the transport back and forth to lubricate the laser transport. This should return the transport to normal action. Now play a music cd to calibrate the laser head . Let the cd play through a couple of times. After doing this you can now try a dvd disc and it should play normally. If it still does not play correctly, check the spindel to see if it is loose. If this is the case use a drop of super glue to tighten it up. Let it dry completely and try the disc again. It should work correctly. If you are still having a problem.You either have a problem with the laser itself or the drive motor. The drive motor problem would usually be noticed on the playing of the cd. The laser head and the motor can be replaced if this is the problem. You can find more information on how to do these repairs on you tube. Put cleaning and repairing portable dvd players in the search engine and it will bring up videos on how people have done these types of repairs. I hope this information will help you with your problem.
Mar 16, 2009 | Zenith DVP615 Portable DVD Player
Tape Transport
Be sure that whoever is replacing the elevator assembly ( transport module ) is putting in a NEW part and not an old part that is still works.
I would start doing this repair yourself... there are only:
4 screws
and
2 cables: one that powers the cassette load\unload motor
and the other is the tape sensors cable
once you pull the cover
they are very small phillips head screws: you NEED a very good, long, small Magnetic tip screwdriver.
Tthere is a manual screw drive near the loader \ unloader motor: it has a Red plastic phillips head drive screw.
This manually moves the Loader assy in and out: you will need to move it to uncover the two screws that are near the front of the machine.
when you find these screws: its a good idea to mark them with a red Sharpie, for easy finding next time..
If the machine is getting heavy use, then 5 months may not be that bad, if the machine is babied should last alot longer.
either way you can get a handle on the situation and save youself some money by bringing this particular service 'In House'
I did this fix last week on this unit.
it took me 15 minutes.
Ed
Nov 13, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Canon BubbleJet i560 InkJet Printer Logo
167 people viewed this question
Clive
Clive
old marine
old marine
