Question about KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher
////////////////////my kitchenaid dishwasher lights are flashing
My kitchenaid dishwasher model kudpo2frsso built in
lights are flashing normal and cancel
I shut off the breaker for 20 minutes pressed Normal heat dry X2
Then cancel x2 but to no avail. Any suggestions its the day before Thanksgiving Help!
  • 4 more comments
  • jklerner292 Nov 27, 2008
    my kitchenaid dishwasher model kudpo2frsso built in
    Then cancel x2 but to no avail. Any suggestions its the day before Thanksgiving..
    The dishwasher is not working at all the NOrmal Light and the Cancel light flash simutaneously.
    I already took things off that breaker. Can you reset the dishwasher somehow. I donot think it is the load i have had the dishwasher with no additional appliances for 2 years.
  • rbaker06 Dec 19, 2008
    mine is doing exactly the same thing, the Normal light and Cancel lights blink. DW is 3 years old and on its own breaker. Manual says nothing, I think it is service call time.
  • sebbyz6 Dec 21, 2008
    Same problem as flashing lights, has replacment of the panel worked to solve the problem.
  • Anonymous Mar 30, 2014
    kitchenaid dishwasher s/n 8270219 shuts off 1 minute after it starts
    Sergeant:
    Champion:
  • 251 Answers
Yes u need to call an electrican u have to much load on that side of the house
Posted on Nov 27, 2008
  • Shaun Plencner
    Shaun Plencner Nov 27, 2008
    Timer or selector switch
    Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
    Genius:
  • 1,550 Answers
If the Pots & Pans cycle light is flashing the key pad has a stuck button on it & will need to be replaced in order to get your dishwasher work again .
Posted on Nov 26, 2008
    President:
  • 2,712 Answers
Can you explain the issue in detail - is your dishwasher not working at all, or the buttons continue to be lit up, etc?
First and foremost, check the dooe switch to see if it is functioning properly.
  • Swilin Sampson
    Swilin Sampson Nov 27, 2008
    There is no way to reset the dishwasher apart from completely unplugging it from power source for about an hour. If the issue still persists, then there is most likely an issue with the internal circuitry. A replacement of the keypad control should resolve the issue.
  • 535 Answers
Chk the switch of ckt bord or chak the pannel of ur dishwasher
My Kitchenaid dishwasher model KUDS01FLSS6 stopped working. It won't run and the clean light is flashing at me.
you need to clean your dishwasher, leftover soap, food particles, usually cause sensors to be dirty hence it thinks there's some problem with your machine.
Feb 02, 2011 | KitchenAid 24 in. KUDS01FLSS Built-In...
The clean light will not stop blinking so the normal cycle will not run
From another link, clean light flashes 7 times. Turn off breaker for dishwasher, wait 5 minutes, turn back on. with dishwasher door open, push high temp, energy save dry, high temp, energy save dry, then close door, open door, press cancel and then Normal wash cycle. Dishwasher Starts!!!!!! Save myself several hundred $. Was about to buy new one from Lowes!!!!!! Thanks everyone!
Feb 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light flashing
reset it by hiting heat dry normal heat dry nornal that should reset you dishwasher
Aug 19, 2010 | KitchenAid 24 in. KUDP02CR Built-in...
Kitchenaid normal cycle light and cancel light both blinking. Dishwasher wont start
Thanks for writing to Fixya.com.
Please do the following to reset the washer. Normally the clean light sometimes flashes and just needs to be reset. To do so hit the keys in the following order. <Heated Dry> <Normal Wash> <Heated Dry> <Normal Wash> <Cancel>.
The dishwasher will go through a cancel cycle (drain the tub) and will then let you start it up again
Thanks for contacting Fixya and please accept the solution if it has helped you.
May 28, 2010 | KitchenAid 24 in. KUDI01DL - Multiple...
Clean light keeps flashing and will not start.
Try the follow key dance, all within 5 seconds push:
HEATED DRY --- NORMAL ---- HEATED DRY --- NORMAL
wait for about 2 minutes then hit cancel
May 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid KUDS25SH
Hold the button down until it beeps and the light goes off. Eric
Sep 03, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
The light on the buttons that say cancel and normal are flashing and the dishwasher won't turn on.
first thing to try is to disconnect power for 15 minutes and then try again if goes into default again take off bottom panel and behind the black trim will be a tech sheet see if it gives yousome diagonostics sounds like it may be the computer if the power off and on doesnt make it work,.
May 31, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
I cant get my dishwasher to turn on, i press the normal cycle and the light flashes 4or5 times and nothing happens, i've unplugged it and tried all of the cycles nothing works
Count the exact number of flashes prior to the pause - this is the error code necessary to diagnose the problem. What is the model number also?
May 13, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid 24 in. KUDS01FLBL Built-in Dishwasher Logo
887 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
