Question about Garmin nuvi 200W GPS Receiver
Garmin nuvi 200 wont calibrate
My Garmin nuvi 200 is not calibrated and i CAN NOT HIT THE BOTTOM BUTTON IN ORDER TO GET TO THE SCREEN THAT LETS ME CALIBRATE AGAIN. aNY IDEAS? I also have a "new" (refurbished) Garmin N?vi 200. Mine is not as bad as yours, but the touchscreen needs to be calibrated. On the alphabet keyboard I can press the center of the 'B' button, and it will still register as an 'A'. All of they keys are about a 1/4" too far to the right. Any ideas hot to recalibrate this screen? Thanks!
  • fixyabread Nov 26, 2008
    HA!
    I just solved my own problem! (and maybe yours too??)
    Hooray for google!
    I found the answer here:http://www.gpsreview.net/forums/viewtopi...
    "72 Troubleshooting - Screen
    If the touch screen is not responding to your taps properly, calibrate the screen.
    Turn the Nuvi off. Then, slide and hold the Power button to the left for about 30 seconds."
    The next screen that comes up should be the calibration screen, telling you to press the dots on the crosshairs.
    I recommend using your finger, just as you would in your vehicle. I thought I could be more precise using a stylus when I first got the device and that is what caused the problem in the first place.
    Live & Learn!
4 Suggested Answers
sharcnet
  • 2130 Answers
SOURCE: My touchscreen on my Garmin nuvi 200 is messed up.
Yes, please see this link:
http://www.sharc.net/discus/messages/6/77.html?1236709210
If that doesn't work, the screen will need to be replaced.
- Jim
Posted on Aug 12, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin 650 will not calibrate.
Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Mar 04, 2010
SOURCE: garmin nuvi 200 wont calibrate
Yup, same problem. All it took was holding the power button to the left for about 30 seconds and the calibration screen came up. Problem solved!
Posted on Aug 14, 2010
How do you calibrate Nuvi 40LM when the calibration is so badly off?
Turn off the Nuvi. Place your finger on the upper left-hand corner of the screen and then push down on the power button to turn the unit on. Release the power button when the Garmin logo appears. Continue to press on the upper left-hand corner of the screen until you see the calibration screen.
Aug 17, 2016 | Garmin Nuvi40lm Nuvi 40lm Lower 48 Gps...
How to calibrate garmin Nuvi 2597LMT touch screen
try poweing it on while holding the upper left corner.
Jul 11, 2014 | Garmin GPS
No signal how do I fix it
You have not said what model garmin nuvi ?
The touchscreen on a Garmin nuvi GPS usually loses sensitivity or stops responding if it's lost calibration.
This usually happens after prolonged usage.
Touchscreen problems are also caused by dirt, smudges and improper care.
If your Garmin nuvi's screen isn't performing as expected, Garmin provides solutions and tips to not only improve the device's performance, but prevent premature wear and tear.
Calibrating the Screen
If the Garmin nuvi's touchscreen isn't working, you need to calibrate the screen.
Calibration resets and repositions the screen for optimal performance without deleting saved settings.
Before calibrating the screen, press and hold the "Power" button to turn off the device.
Pressing and holding the "Power" button again for about 30 seconds automatically displays the calibration screen.
Pressing the dot on the white screen calibrates the touchscreen automatically.
Updating Software.
If The Garmin nuvi's touchscreen is still unresponsive, updating the device's firmware to the latest version can solve operating system problems that lead to touchscreen problems.
Before updating the device's firmware, connect the GPS to the computer using the USB cable. When the computer detects the GPS, the "AutoPlay" menu appears on the screen.
Tapping the arrow on the menu automatically opens the "myGarmin Agent" download page.
From there, follow the prompts to update your Garmin nuvi's software quickly and safely.
Cleaning. In some cases, the Garmin nuvi's touchscreen won't respond to touch if the screen is dirty. Touchscreens are sensitive to dirt and smudges that decrease sensitivity.
If the screen is dirty, cleaning it with a soft, clean, lint-free cloth improves performance.
If the screen is severely dirty, using water, isopropyl alcohol or eyeglass cleaner removes tough stains.
To avoid damaging the screen, apply liquid to a cloth instead of directly to the touchscreen before cleaning it.
Tips.
Refer to your Garmin nuvi's maintenance and storage information found on the device's manual prevents premature wear and tear.
If the screen stopped working after prolonged exposure to extreme temperatures or water, the device's hardware is most likely damaged.
In such a case, you need to contact Garmin for additional troubleshooting and possible repairs.
Attempting to disassemble and repair the GPS yourself only increases the risk of damaging the unit even further.
also it could be a battery problem if the nuvi is not getting power ?
May 08, 2013 | GPS
Garmin nuvi 1200 wont let me type the right letters
Try recalibrating the touchscreen. The procedure can be found here:
http://www.sharc.net/discus/messages/6/77.html?1315261162
Press each dot to recalibrate the screen.
Once completed the Nuvi will display Calibration Complete
Feb 28, 2013 | Garmin nuvi 1200 Car GPS Receiver
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
Garmin nuvi 1350:touch screen calibration
Hold your finger on the top left corner of the screen while turning it on. Release the power button when you see the Garmin logo pop up but keep your finger on the top left corner until the white calibration screen shows.
Apr 09, 2010 | Garmin nuvi 1350 Car GPS Receiver
I think I just solved this!
(I had the same problem.)
Hooray for google!
I found the answer here: http://www.gpsreview.net/forums/viewtopic.php?t=4999
"72 Troubleshooting - Screen:
After you slide, and hold, the power switch to the left (ON position) for 20-30 seconds, the next screen that comes up should be the calibration screen, telling you to press the dots on the crosshairs.
I recommend using your finger to press the dots, just as you would in your vehicle. I thought I could be more precise using a stylus when I first got the device, but apparently that is what caused the problem in the first place.
Live & Learn!
FWIW -- I have the Garmin Nuvi 200 (not 200W).
I don't know why this problem is listed under 76Cx.
Oct 09, 2007 | Garmin GPSMAP 76Cx GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
877 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
