Question about GE Americana A4425GDTWW Side by Side Refrigerator
My fridge is not make water
Everthing the water from the main source is work. but there is some thing i dont know. it might have something stuck in thw fillter and the wa water at the fornt is not come out when i press on the button. wat should i do. this is me Fridge names. General Electric Americana A4425GDTWW (25 cu. ft.) Side by Side Refrigerator
  • rsr31095 Jan 16, 2009
    I get water to the coupling right before it goes into the door. I get nothing from the the dispenser. How does the door seal come off so I can take the door panel off to check the water line in the door.
  • 390 Answers
I assume that you checked the water is coming out of the 1/4 inch copper /pvc piping that connects to the water line from the refrigerator' s water inlet pipe. In order for water & ice to come out 2 things have to be set correctly.
1. Make sure that a water filter is indeed installed and that it hasn't been there installed for more than 2 years as it could be clogged.
2. make sure that the small shut-off valve in the back of the fridge is turned on!
Good Luck!
Rich
Posted on Nov 26, 2008
How do I stop the water in my 2032
The only thing that comes to mind is the brew solenoid on the top of the machine. The gasket might be damaged or something is keeping it open.
May 18, 2014 | Fetco International CBS-2032 Coffee Maker
If i fillter my water befor the refrig water fillter refrig fillter life is
You didn't complete your sentence You wrote "water filter refrig life is" If you meant that the refrigerator life is or would be extended. If that is what you meant then the answer is no. Please post your question so that I can better advise you.
Mar 01, 2014 | Whirlpool Refrigerators
The a/c dont working only heater
If the compressor is running and one of the ac lines is cold, you probably have a blend door stuck or faulty in the HVAC box under the dash. The blend doors direct air thru the heater core and evaporator core as well as thru the vents.
Jul 27, 2012 | 2000 GMC Jimmy
I have a Samsung WF448AAP/XAA washer. I have had it for a year + and have never cleaned the filter on the bottom of the machine. Tech support told me to clean the filter. Dumb, I know, I just didn't...
There is most likely something stuck in the rubber hose between the drum and the pump, Unfortunately this is not easy to get to as it requires tilting the machine back and climbing underneath to remove the hose and check it. Make sure you disconnect the power before doing this.
May 08, 2017 | Samsung WF448AAP Front Load Washer
Water will not empty
your filter is blocked you have a fillter at the bottom right hand side take the flap down or if theres no flap its behind the kick plastic take off with care you then should see a black or white know you can twist make sure you have towels down as theres going to be a lot of water put a little bowl close to it and a bowl biger next to it that way you can empty it in the big bowl dont that the knob wight out do a bit by bit in till all water has stoped coming out thats it when you take it out look right in side you should have some thing in there...hope i have helped you please rate me
Oct 23, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Driving and then everthing shut down will not start like a dead battery
pull yourbattery and cheak the level of the acid. if low put in some water till full chargeit and put it back in and report back then.
Oct 08, 2009 | 2000 kawasaki VN 1500 Vulcan Classic...
I have a GE side by side GSS25JFMC. The freezer was left slightly open overnight. I noticed it this morning and closed it. When I came back, everthing was frozen up in the freezer so I removed panels and...
There is no reset on that model. I also don't think leaving the door open had anything to do with what happened. You will need to check both sides of the main control board located on the rear of refrigerator for burn marks or signs of heat damage. Part number WR55X10942
The main board does all the thinking on your refrigerator. Not many thing on that board that is not turned on or off. Unplug first and inspect board an let me know what you find. If board is OK then we will need to check the start relay and start capacitor down near the compressor. Thanks, Sea Breeze
Aug 20, 2009 | GE Refrigerators
GE Americana A4425GDTWW Side by Side Refrigerator Logo
178 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
