Question about HP Pavilion a1253w Notebook
No sound. System won't find driver. Also, an "unknown" device & a SM ??? will not load\work for the same reason. All this occured right after loading IMESH. Thanks
  • jeff sandy Feb 12, 2009
    Hi:
    Did you ever get this resolved? I'm having the same problem...
    Thanks
    President:
  • 2,692 Answers
The simples answer may be  to go back to the restore function for the date right before you installed IMESH, what ever that is.
Posted on Nov 26, 2008
Can't get driver loaded for Zeepad 7 9XN
Hi code 43 can occur if the device driver fails uninstall the driver ,& install a new driver .cheers
Nov 04, 2017 | ZEEPAD 7 inch Android 2.2 Tablet
Updates won't load on Samsung DP7003ab
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 02, 2013 | Samsung Dp700a3b-a01us Touch Desktop...
I have a Presario F500, it had sound but it seems like I deleted the sound and now it says "No Audio Output Device is Installed". PLEASE HELP. dANNY
Danny, please fallow these instructions to the letter and you will have your sound back up and running in no time.
First, disconnect all external devices from your unit, ie; flash cards, external hard drives, wireless devices, and any USB devices with the exception of keyboard and mouse.
Next, reboot your unit and allow to completely setup.
Next, lets go into your device manager and take a look.
If you see any red flag's, exclamation marks or the phrase unknown devices, please remove them and reboot your unit.
The reason we are removing any of the above is, the red flag's indicate a malfunction with the device, the yellow exclamation mark, shows at device seen but in direct conflict with another device.
The phrase " unknown device " shows a device that is trying to load, that windows does not recognize or have drivers for.
Either way, if you have removed all the explained above, you can now restart your unit, again without external devices.
Your unit should see whatever was removed and reload the correct drivers needed to have the device function properly.
Now that the unit has restarted and reloaded its drivers, you should have your sound and you can " one at a time " load your external devices.
If for any reason, you are to have a problems in the loading of devices, drop me a comment and I will help as I can.
Happy Holiday's
John
Nov 27, 2009 | HP Compaq Presario F500 F700 and G6000...
In my system the sound system is not working . the mother boar is p5gc-mx/1333 witch sound drive o loaded in the system
There could be more than a couple of reasons for this to occur:
1) Check that the external speaker mini-plug is connected to the back (of front) of your system.
2) Ensure the speakers work connecting them to another device, such as a portable CD player, or cassette player.
3) If the speakers work, then the cables are also Ok; then try the following, assuming your OS is Windows, of any flavour:
(In XP) Go to Control Panel and double click on System. Run the Device Manager utility and select your audio/multimedia card.
Right click on it and select "Uninstall".
Close all windows and restart your machine.
(Vista) Right click on Computer and select Manage. Next, select Device Manager.
Uninstall the audio card using procedure above. Restart your machine.
Windows should detect the audio card as though it's the first time it's been installed, and it will try to find the device drivers for it from a known drivers directory.
If the detection phase fails to find the drivers, then load the CD that came with your audio card and insert it on the tray, and point the utility to search on this CD.
You may need to browse up to the directory that actually contains the drivers (a folder usually named so). The way to find out when Windows has found the driver files is to notice that the Ok button is no longer grayed out.
Aug 15, 2009 | Computers & Internet
No drivers for sm bus controller & 2 unknown devices listed
http://downloads.emachines.com/emdriver.html?model=E4076
this is the link for your drivers. it is very important that you download the chipset driver utility and run it. the chipset driver utility should resolve your sm bus controller not showing up. make sure you restart the machine when it asks. this will insure that the o.s. and machine reset correctly and load the new drivers. if you have more issues drop me a line and we can get it fixed.
Good Luck!
Ruben
Jul 23, 2009 | Acer Aspire 5500 5570-2609 Laptop
My computer din't have sound.I already install Realtek HD Audio Driver but not solve the problem,still no sounds.I looked on to Control Panel-Audio&sound but there is no audio device at all.so who can...
Firstly, need to verify your unit uses a RealTek driver. Go to control panel, then system, then hardware, then device manager,
Look at the list and find sound, video and game controllers, click on + sign to expand, look for devices with ! marks, these are the ones with issues. They will either be unknown or state the wrong drivers are loaded. You can click on the device in question then right click to update drivers.
This will work only if you have the right drivers.
Jul 01, 2009 | Intel Computers & Internet
Aspire 4520 driver missing..!!~
if you can download driver easy https://drivereasy.en.softonic.com/download or put on a device like usb stick and put on the aspire it will find the missing drivers and you just down load and install them, don't use automatic as you will need to pay for this to be activated but to load them yours self its free. been using it for years now my self.
Dec 23, 2017 | Conexant chipset 56K V.92 PCI Data/Fax...
Pci card drivers
you would need to get all the drivers for your laptop from the IBM website and install all of them. If you cant find them or need further help please post back and let me know.
Apr 10, 2009 | IBM ThinkPad T60 Notebook
Aspire 4220 acer AMD sempron processor 3600+ sound driver
you have to reinstall the device drivers please check in your resorces cd which came with your laptop or please check there web sie to down load the drivers and install it and every thing will be fine
thanks
Jan 24, 2009 | Compaq Audio card Sound Card
HP Pavilion a1253w Notebook Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
