I have a convergance problem (red and blue are both offset). I tried going into the convergance menu, but the crosshairs won't move. Am I doing something wrong or do is the problem minor or severe?
-   the colors are mess up and it looks like 3-d need some help please to fix it
-   naltreche
Jul 29, 2008
-   The colors on both sides of screen showed up with line of 2 colors and picture had some colors on images now all I have is colors jumping all over my screen,no picture
-   Adman68
Jun 18, 2008
-   yes , I have the same problem with my Hitachi HD convergance problem ..just wandering how do i fix it....-   fernmed
Jun 15, 2008
-   GREEN AND PINK IMAGES OR HALOS ON SCREEN DOUBLE PRINTING ON TV 55" PHILLIPS -   Guest
Jun 12, 2008
-   Blue and red outline everything on screen. -   Guest
If your convergence setting will not adjust the picture you need to replace the Convergence amps. A repair shop will do this for $200-$300 depending on your area.
i had someone look at my tv that fixes them and what i had to do was replace the chips that were in their for about $120 for everything labor and all. because if the perfect focus wont work like mine then its probably the chips.
I found out why the crosshairs won't move. The replacement Sanyo convergence IC's was bad STK392-150. I had another spare generic STK392-150, and it worked for half of the beams. Awaiting another STK392-150 to arrive.
Was this helpful?
Yes
No
Solution #7
posted on Jun 20, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
change your convergence cartridges and check your resistor specially the fusible ones and all low values.. a small change in value can prevent any automatic convergence circuits from operating
cannot get tv to display picture when connected to satelite ...I disconnected our old tv which was...
(More)
cannot get tv to display picture when connected to satelite ...I disconnected our old tv which was working fine recoonected satelite cable to this tv and nothing happens..just static noise from the speakers
I have a 55" rear projection Mitsubishi (VS-55609) and the blue looks offset to the right. Is...
(More)
I have a 55" rear projection Mitsubishi (VS-55609) and the blue looks offset to the right. Is this a convergence problem? If so do you replace one or both of the STK393-110 and other recommended hardware? Do you have a kit that you sell with instructions? I have a soldering gun, solder extractor and other tools. Thanks, Tim
i need to replace the exterior plexi screen on my mitsubishi vs-55609. the unit works great, but the...
(More)
i need to replace the exterior plexi screen on my mitsubishi vs-55609. the unit works great, but the plexi was badly gouged. i have removed it and want to replace it. where can i get this part for a quick and cheap do it yourself fix? thanks, roy somers
Our Mitsubishi 60607 is loosing its color. When you turn it on it begins blacked out then slowly...
(More)
Our Mitsubishi 60607 is loosing its color. When you turn it on it begins blacked out then slowly warms up to where you can finally see the picture. Although it looks likes its dimming out. This TV is rear projection. Can this be fixed?
I have 55pp9401 with red ghost next to subject and then green ghost to the right of the red ones like the whole thing is not lined up properly. The set was not moved or tampered with, just happened while I was cruising chanels
After the magic focus button is reset, the number 4 shows up. The colors on the tv are a blue stripe across the top followed by a yellow stripe, lettering is out of focus showing double images, lots of blue and yellow smeared it appears. Please help get my tv realigned.This is a Hitcahi 53 inch projection tv.
I have a yellow stripe at the top going across the tv and the a bright blue stripe under it. The words on the tv also have a double image and use these blue and yellow colors. the stripes are not solid stripes, but curves and also miss small sections from being a complete stripe. Please help me figure out how to fix this, my warranty just ran out, of course. Thanks
Comment by Guest, posted on Dec 30, 2007
the colors wouldn'talign on the screen and even doing the perfect focus it didn't help so i had the chips replaced in it for 120$ at my house and now the tv works just fine. which is great for me because somebody just gave it to me because they couldn't figure out what was wrong with it, so i got the tv for about 120$.
Also replaced STK392 150's and the digital convergence won't move according to remote control. When I press the directional keys on the remote the screen just flashes instead of moving the color lines.
