Question about Kenwood KDC-135 CD Player
New KDC-135 has Power but Faceplate won't light up
I recently bought a Kenwood KDC-135 for my '97 nissan pickup. After installation the unit is receiving power because I can see the red LED blinking. Attaching the faceplate, and pressing the power button, however, leaves me a blank, dark screen. At first I was worried that, for whatever reason, the faceplate wasn't receiving power, but I can hear the unit whirr and click when I press the CD eject button on the faceplate, so there must be some connection there.
Friends and co-workers have suggested I have a bad ground, or not enough voltage through the power wire. I have no way to test either really. One co-worker even suggested direct wiring the power and ground to the battery. The ground I hooked up to the chassis in the same place as the factory radio. The KDC-135 has two power wires. Red and Yellow. Could either of these be the issue, not supplying enough power? Could it be the connections I used? I used self-splicing connectors, the type that you feed the wires from both sides and pinch together the metal bar that bites down on both wires in the middle. Any help would be greatly appreciated. I'm tired of plugging earbuds from my portable cd player in my ears.
  • mickyfknd May 18, 2009
    i have the same problem!! any ides??
    Sergeant:
  • 324 Answers
You shold always twist the end of the wiring together and tape them never use connectors, remove the connectors and twist the wires driectly to each other and tape them wiht electrical tape, the connectors almost always can not deliver the proper voltage..
Did you make sure you have the yellow to a constant connect wire and the red to a turn on?if not this can cause the radio not to work......
you can test wich is wich by turning the key off and putting the yellow to the one you think it is and red to the one you think it is, if you have have it right you will hear the CD player make a click run sound...... if not you will not hear any thing.
Posted on Nov 26, 2008
    Problem Solver:
  • 12 Answers
Hi
The RED wire needs power when the ignition key is on aux or ign, also the yellow needs power permenantly for memory back up. You cant get more power than the 12 volts supplied by the battery
Posted on Jul 08, 2009
I have a Kenwood KDC 135 car stereo wont un mute.
behind the face plate there is a little recessed reset button. push it using the tip of a pen or similar. that will fully reset the radio to like it was when you bought it.
Some times head units hicup. this is how you reset it. In most error cases this solves the problem.
Dec 15, 2009 | Kenwood KDC-135 CD Player
How to install a kenwood kdc-135 car stereo
This is a link to Kenwood for your KDC-135 Owners Manual. Page 15 has the wiring diagram and pages 16 and 17 cover physically installing the unit.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-135.pdf
Nov 17, 2009 | Kenwood KDC-135 CD Player
Unit only has power for a few seconds
Yeah remove the unit from your car,
Go to car audio store and buy Kenwood receiver without the
fancy opening front.
Dec 17, 2008 | Kenwood eXcelon KDC-X879 CD Player
Kenwood excelon kdc-x815 display screen no power
recently bought a kenwood kdc-815 car radio from a swamp met. bought it with no security code need security code
Apr 08, 2008 | Kenwood KDC -X815
New KDC-135 won't turn on...
Hey Bandad, you will need 12 volts at the backup wire also. Try that and see how you go.
robotek
Apr 07, 2008 | Kenwood KDC-135 CD Player
KDC S3007
Hi bacbeats,
You nered to clean the contacts on the main unit and the faceplate, evidently you have contamination keeping the power from getting from the main head unit to the faceplate.
Nov 21, 2007 | Kenwood KDC-S3007
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Dead Kenwood KDC-128 CD Player Is there a "reset"
KENWOOD MADE TWO DIFFERENT EDITION FOR THIS AND SOME OTHER MODELS. YOUR WILL NEED TO CHECK THE SERIAL NUMBER AND YOU CAN CHECK WITH PACPARTS AT pacparts.com THEY WILL GET THE RIGHT ONE FOR YOU
Dec 13, 2006 | Kenwood KDC-128 CD Player
Kenwood KDC-135 CD Player Logo
762 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
