Question about Hobart A200 Stand Mixer
I have an A200 mixer ,the motor works antd turn the gears but witth charge not turn I think is the clutch,how can I Replace it
  • rodrigo4393 Nov 28, 2008
    I need replace the clutch and need help
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Below is an image of a brass clutch worm gear for the old style spring type assembly of an A 200.
While this would be for the newer versions of this machines.
They are available from this page as well as assembly, gearing, exploded diagrams that might be of additional help to you.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 28, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 728 Answers
There should be a overload/reset button that sits on the back of the mixer's pedestal. If you push it and it clicks, then it has been tripped and that should fix the problem. If that does not, or you do not have the reset button, you may have to take it to a repairman to get it safely and correctly repaired. It should not be expensive.
Posted on Nov 27, 2008
  • 4,806 Answers
Check to see if the timer is at "0" from the last time it was used
  • 4 more comments
  • Lee Hodgson
    Lee Hodgson Nov 27, 2008
    is there a bowl cage on the mixer? if not bypass the timer and see if it starts
  • Lee Hodgson
    Where you see the beater shaft there is a nut next to it make sure that
    nut is not to loose or tight.was the mixer overloaded at any point?if
    this doesnt help you youll have to get into the transmission
  • Lee Hodgson
    have you got the operators manual?
  • Lee Hodgson
    here is the operator and maintenance manual:
    https://feg.hobartcorp.com/resourcecente...
    if you need anything else just post back
    kind regards
  • Lee Hodgson
    Hobart also sell replacement parts direct to end users, just visit their service website at www.hobartservice.com
    - and click on the "Locate on Office" link. You'll be able to contact
    your local Service branch to purchase a replacement part OR to have
    them take a look at the unit and provide a quote on fixing it.
  • Lee Hodgson
    Lee Hodgson Nov 28, 2008
    here is a link to all the manuals you need to repair your mixer:
    best regards
Hobart A200 mixer. 1st gear has no torque, I can stop it by hand. I found the key sheared on the low speed gear(flat gear, beveled gear part wasn't sheared). I replaced the key, & it sheared it again...
Ed, if you continue to do it yourself, the end result will be tossing good money out. Have a professional check the system and save the unit from permanent damage. Chipping parts of a gear off means a serious resistance force or action has occurred. One force is slowing down as the other is speeding up. Gear alignment can be moved off center, or a sudden application (sudden stop or start) can damage the least resistant parts. For example, when a hook turns within the mixing chamber and the resistance of the content is too great on the turning shaft and gears, which ever part is weakest will break. Complicated I guess.
Mar 01, 2014 | Hobart A200 Stand Mixer
Hobart 20QT guessing old a200 motor runs fine removed top cover to see but gears not working and mixer does not spin Any diagnosis Help greatly appreciated
The first vertical shaft has a brass gear that runs off the rotor. The ancient models had a spring loaded slip clutch built onto the gear. Upgrade it with a worm shaft kit which gives you a complete new shaft and fixed gears. I think it includes the upper and lower bearings. Maybe replace the grease if it has not been done. Or look for a sheared key on the worm shaft.
Feb 19, 2014 | Food Mixers
Hobart Mixer A200 buzzing. The motor not moving
Have you try to run the motor without engaing of worm gears? The worm gear 15T assembly need to remove in order for motor to run freely. check worm gear attach to motor shaft for any damaging.
Mar 24, 2010 | Hobart A200 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Hobart A200
When you say lag and catch up. This may not be a issue. I have seen this with dough and a spiral hooks on all sizes of Hobarts the hook and dough get in a position to push the hook forward and the drive gears catch back up the hook. in fist gear on the 20 quart this is common for sure. but its normal. if you have a real slip from a sheared key it will not take long to where you can hold the planetary shaft with your hand and stop it. another slip that might be possible is if your mixer has the first generation worm shaft gear Assembly. when it is worn out it will slip you. this is the shaft that drives directly off the motor. you can tell if it's first Gen by it has a large spring on it. the tow later versions are all keyed to the shaft no chance to slip unless a key shears.
Michael
Oct 24, 2008 | Hobart A200 Stand Mixer
Mixers eating brass gear driven by motor pinon
Thats called a sacraficial gear because its brass which is a soft metal.This gear takes most of the strain but i think either a spacer is missing or the gears arent meshing correctly.The transmission assembly the shaft next to it make sure all the spacers/washers are there.Goto hobartcorp.com you will find an exploded parts breakdown.
Aug 29, 2008 | Hobart A200 Stand Mixer
Manual for Hobart Mixer A200
You can go to hobartcorp.com and register for free then you can print or download a parts
manual to help you to do repair. Hobart provide service manual to their technician only.
May 05, 2008 | Hobart A200 Stand Mixer
Hobart A200
amy, depending on how old your mixer is there are 2 types of clutches for 1st gear.these could be your problems--a key is sheared on the shaft--shaft/gear is broken.the bottom part of the mixer where you put on the attachements is called the planetary,does it look like it has moved down?you could tell if the dough hook,wire whip,ect,ect is hitting the bottom of the bowl.if this is the case its just simply tightening the 2 nuts next to the beater shaft.if this is not the case you would have to dissasemble the transmission.let me know.
Jan 11, 2008 | Hobart A200 Stand Mixer
Hobart A200 Stand Mixer Logo
Top Hobart Food Mixers Experts
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
