Click Ctrl+Alt+Delto get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hitthe Del key while holding them.Once the task manager opens Clcik the Processes tab then click the Image NameColumn heading on the left to get them in alphabetical order. Scroll downand look for explorer.exe. If you see it click it to highlight it thenclick End Process.
Next, click the FILE tab at the very top left of the window and select New Task(RUN). When the Create New Task window opens type explorer.exe and pressok. Your start menu, task bar and desktop icons will start appearing andpopulating. if not that means a virus has hidden your files and folders.
SOURCE: Blank desktop on boot
is the laptop switched to the external vga connector, try pressing the FN (if there is one) and F3 at the same time to see does it cycle through the modes,
did you change your graphics driver/resolution or anything like that?
SOURCE: Icons don't appear
hello,
Lets try a few things....
start normally
SOURCE: desktop gone blank after installing avira
The cause of this problems is corrupted system files cause by the anti-virus or spyware... follow steps below for solutions.
Step 1: install the OS and install the spyware and anti-virus. set your spyware and anti-virus configuration to delete the files manually first if they detect a virus or spyware in your computer..
Step 2: Run the first scanned for your anti-virus and spyware.. after the scan is complete you will be ask by spyware and anti-virus what will you do in the detected viruses or spyware in your computer? but don't decide yet.. check the location of the files that is detected.. you must not delete any files detected in the "Windows Directory" mostly it is located at C:\Windows\, because it will cause your Operating System to corrupt if files is deleted in that section.. try ignoring or adding the files in exception in the anti-virus or spyware exception list (I recommended adding to exception list), and you may proceed with the others.. after complete scannng put the setting of your anti-virus and spyware to its default settings..
HOPE I CAN HELP
CLCTECH
SOURCE: cant start netbook acer zg8
usually means hard drive is bad if there's any data on this computer u HAVE to have leave it off and take it to a com repair shop or plug the hard drive in to another pc that works and see if you can copy any data off. youll probably need a ide to usb, sata to usb or an extra sata cable/connector on the mobo and power connection
SOURCE: Dell Inspiron M5030 frequently locks
I would make sure it is up to date asfar as Windows Updates are concerned, check the internal RAM, (Press F5 whilst booting and run the utility) and download the latest BIOS and drivers from Dell.com
Hope that helps.
