Question about Yamaha RX-V757 Receiver
Speakers Crackle after 5 minutes
I have had this unit for a year with no problems. Now after I it is on for 5 minutes the speakers begin to crackle and they get worse the longer the unit is on. I noticed that when I use Pure Direct the speakers dont crackle when listening to FM. If I switch to 2 Ch they start to crackle and any other option crackles. Same holds true when I play a DVD. Any Thoughts? Thanks George
techman
  • 3130 Answers
SOURCE: Not getting sound from right speaker
How do you have the audio hooked up from the TV set? If its s video or RCA plugs? If it is switch them around and see if it swaps channels that goes out . If it does then the output cable or the jack is bad. If your using an HDMI ir a scart cable. The cable or connections could be bad. Unplug it and reinsert it or while the units on mover it around and see if the audio comes back on.
Posted on Sep 22, 2006
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
SOURCE: crackling sound through speakers while watching dvd movie
Yamaha Rx-V361 Firmware Upgrade, A/V-Receiver/-Verstärker - HIFI-FORUM
Posted on Jun 18, 2008
SOURCE: DSP-A1 Power Off
All you have to do, check all your speaker terminal and tighten it
Posted on Sep 26, 2008
easyq
  • 144 Answers
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
Posted on Apr 17, 2009
Crackling
So if you bought enclosures that are premade AND had the speakers installed, you need to see if there is a cross over network installed in them
Apr 27, 2013 | Car Audio & Video
Speakers crackle after an hour
its over heating i had that with my old typhoons i would turn them off every hour for 5-10 minutes and turn the bass down a small amount hope it helps it can be a different problem with philips speakers though
Apr 08, 2012 | Audio Players & Recorders
My logitech s-120 speakers crackle very loudly sometimes. At first I thought it was the sound card in my old PC, but when I switched to a brand new Mac computer the problem continued, making me think the...
hi there,
The problem is actually from the speakers themselves. If it's not a year old you might want to bring it back to the store where you purchased it for a warranty repair or replacement.
Sadly the problem is inside the speaker and it could be a loose connection inside. If you're comfortable enough you can try to open the speakers and check inside for any loose wires which cause unstability of sound or for any loosed fittings from the magnet.
Hope this helps!
May 30, 2011 | Logitech S120 2 Speakers
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Dell studio 1737 speakers crackle and pop.
My best guess is, if they crackle with the speakers but not the headfones,  then replace the speakers. Must be a lose wire or something of that nature.
Jul 27, 2009 | Dell Studio 1737 Laptop
No sound coming out of speakers
A quick way to check your speakers is to put the contacts from a 9 volt battery to the positive and negative speaker wires (briefly). You should hear a crackle of some sort if the speakers are functioning. If there is no crackle, speakers are bad / if there is a crackle, your head unit must have a problem.
Jan 22, 2009 | Kenwood VR-509 Receiver
Speakers are crackling
This could be caused by one of your speaher wires being shorted out to ground, OR one of the speaker terminals in the doors or rear coming into contact with metal. If you remove the unit and test it with the speakers hooked directly to the back of the unit and they do not crackle, then the unit is fine. If they still crackle - then you either have two diferent sets of bad speakers, Or more than likely the outputs of the kenwood have been damaged by an improper installation in the past.
Jan 17, 2009 | Car Audio & Video
Bose 123 Home Theater speakers started crackle sound?
If the wires are bare on some parts and touch eachother that will most likely be the cause.
Aug 08, 2008 | Audio Players & Recorders
Yamaha RX-V757 Receiver Logo
83 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
CHP6PH1
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
