Question about Pioneer AVIC-F900BT Car GPS Receiver
Can I install new maps on Pioneer F900BT
Hi- I have a Pioneer F900BT installed & am not crazy about the mapset. Can I somehow install the maps/voices/etc. that Garmin uses?
  • dchandler200 Dec 28, 2008
    it wiil be nice if you could just load these maps into your computer and set destinations then unload with the sd card
  • nicholas geiman May 11, 2010
    you cant at least not yet
You can with pioneers new software available to download on their website, please find the link below, its called NavGate Feeds:
http://www.pioneer.co.uk/uk/content/support/support/upgrade/AVIC_F900BT_F700BT.html
you can view all the history from locations u've been, the roads you travelled down and also use Google maps to locate and plan new routes then upload back to the USB / SD Card and load them into the sat nav!
You can even manage the settings throught this application as well.
Hope this helps
Steve
Posted on Jan 27, 2009
Sat Nav stopped working Today informed that No Maps Found what can I do about this to get it working again--Please !!
If you have a Garmin model with Lifetime Maps or Lifetime Maps & Traffic (LM or LMT) you should go to garmin.com and download & install Garmin Express. Then, connect the GPS to the USB port and tell the program to check the GPS for updates. Otherwise, you may have to buy a mapset if it has somehow been deleted. Call your GPS maker's support before buying anything as maps are not usually returnable.
Apr 06, 2015 | GPS
Device number on Pioneer F900BT
you plug the SD card in the SDdrive and start up. then the device number will be shown.
link to manual
http://www.pioneer.eu/uk/products/archive/CNSD-300FM/media.html
Jun 15, 2012 | Pioneer AVIC-F900BT Car GPS Receiver
I have lost all UK & Europe mapping - except for major roads. This was initially built in to unit. Have SD card for Australia & New Zealand - this works fine.
The maps are stored in specific mapset files with *.img extension in the flash memory of the GPS unit. Each mapset file contains one or many maps in it. Beside that, the Garmin GPS navigator can also recognise and load up one additional mapset file from SD card residing in the "Garmin" folder and named as "gmapsupp.img".
Here are the mapset files supported by Garmin Nuvi 255w GPS navigator:
  • gmapbmap.img - the default base map
  • gmapprom.img - the primary mapset
  • gmapprom1.img - the secondary mapset
  • gmapoem.img - the OEM mapset that cannot be unselect by user (if it exist)
  • gmapsupp.img - the supplemental mapset which you can have one in the GPS flash memory and another one in the attached SD card.
Therefore, the Garmin Nuvi 255w GPS supports up to 6 mapset files, including 1 in SD card. Normally new maps installed by the user will be stored in gmapsupp.img.
You will lost all the maps in the previous mapset file if it is overwritten by a new file with same filename. If you want to keep the existing maps, ensure that you store the mapset file with an unused filename (from the 5 filenames above). Alternatively, you can make use of special tools to merge new maps into existing mapset file.
You can view the name of your base map in Tools > Settings > System > About > Basemap.
You can view the name of maps in the other mapset files in Tools > Settings > Map > Map Info. There, you can tell the GPS to load the map by checking on its name, or not to use the map by unchecking it.
In case there are 2 or more non-overlaping maps available for the same location, the map with the highest priority number (defined in the map itself) will be used by the GPS.
Note that certain map which are locked by vendor need a 25 bytes unlock key stored in a *.unl file in the same folder and with the same name as the mapset file where the locked map is stored in.
You might probably also interested to read:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 13, 2011 | Garmin nuvi 255W GPS Receiver
I have an avic f900. a number of new roads have
http://www.pioneer.eu/eur/products/25/38/301/CNSD-100FM/index.html
Map and Operating Software Update for the AVIC-F700BT and AVIC-F900BT (2009)
Dec 21, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Avic f900bt always on mute but key sounds and navigation not mute
You have to isolate yellow-black cabel. This cabel was in contact with earth and it was the reason, why you have Mute on the display.
Mar 26, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
I installed the Pioneer AVIC-F900BT and it has been
Windows CE is used to operate the Pioneer AVIC F series, which yours falls into. That version of Windows has not been patched or updated with the new day light savings times and since the player uses GPS to get the current time and Windows to make the time change for your zone then your time will not update until the orginal daylight savings time occurs. You can try to change the time to manual in the Pioneer settings, deal with the wrong time for just a lil bit longer until the original Daylight Savings Time takes place, or re-search an update and way to update the players OS which is Windows CE. Hope this helps :)
Mar 10, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
HTC diamond phonebook to Pioneer F900BT
send the vcard to a bluetouth device.
it will then send that one contact over.
if you then press ok on the avic, it will try to sync the entire phonebook (up to 400 items)
Greets,
xxhunter
Feb 15, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Powering on
Please check if the power adapter is giving voltage output. You can try using a different power adapter.
Oct 08, 2008 | Pioneer AVIC-F900BT Car GPS Receiver
Downloading mapsets
Every time you download it wipes the entire memory card. You have to select all the maps you want stored on the card each time you add a new map. To keep from selecting all the maps everytime you want to download you can save the file in your mapsource software then just add or delete maps from your original map list.
All the mapsets that are installed in your PC should appear in the menu bar on a dropdown list. If you click on it you should see "bluechart" city navigator" etc, if you installed them correctly.
Choose one of the map sets, such as bluechart, from the dropdown list and all the maps from that set should appear on the screen.
As you select individual maps from the map set they will be loaded onto a maplist wich should appear under a tab on the left side of your computer screen.
Then go back to the menu bar and pick your next mapset, such as city navigator. A new map set will appear on the screen but the maps you selected from the previous set will still be on the map list on the left side of the screen.
I hope this helps. Please reply if you have questions about my response.
Feb 24, 2008 | Garmin GPSMAP 276C GPS Receiver
Pioneer AVIC-F900BT Car GPS Receiver Logo
3,243 people viewed this question
Top Pioneer GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
