Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Won't work after charging
I was charging my mp3 player, and now it won't work. All it does is show Scandisc on the screen
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
After charging,the screen says philips,and wont do anything else
Hi Cheryl, The link below is a youtube page full of videos showing how to turn on your mp3 player and unfreeze it.........CHEERS..
how to fix mp3 player that won turn on YouTube
Apr 24, 2016 | Philips GOGEAR Audio Players & Recorders
My Go gear vibe 4gb MP3 battery is flat and won't recharge.
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Apr 03, 2012 | Philips GOGEAR SA6045 MP3 Player
Hi I just recently charged up my mp3 player after a long time it's charged but lock screen won't come off I hit the reset still no success
Hello if you see light the back light turned on and see nothing on the screen that mean the frame-wire is damaged and you need to buy new mp3. Or maybe the battery is not working change it as soon as possible and explain to the shop what is the problem. Please rate my comment
Nov 20, 2011 | Samsung Napster YP-910 MP3 Player
My onxy mp3 player won't charge despite being plugged into my USB port for hours
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Jul 13, 2011 | Mach Speed TRIO Onyx MP3 Player
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
Won`t charge
Try and find a camera lead with the same head and one that plugs into the wall. It might work. Works for me.
Apr 24, 2009 | Audio Players & Recorders
Sansa Fuze MP3
Disconnect the player, press and hold the power button till the player resets. Change the USB mode to MTP, then turn the player off and reconnect to computer. The computer should now recognize the player.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 05, 2009 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
26 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
