Question about Sony Handycam DCR-TRV460 Digital Camcorder
Cannot load tape
When I open the tape "hatch" -- the internal mechanism does not automatically open up to receive the tape. I've tried it both with the power on and the power off. I'm borrowing this camera and was given a crash course on it today.
Problem resolved. I apparently did not have the "hatch" door open completely. I tried it again, heard a click and the mechanism lifted to accept the tape.
Posted on Nov 26, 2008
VHS tape will not eject and unit shuts down
It's not loading correctly. You need to open the cover (unplug first) and get familiar with the loading mechanism. You can get the tape out by rotating the loading motor wheel.
Mar 22, 2015 | Magnavox ZV427MG9 DVD Recorder/ VCR
Hi, I've got a 2007 ford expedition xlt and I can
readjust the locking mechanism as it sounds as it is not quite locked
Jan 12, 2013 | Cars & Trucks
Chevy Tracker Rear Hatch Lock
Remove the inner rear hatch skin, and operate the hatch manually to release it.
Test the locking mechanism again, and check for power.
Nov 12, 2012 | 2001 Chevrolet Tracker
Tapes don't load
Perhaps some physical damge to either the main mechanism or loading/carriage mechanism if you can't get a tape inside the unit. The power shut off is an automatic response, when the operation becomes comprimised.
Jun 06, 2012 | Panasonic AG-DV2500 DV/Mini DV VCR
Cannot get tape to eject
It could be a couple of different issues. These things could help.
(1) Power OFF the camera, remove battery then replace the battery, power up the cam and try to eject tape again. Nothing? try...
(2) Gently press inward on the tape cover with both thumbs a few times. Then, while pressing gently inward with one hand, press the release/eject-tape function until you hear a click or release sound. Then, if it doesn't open automatically, gently "help" open the hatch.
If it remains stuck, after follwing these steps a few times it would be my guess that perhaps the camera has been dropped in a way that jammed the mechanism controlling the eject function.
TIPS that may prevent having eject problems: When loading tape, be sure to insert the tape correctly and slowly, makeing sure the tape is placed properly. Gently press on the specific location indicated to close the tape holder, and wait for the tape to "seat" properly before closing any other part of the tape cover or hatch mechanism. Taking a few extra seconds when loading the tape can save extended frustration later.
May 16, 2011 | Samsung SC-D363 Mini DV Digital Camcorder
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
Loaded tape into Samsung VP-L700U 8mm and received 'Emergency Eject' message. Tape now chewed. Repeated & ruined several new & used tapes, including cleaner tape. Camcorder was working a half...
Internal mounting screws for the tape chassis may have come loose and can no longer hold the tape in the correct position. You will need to disassemble the camcorder to access the tape mechanism.
Nov 15, 2017 | Samsung VP-L700U Camcorder
My rear hatch will not open no matter what I do, remote, dash button or key, neither works. I checked te fuses and they are all good. What could be the problem? It worked and then I locked the doors with...
I just repaired a 2002 Aztek with a non working hatch. It was bad solonoid motors that were not releasing the latches.it is a fairly hard job to access the latches to release the hatch so you can get to the solonoids. You have toy crawl into the back of the vehicle and remove the bolts that hold the latch hooks. Once you have done this the glass top of the hatch will open. you can then use a screwdriver to reach down through the internal part of the latch and release it so you can access the bolts to disasemble the hatch to get to the solonoid motors. This is not a job a novice mechanic should atempt.It should be done by an experienced mechanic with the proper tools.
May 13, 2009 | 2001 Pontiac Aztek
Tape Ejects after little time
Yeah this isnt caused by the Tape I have had an issue way back with my tape driver as well and it was an internal mechanical malfunction, the gears that hold the tape in position push the tape internally on its gears and read / copy data but when it no longer is aligned with the gears it just keeps spinnning and eventually ejects automatically. Unfortunately I didnt open it up and fix but I was able to send it back to the Manufacturer and mine had 5 year warranty and they fixed it.Im new on here so if my solution helped you please give some good feedback on my answer thank you
Aug 11, 2008 | Benchmark DLT1 DLT Tape Drive
Tape will not retract
Sounds like the carrage is out of time with the deck. Either that or the mode switch (the switch that senses the location of all the gears on the deck) is in need of an internal cleaning. When the contact pads on the mode switch get a little corroded it will confuse the microprocessor that controls loading and it will not know where the gears really are. Good luck.
Mar 30, 2006 | JVC GR-D250 Mini DV Digital Camcorder
Sony Handycam DCR-TRV460 Digital Camcorder Logo
134 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
