Question about Keurig B100 Coffee Maker
Drawer locks very little water comes out
We descaled our b100 and decided to install a charcoal filter for flavor. After installing the filter the drawer locks up and virtually no water comes out.
If you do not hear a buzzing sound through most of the brew AND dispense cycle, then one of the pumps may not be running. the one on the left inflates the bladder that punctures the KCup, the pump on the right puts pressure in the lower resevoir which causes the coffe to siphon up and out the unit. My boot was damaged, but agree with other post that the boot is not as functional as it appears. But both pumps are essential. looking now to locate the pump online.
Posted on Aug 27, 2007
    Problem Solver:
  • 13 Answers
In the water tank you have 2 sillicon tube one of them is stretch at maximum and usaly strech in 2. cut the part split and connect it again. the probleme is because the silicon left is propryety when is strech in very hot water. the best way to slove this problem is to find about 1 in of silicon tube of 1/4 or 3/16 iner and put the new parts of tube directly on the bafle and put the original tube in the new on. it just make a link betwen the bafle and the original tube. put teflon tape on the fitting of the bafle to avoid of the new tube spout out from the fitting.//// but take care and other touble can cause this the pump can be jam because the one way valve on the side of the brewer jam open because is to teith in in is body. check all is thing .if you need somthing eles y will comme back on the site soon :0)
Posted on Jun 11, 2007
I have a water tank behind the top drawer of my LG. Itseems to be empty I have checked the supply to the fridge and it is fine. I removed the filter and pressed the lever, water comes out. put filter
Sounds like a problem with filter. Was it having problems before installing new filter. Filter may be in backwards. I recommend reinstalling the filter
Dec 10, 2014 | Refrigerators
In the water pan, do you just add water or can you put some wood chips with the water? i want to smoke a boston ****. should I put it in fooil or cook unwrappped?
No, the water pan is just for water. The pre-soaked wood chips go in the charcoal bowl on top of the heated charcoal. Putting the wood chips in the water bowl with water in it, would serve no purpose as far as adding a smokey flavor is concerned. If you desire a smokey flavor, do not wrap the **** in anything.
In case you have misplaced your owner's Manual, I have included a link to it that you can download and print for future reference. http://images.brinkmann.net/docs/pdf/810-5301-C.pdf
I hope this helps you, to further your enjoyment of using a smoker. Thanks for choosing FixYa.
Jul 25, 2011 | Brinkmann Smoke 'n Grill Double-Grill...
Was given a brinkmann gourmet charcoal smoker/no manuals
Sure...the smoker top and middle lift off. There is a pan that goes over the charcoal pit. The pan is used to create moist heat. It will produce steam while you cook. I recommend flavoring whatever fluid you put in the pan with fruit, fruit juice, or frozen concentrate, or wine, mixed with water. You can put your initial batch of charcoal in the bottom, (pit) and fire it up just as you would any charcoal grill. once the coals are ready, you can put the pan over them, put the middle section in, (with whatever meat you prefer), then finally the top. During cooking, to produce a smoky flavor, you can put water soaked hickory or misquete chips with the charcoal, it has a door for access. You can also add charcoal as needed to maintain the desired heat level thru the door. Remember, it takes longer to prepare food on the smoker, the key is low heat and longer cooking times. For example, I usually cook a boston **** at about 185 degrees for up to 12 hours. Bon Appetite!
Oct 05, 2009 | Brinkmann Gourmet Charcoal Smoker/Grill...
No water.
I resealed the checkvalve coming from the resevoir.The valve is cylindrical and has a two piece exterior from the factory.Sealed it with a little expoxyand works fine.
Sep 12, 2009 | Keurig B100 Coffee Maker
Stomach pain drinking from refrigerator water dispenser
Get a charcoal filter from home depot (about 50.00) and install behind refrig or in cabinet . Filter has replaceable cartridges like for charcoal , lime , calcium . Installs in supply line to refridg . Do not recommend the 11.00 filter installed in line , where you replace the whole filter . Get the replaceable cartridge type .
Jul 20, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
B100 putting out very little water, reservoir is full
bye descaling product for the coffee maker not vinegar put descaler in machine fill with water start leave it running for 10 seconds close it for 15 minute start it up again repeat untill empty after its empty fill it with water run it untill empty repeat again descaler is acid so you need to rinse very good try it out thanks pierre
Jan 11, 2009 | Keurig B100 Coffee Maker
B100 only dispensing 1tablespoon of water and drawer does not open
descaling with vinegar forget that you said after you decaled it it worst vinegar remove calcium in little chunks ckunks bloc everything use a special descaler it melt calcium just to prove you that im right you said you saw lime deposit if you use the descaler when the water come out no residue just water color change 1 part solution 1 part water put it in container start machine for few second stop leave it for 15 minute repeat untill empty that a hell of cleanup after dont forget to rinse that solution is very corosif cheers
Jan 22, 2008 | Keurig B100 Coffee Maker
Keurig B100 Coffee Maker Logo
124 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
