K8NF6G-VSTA
- 2 x DDR DIMM slots Take the guesswork out if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system hope it helps
- Supports DDR400 / 333 / 266 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
SOURCE: Buying RAM to my ASRock(845GV R5.0) Motherboard ?
it can support up to 2GB ram maximum FSB 533/400MHz,
Memory
Supported RAM Technology: SDRAM, DDR SDRAM
RAM ( Max ): 0 MB / 2 GB (max)
Supported RAM Speed: PC2100, PC1600, PC100, PC133
SOURCE: I have a motherboard asrock-k8nf6g-vsta,
the problem with those drivers is that YOU are an idiot. and idiots can't find the drivers on the official page....
SOURCE: I need drivers for audio and video integrated.
Here is the link for the drivers you need (select the operating system you are using):- http://www.asrock.com/MB/download.asp?Model=K8NF6G-VSTA
Testimonial: "Very fast. Thanks"
SOURCE: asrock k8nf6g-vsta motherboard will not power up
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive Test all leads that attach to your hard drive including electrical extensions,IDE,SATA the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
SOURCE: I need, ASrock K8NF6G-VSTA bus
Hello
Click here to download drivers from ASrock web site
Good Luck
hope this helps
