Question about HP Office Equipment & Supplies
We are trying to install the HP Deskjet D2500 series printer and get the spooler problem and cannot advance please advise
  • debroy
    debroy May 11, 2010
    what is the msg??
  • HP Master
  • 4,338 Answers
Verify that that the Print spooler service, and all the services that it depends on, are correctly installed and running.
  • Open the Services Management Console (click Start, Run and enter services.msc).
  • Double-click the Print spooler service to open its Properties window.
  • On the General tab, check that Startup type is Automatic.
  • Select the Dependencies tab.
  • Note all of the dependent services listed, then close the Print spooler Properties window.
  • Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try un- installing all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print spooler service dependencies other than the Remote Procedure Call service.
  • Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
My D2500 is not printing i.e. only the top line and the bottom line and nothing in the middle? I have renewed ink cartridges
Please check the printer properties and reset ti to default. If still not work. re-install the printer. sometime we need to refresh the printer drivers by re-installing printer driver.
Feb 28, 2015 | HP Deskjet D2500 series
Will HP 60 ink cartridge work with HP Deskjet 2460? Tnx.
This is all HP recommends for the HP Deskjet 2460, so I wouldn't suggest buying anything else. First of all it might not fit and second, even if it fits, other issues may come with using those. If you can't see the list here it is:
HP 21 Black HP 21 Black Twinpack HP 21/22 Black/Color Combo HP 21/22 Quad Pack HP 22 Tri-color Twinpack HP 22 Tricolor HP 58 Photo
Jun 23, 2011 | Office Equipment & Supplies
How can i install my hp deskjet d2560? when the time i bought my hp printer it has cd instalation driver but the cd has d2500 series so i go to the net and download the driver for d2560, but when i...
The same driver software is used by the D2500 printer series, of which your D2560 is one model. So the "D2500 series" drivers are correct.
Make sure you downloaded the correct drivers for your Vista version, 32-bit or 64-bit. The links are to the HP site drivers page for your printer. Also, HP printers often will not work if you connect the printer before installing the drivers. The setup guide and CD both mention this, but it is sometimes overlooked. Try uninstalling the HP software and following the process again, and make sure the printer is not connected until you are instructed to connect it.
These steps will install the proper drivers so Vista can use the printer. If the printer still is not working, please post a follow-up comment with more information: error messages, indicator lights, print quality problems, etc.
Good luck and thanks for using Fixya!
Nov 10, 2010 | Computers & Internet
Hi I have an HP Deskjet D2560 which was working fine up and until I installed my new HP Deskjet F4480.Ever since I keep getting an installer plugin error that keeps popping up for the D2500 series printer ...
Try making the other printer offline when ever not in use. Their could be reason this is clash of installed files or else try uninstall of D2500 printer drivers & installing with updated drivers that can be downloaded from support.hp.com.
Oct 31, 2010 | HP Office Equipment & Supplies
LOST INSTALLATION DISK FOR HP D2500 DESKJET PRINTER NEW LAPTOP ANY IDEAS FOR INSTALLATION
Start from here and download the software for your system.
Chose model, operative system and follow instructions to download the driver software.
HP Deskjet D2500 Printer series - Download drivers and software .
After downloading , start the file , start driver installation with printer usb cable not connected.
Mar 01, 2009 | HP Office Equipment & Supplies
Need to download cd
You can find your drivers/software on the HP website under the support section. All you need is your model # & operating system. Hope this helps & please remember to rate my answer. Thanks.
Jan 09, 2009 | Office Equipment & Supplies
Putting in ink caritages, the printer I have is hp deskjet D2500 series
Please state your problem or use our live chat for more hellp
Nov 18, 2008 | HP Computers & Internet
My HP 3920 deskjet printer not printing.
the service needs to be turned back on altho I dont recall where u do that. Try a search on your pc for services... then turn the print spooler back on
Sep 16, 2007 | HP DeskJet 3930 InkJet Printer
67 people viewed this question
Seeker5211
Seeker5211
