Question about AMT Datasouth Datasouth Documax 3300 Matrix Printer
Dataouth 3300 not printing properly
The letters are missing dots
  • 4 Answers
There are three probable causes ...
A bad print head, a bad print head cable and a bad logic card - more often than not it's the print head
Posted on Jan 28, 2009
Horizontal print gaps on ml184+
The most common cause of missing sections in the letters is a bad print head. These types of printers (Dot Matrix) create the print with the print head which has a line of small pins called hammers that are activated by an electromagnet. Each pin has its own hammer. If the electromagnet fails or you have something jamming the hammer then it will not move to strike the ribbon and make the image or letter. You can get a replacement print head online for about $15.00, the part number is 50063802. Here is a picture of what the print head looks like. :
Dec 30, 2011 | OKI MICROLINE 184 Turbo Matrix Printer
Bad print quality
you have not mentioned what printer it is? DMP, Inkjet or.....
if it is DMP you check the print head whether some pin(s) missing and if so you have to replace the print head
Aug 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Brother GX-6750 correctronic
Check the print wheel to see if any spokes are bent or missing, be sure that you have the proper correction tape (tack free) and that you are not in proportional space or have an international print wheel.
DickyO
Mar 16, 2008 | Brother GX-6750 Typewriter
Printing problem with Star Sp200
Seems like a problem with the printer head...It is usual for matrix printers and it happens due to wear and tear..You will have to get the printing head to get replaced..
Oct 27, 2007 | Star Micronics SP 2000 Matrix Printer
Tally 2280
It sounds like you may have a broken (or perhaps stuck) pin in the printhead. Check for missing dots in other letters also, or if printing a graphics object, again, a missing dot, consistent throughout the print. Other possible causes of a pin not being "fired", are a small break in the ribbon cable from the printhead to the control circuit. Look for a tiny crack or break in the ribbon, especially along the edge. Also, a defect in the electronics which control the printhead pins will cause this. If by chance the printhead is all gooped up with old ink, a pin might merely be stuck. I have taken printheads out of dot-matrix printers and soaked the pin area (area closest to the paper) in rubbing alcohol, or used Chemtronics cleaning chemicals to spray off the old sticky ink. Messy job: don't wear a clean white shirt! Lastly, if a pin is broken, either the printhead must be replaced, or sent in for repair, assuming repair centers still exist. In years gone by, I have sent in heads, and gotten them repaired successfully.
Apr 23, 2007 | Tally Matrix T2280 Printer
Oki 520 missing print
You have replaced the item which is commonly the cause- the printhead. The other possible problems are: a connection break in the printhead ribbon cable, which makes electrical connection from the driver circuitry to the printhead. Look for a tiny crack, especially along the edge of this ribbon cable. Another possibility is an electronic component defect in the circuitry which fires the printhead, or maybe a loose solder connection in the same circuit. Lastly, when you replaced the printhead, are you reasonably certain the replacement head didn't have a broken top pin or two?
Apr 10, 2007 | OKI MICROLINE 520 Matrix Printer
AMT Datasouth Datasouth Documax 3300 Matrix Printer Logo
187 people viewed this question
Top AMT Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Marvin
Marvin
Are you an AMT Office Equipment and Supply Expert? Answer questions, earn points and help others
