Question about HP PSC 2210 All-In-One InkJet Printer
Front Panel Display is Blank - only small black squares
I can't get my HP PSC 2210 All-In-One InkJet Printer-Fax-Scanner-Copier to work. The front panel display screen stays blank, just small black squares and does not light up when in the on or off mode and of course, the small black squares dissappear when I unplug the power cord. When I plug the power in and turn it on, the copier light comes on and the cartridge starts to move out about an inch or two and makes a noise like it wants to print for a few second and then the cartridge moves back in to the left and the noise stops. This is very hard to troubleshoot, because the screen shows the black squares no matter which buttons I push. Thanks Mayzie
  • 1 more comment
  • Heintje Nov 27, 2007
    Over the past few months the display deteriorated from barely readable to just seemingly random squares/pixels to nothingness.
    About to take the screwdriver to it, hoping for a loose lead or something.
  • thesnackbrea Dec 01, 2008
    I have a very similar problem. When in the middle of printing, all lights go out and the printer stops. After I unplug and replug the printer back, it will continue for a while and then start the process all over again.
  • Anonymous Mar 19, 2014
    the small lcd square on the front went solid white. Can't see anything.
Actually... I fixed mine more or less using just a kitchen knife.
I pried loose the plexiglass cover for the 2-line display by carefully sliding in a knife just under it.
It is stuck on with double sided scotch tape along the rim, and two plastic anchors in the bottom areas.
With that little cover removed I pushed and prodded the exposed display which made the text readable at times.
It turned out that if I pushed in the knife slightly at top of the display, and angled the knife to push the display unit 'forwards' it would start to make contact, and become readable.
I may have to open it up better some day to re-seat the display, but for now that worked.
Hein.
Posted on Nov 27, 2007
The front panel display initializing and then disapear and then the functional buttoms begin to flash. nothing happen again. when i press the on buttom the same thing reocurre
Posted on Jan 09, 2007
Hp 2210 all-in-one printer fax copier scanner-keeps saying remove door and remove paper jam and there is no paper jam. How do i clear this?
You can't I have the same printer and it is the stubbornest thing in the world. Just hit enter and keep printing.
Nov 18, 2009 | HP PSC 2210 All-In-One InkJet Printer
I have an HP J6480 printer, Fax copier, when I fax or copy a black line is down the center of the sheet. I replaced the toner. How do I fix it?
There is something stuck on the scanner glass. To test for this problem try making a copy by laying your original on the glass and making your copy, not running it through the feeder. If it copies fine from the glass it is definately something in the feeder/scanner glass. Just clean it with a soft cloth and some glass cleaner. You should be lookig for a thin strip of glass to the left of the large glass. Or you might have to open up the feeder unit and find it there.
Oct 16, 2009 | HP PSC 2210 All-In-One InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
My problem is with the HP PSC 950 series printer, fax, scanner, copier. The fax and copier work sporatically, sometimes producing a copy or fax and most times not. Please help
faxing,scanning and copying use the same mechanism,thts the scanner,if its doing it intermittently you can try a reset on the printer.see if tht works.
Jun 24, 2009 | HP PSC 950 All-In-One InkJet Printer
HP psc 2110xi all in one printer scanner copier
When I turn on the 2110 printer the scan light just keeps moving forward a small amount and to goes back to the home position. It will do this for about 5 minutes and then shut donw.
Mar 05, 2009 | HP PSC 2210 All-In-One InkJet Printer
Wejust bought a psc 2210 and we dont know where ink jet are at in
The are under the scanne, you reach them fron the front
Here is the full user guide, check on page 72 Full User Guide
And here is basic guide
Basics Guide
And here is the setup guide
Setup Guide
And here is the complete supoorter site
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3571753&lc=en&cc=us&dlc=en&submit.y=9&submit.x=7&lang=en&cc=us
Good luck
Nic
Mar 04, 2009 | HP PSC 2210 All-In-One InkJet Printer
Cannot get dial tone to send a fax
try to reset your printer to factory setting
purchased your HP PSC. Choosing to restore your factory defaults restores
all settings, except date information.
You can perform this process from the front panel only.
1 Press Setup.
2 Press 5, then press 3.
This selects Maintenance, and then selects Restore Factory Defaults.
The factory default settings are restored.
and you can find the manual at this link
http://h10032.www1.hp.com/ctg/Manual/bpu05064.pdf
Jul 01, 2008 | HP PSC 2210 All-In-One InkJet Printer
Re: Printer HP 2210
well darlene maybe you should change the cartriges they might be too old the second option clean the top glass beneath and above so that the scunner might read clearly thomas
Apr 15, 2008 | HP PSC 2210 All-In-One InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
I can't scan
This document applies to the PSC 2210, PSC 2210v, and PSC 2210x. When you see the scanner failure message, turn off the PSC 2210. Wait a few seconds and then turn on the PSC 2210. If you see the message again, please contact HP Support. http://h10025.www1.hp.com/ewfrf/wc/contacthp?lc=en&cc=us&docname=c00055511&dlc=en&product=79499&rule=45570&lang=en
Dec 04, 2007 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
110 people viewed this question
Clive
Clive
