Question about Whirlpool GH7145XF Microwave Oven
Can't get light bulb cover off in Whirlpool oven
Whirlpool manual says to turn the light bulb cover counter clockwise. It is impossible to loosen. I would appreciate some tips/tricks.
    Sergeant:
    Champion:
  • 338 Answers
The only thing i can suggest it to tap it lightly with the handle of the screw driver to see if maybe it is cross threaded. some are hard to get off.. so maybe try using one of those jar opener pads to get a better grip to turn it.
Posted on Nov 26, 2008
Have a c970-440793 range. Need to replace the oven lamp light. I have the part in from Sears but there are no instructions.
Just slide the wire off of the glass lamp housing cover. It should just pop-off to the side. Then carefully remove the glass cover so as not to break it. Next, just remove the light bulb by unscrewing it counter-clockwise.
Screw in the new bulb (any small 40-watt appliance bulb will work,) hold the glass cove in place, then slide the wire back over the glass cover. The wire should be centered over the middle of the glass, towards you.
Sep 28, 2015 | In Microwave Ovens
Replace lightb ulb
Grab bulb in light receptacle and quickly spin in circles counter-clockwise. Wait to recover from dizziness and throw bulb away. Get new bulb, place in light receptacle and spin clockwise being careful not to over tighten which could result in new bulb breakage and rendering it worthless. Throw up and recover from dizziness.
Sep 15, 2014 | Emerson Microwave Ovens
Cooktop light socket needs replacing, bulb broke in it. Socket needs replacing.
make sure the light is off, better yet turn off the breaker
take a potato a little larger than the socket, cut it to size, whatever.. jam it into the broken bulb (carefully), this will allow you to grip the broken bulb safely. turn counter clockwise and whats left of the bulb should unscrew out.. works VERY well
Feb 15, 2013 | Microwave Ovens
Need to replace both might lights under microwave.
Remove the screw from the lens cover and open lens. Turn light bulb counter clockwise and remove. Repeat this on other side. The bulbs or 40W appliance bulbs. Take the old one with you to hardware store to match it up. Reverse your steps to put new ones in.
Jun 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
How do you change the light bulb in a JVM 1440?
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to unsecure the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | GE JVM1440 Microwave Oven
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
May 02, 2011 | Microwave Ovens
I have a Hampton Bay ceiling light fixture model FM 5001. The light had burned out. How can I get the glass cover off, so that I can replace the bulb
Hope you figured this one out by now. . .it unscrews. Turn the glass counter-clockwise and it'll come off.
Nov 26, 2010 | Microwave Ovens
Need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Jul 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a light bulb that broke and I cant get it out, does it push in or screw in?
Chances are it is a boyonet base bulb. Unplug or turn off the power to the microwave. To remove the bulb, press in lightly, turn the base of the bulb counter-clockwise about 20 degrees till it stops, then it should pull straight out.
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The light in my Whirlpool microwave/ convection oven burned out and no one can tell me where it is or how to fix it. I called Whirlpool, and they recommended I call a repairman to come to my house to fix...
You can download Whirlpool owner's manuals and installation instructions here.
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
If you do need to take it apart to replace the bulb:
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs (or 20A ceramic fuses) can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Jan 08, 2010 | Microwave Ovens
Whirlpool GH7145XF Microwave Oven Logo
106 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
