Question about Canon Office Equipment & Supplies
Canon CanoScan 3000F won't scan film negatives. It gives me this error: Cannot Scan for these reasons: - The original may not be set correctly. - The Film Adaptor Unit Protective Sheet may be put in place. - The lamp may not be warmed up. Scanner driver will be closed. Code: 2,181,0 TWAIN data transfer error. I've never scanned film negatives with this scanner before, but it scans regular photos fine.
  • 3 Answers
SOURCE: Producing Negative film
The 4g wil not be the solution for you.  It is just a basic graphics printer.  The filmmaker 4 will be the option you should look at.  It will produce negs and positives all the way up to 2400 dpi.
Posted on Oct 24, 2007
SOURCE: CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Posted on Feb 05, 2008
  • 18 Answers
SOURCE: I have a CanoScan FB121ou
You can probably contact Cannon and see what they get for the power supply or search the WEB for an aftermarket ps. You will need the specs off of the old one if you go after market.
Posted on Oct 14, 2008
SOURCE: Scanner Canon 3200F using ScanGear
do you scan on automatic mode?
Posted on Feb 24, 2009
SOURCE: canoscan 3000f error code :
Posted on Dec 03, 2009
Inability to copy film to pictures
When you were scanning, did you set the scan selection to scan negatives ?
Jan 20, 2008 | Canon CanoScan 8600F Flatbed Scanner
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
Mar 01, 2011 | Canon CanoScan 3000F Flatbed Scanner
My canoscan 8400F suddenly stopped working last week. I had been scanning slides thru Photoshop when on my next scan attempt, I got this message: Cannon scan for these reasons: -The original may not...
You have to remove the white protective sheet from the the lid. Once you remove it you will be able to scan film. Also make sure the lock button is not in the lock position.
Open the Canoscan Toolbox.
Click the Save option.
Put a check in the box that states "Display the Scanner Driver".
Click Scan.
Click the Advanced Mode tab.
Make sure Select Source is set to "Platen".
Click the Preview button at the top left
Another thing is this can be caused by a faulty FAU cable. One or more of the eight wires within this cable has fractured
Oct 16, 2010 | Canon CanoScan 8400F Film Scanner
The scanner will not process slides but performs all other copyin
The problem is resolved.
I continued searching the internet until I downloaded the Manual for ConoScan 3000F. The procedure for film scanning had a diagram of the sleeve referred to in the error report.
After removing this sleeve from the underside of the lid everything went well.
ïf all else fails read the instructions" . The problem is to find them when paper is no longer used.
Nov 04, 2009 | Canon CanoScan 3000F Flatbed Scanner
Why is my canoscan 44oof scanning in negative mode i.e white paper with black print is scanning black with white print
I solved this problem by the following:
Don't scan from the Canoscan toolbar. Use an imaging program (I used Picasa), import from the Canoscan, and Scangear opens up. In the settings for Scangear, you can choose positive or negative film (use positive for slides). You can keep using Scangear, or after using it once, you'll see it has corrected the problem with the toolbar
Oct 07, 2009 | Canon CanoScan 4400f MultiFunction Color...
Couple of problems for canoscan 3000f :
It appears the scanner is not scanning in the vertical direction.(I am assuming it is able to scan the full width). Try unistall and reinstall of the friver. This can work. There are sensors in the scanner that indicate the 'end of scan area'. Check if any of them is blocked by shreds of paper or dust.
S. Mohan
Feb 24, 2009 | Canon CanoScan 3000F Flatbed Scanner
Slides scan as negatives
this scanner usb cabal no didact tell me bored problam ya cabl problam 6600E
Feb 04, 2009 | Canon CanoScan 4200F Flatbed Scanner
Cannot scan film and slides
Check the cable that connects to the lid of the scanner. If it is disconnected, you won't get the Film options.
Jan 21, 2008 | Canon CanoScan 8600F Flatbed Scanner
Error message when scanning
Seen this B4 ya scanner system board is borked... the power Supply failure is a symptom.. Probably ya port inerface/PSU ... so it's either shop it or ship it ... :)
Aug 24, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
139 people viewed this question
old marine
old marine
