Question about SanDisk Sansa e250 MP3 Player
It turns off as soon as you unplug it from charging.
I brought a E250 for my sister for xmas from America. (We are in the UK). When we plugged it into the usb on my PC it started to charge. After about 6 hours we took it out but the screen immediatly turns off and you can't turn it back on again. It does this every time you try and unplug it from the PC. I have also tried using a wall plug socket charger, the screen turns on and you can play the songs throught it but as soon as you unplug it from the mains it turns off again and you cant turn it back on. It seems to be having trouble holding a charge. Any help? Thanks
  • 3 Answers
Maybe it could be the battery.. you might need to go purchase a new battery
Posted on Jan 21, 2007
SOURCE:
My daughter's RCA tablet will not turn on. what can i do?
Two possibilities:
1.- Be sure the battery is charged. There has to be some indication that the tablet is being charged.
If you can turn on the table when plugged in to the charger, and it dies soon after unplugging it, the tablet's battery may need replacement.
2.- The other possibility is that the tablet is dead...
Jul 30, 2014 | Tablets & eReaders
I have plugged it in with a uk adapter but its not
US has different voltage to UK. You need a step down transformer in order to get the correct UK voltage.
Dec 14, 2009 | Nintendo DS Lite Console
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
My e250 will not turn off & will not turn on-Screen is gray w/vert. lines in it
You need to remove the battery and let the system power down completely. I have had this problem and the others I have seen on this site. Removing and reinstalling the battery solves many problems. Just letting the battery drain is not good for it and may take a really long time.
Sep 28, 2008 | SanDisk Sansa e250 MP3 Player
Wharfedale touch dect triple phone with answerphone
Hi Michell,
I have the same unit and mine bleeps when I have new messages.
anthea
Jul 12, 2008 | Harley Davidson KNG America 026711...
Wont charge
with your problem i first suggest callng sandisk and asking for advice before you go through all that trouble and money
Apr 18, 2008 | SanDisk Sansa e250 MP3 Player
Completely dead
did you try plugging/charging it into your computer?
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Installing a sony xplod in to my girlfriends fiat punto
If I were in your shoes I would hardwire it, Run the red wire directly to fuse box or battery, run yellow wire to switched circuit in fuse panel, and isolate the black ground wire somewhere inside the dash, I'm in America and have not wrenched on any FIAT's, but in my expirence some manufactures doe things proprietary, give this a shot.
Sep 27, 2007 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
