Question about Hotpoint RVM1425 Microwave Oven
Hotpoint Model #RVM1425WA004
The microwave is working fine, but the lighted control panel is extremely faint, almost appearing to be off. Looking to find out how hard this is to repair(probably something that must be done by an appliance repair person?) and any ideas as to what part might be the problem.
  • Hotpoint Master
  • 9,149 Answers
This uses a vacuum fluorescent display. Over time, they degrade in brightness until they're unreadable. GE does not make just that part available, so the whole "smart board" would have to be replaced. It's not too hard for a do-it-yourselfer but certain important safety rules must be followed, such as in "safety.txt" and "disassembly.txt" available at my Web site. You can order the smart board from Appliance Parts Pros for $149.16 at http://tinyurl.com/gv383
Posted on Jan 07, 2007
Hotpoint microwave model RMV1435BD under recall??
None to my knowledge, but common faults include keypad failure (may show error code "F3") and cooktop light failure, both of which can be affordably repaired. (See link below)
For more free DIY and other help & advice, feel free to contact me via my site below.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 14, 2017 | Hotpoint Microwave Ovens
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
Can,t turn the over the stove lighting on
Replace the bulb. If that doesn't work, the "Membrane switch" under the plastic film control panel is damaged. There is no good way to fix them. Contact hotpoint to see if they still have replacement panels available for this model. If not, either live without the light or replace the whole microwave.
Sep 24, 2011 | Hotpoint RVM1625 Microwave Oven
Our microwave is not heating. When you turn it on it appears to be working, the dish rotates, the light is on, you can hear it running, it's just not heating the food. Is this repairable?
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 22, 2010 | Hotpoint RVM1425 Microwave Oven
Hotpoint 1 and one-half yrs old stopped working
Ck and make sure the circuit breaker on the power panel on the house hasn't tripped.. If your microwave is within 6' of the kitchen sink, ck for a tripped GFCI controlling the power the microwave is plugged into. Good Luck, Ned
Sep 15, 2009 | Microwave Ovens
Microwave external underside light no longer works
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Everything appears to work fine but it is not heating anymore.
If the microwave oven appears to be working but it is not heating the food, it is very possible that the magnetron, or its power supply has failed.
Jerry G.
May 03, 2009 | Hotpoint RVM1435 Microwave Oven
Hotpoint RVM1425BA-003 Microwave Oven Stovetop Light Does Not Work
The problem is almost certainly on the control panel, which we repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 14, 2007 | Hotpoint RVM1425 Microwave Oven
At times some butons don't work
You may have a bad keypad, which in many cases can be replaced.
A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated.
Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation.
I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller.
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Aug 10, 2007 | Hotpoint RVM1425 Microwave Oven
Open Questions:
See all Hotpoint RVM1425 Microwave Oven Questions
Hotpoint RVM1425 Microwave Oven Logo
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
