Question about Polaroid FLM-2601 Television
Tv won't come on
Nothing comes on the screen when I turn my tv on...the power light is on, but nothing else. Polaroid indicates the set is fine after I sent it in but it still doesn't work after I got it back! Any Suggestions? Mike
  • 3 more comments
  • Nashdmills Nov 19, 2007
    I have the same problem. I will try to turn it on at the unit and remote, and it will not come on. Then red light blinks, but no power. If you press it about 80 to 100 times (not exagerating) it will finally come on. Its almost like the old tube systems that have to warm up, but this obviously doesnt have tubes (i hope not anyway). If you have any suggestions i would love to hear them
  • Twinoaks Mar 01, 2008
    Tv is not turn on, red lamps flashes, but no power...could it be the PS?
  • Fostermamas May 20, 2008
    Where do I find parts for this TV?
  • romana1 Jun 11, 2008
    one more person having same problem...my TV is abt one and a half years old... started stuttering when turning on...now i have to press power button LOTS of times and it MIGHT turn on before i get frustrated and go to the movies... not good for Polaroid!!! anyone was able to fix this problem w/o spending $$$$?
    The problem I had with turning my Polaroid on was a simple fix! I was having problems turning the TV on...it would stutter and sputter and finally turn on after MANY tries... called support at Polaroid and the tech asked me to re-set the system setting to factory default... LIKE MAGIC the TV turns on and off at my command like a good TV
Chech ur line trasiformer frist of all check the collector voitage if it is ok
Posted on Jan 21, 2007
I had the same problem on my (model FLM-2601) polaroid month after purchased. The power supply had to be replaced by a professional TV repair shop after I called polaroid 800#! Now a year later same problem. I will fix it my self, took apart PS need part# E051207979800011.
Tony
Posted on Nov 11, 2007
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Polaroid 3700 tv won't turn on no standby lights or anything
Check for any loose contact with any of the connection sockets at the power board, to main board. Re-seat them all once and check. Contact any service technician. Gopakumar Gopalan Google
Feb 19, 2014 | Televison & Video
Tv wont turn on
Check all the connection sockets on the main power supply board for any loose fitting. Re-seat them all, and check. Contact any service technician. Gopakumar Gopalan Google
Feb 16, 2014 | Polaroid Televison & Video
I plugged in a computer and changed the input to VGA and the TV went blank
It sounds like your tv is in sleep mode.
What are the settings for the computer? Make sure it is set for the vga output. If it is a laptop, this is usually done with a function (FN) key. On your settings screen you can set the resolution and which monitor you are using.
Sep 29, 2012 | Polaroid 2611-TLXB TV
My polaroid tv has a red light on but the blue light won't come on and there is nothing displayed on the screen
you must read your instruction manual in section troubleshooting for to what is this problem.
Otherwise you must go to Polaroid to get support help online with Chat.
God bless you
May 10, 2012 | Polaroid 899-KS1-GF4012XAPH TLX-04011C...
PROB LEM WITH POLAROID TLA-01911C
The white screen and nothing else usually indicates a failure of the filter capacitors in the power supply board. When these capacitors go out the voltages are not correct so the TV can not power up right. You can rebuild the power board by replacing the bad capacitors and this should bring the TV back to life. Here is a link to a repair guide for this power supply board.
http://www.ccl-la.com/blog/index.php/repairing-a-polaroid-tla-01911c-with-a-bad-power-supply/
I hope this helps,
BuddyMc
Dec 28, 2009 | Polaroid TLA-01911C TV
Power to the tv just stopd and it is not the cored the red light to sho the power is on is not on
This unit has had a component failure.The unit should be sent or taken in to a service center for testing and service. The Polaroid customer support telephone numbers are 1-866-925-7278 and 1-866-289-5168. Give them the model number of you television and the problem you are having with it. They will be able to help you with your problem.The Polaroid customer support website is: http://www.polaroid.com/CES/support.jsp Give them the same information and they also should be able to direct you to a service center, that will help you with your problem. I hope this information help you with your problem.
May 28, 2009 | Polaroid FLM-3732 Television
Polaroid lcdtv flm-373b
its the problem in the power supply board of your tv. any of the capacitors or ic are loose on the board.check it out and make it proper,
Oct 26, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid Flat Panel TV FLM 373B
I had the same problem with mine, and figured out how to repair the control box. If you would like to have me perform a service on your set go to www.mikecampagna.com/Polaroid
Apr 13, 2008 | Televison & Video
No picture on TV with powerlight on
If you press the power button *on* your TV (rather than using the RC), does the power light still stay on red rather than turn green?
Jan 05, 2008 | Televison & Video
Polaroid FLM-2601 Television Logo
312 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
