Question about Compaq Presario M2000 Notebook
Takes 4 days to charge battery and the display is dim
Dim display and slow battery charge, battery dischargerses even when on ac power
  • TOPHER19 May 11, 2010
    woah that is weird. try taking the battery out and running on ac power like that, let me know if it cuts out, if so it might be a problem with your adapter.....if it doesnt you might have an alien in your laptop, either way let me know more specifically whats going on.
  • 144 Answers
Simple get a new battery
Posted on Jul 22, 2009
How long will the batters last on kodak m753
Every rechargeable battery has a certain cycles of charging and discharging the battery. Not two batteries have the same life time. The amount of cycles a battery can have, can be influenced by the user. If you leave a battery without charging or discharging for months or even years, the lifetime can be shortened. That is why most of the time you get warranty on the equipment, but almost never on a battery. (sometimes a warranty of 90 days is given on a battery.)
Still when a battery won't charge, you could check all the parts in the chain. The AC / DC power convertor / charger the power cable.
When the light on the charger comes on, you can assume the charger is working.
If you can charge the battery in the camera everything looks the same. As soon as the green light comes on (starts to flash slow) you can assume the AC adopter is working. The charging of a fully discharged battery should take about 4 hours.
I have two Kodak Li/ion batteries and after almost 10 years, they are still on good condition. But I also had to trow away lots of other batteries, before they were about one year of age. (I did charge them wrong, with a high current, more then they could handle)
Aug 25, 2014 | Kodak Easyshare M753 Digital Camera
Ac/heater fan slows and headlights dim intermittently on our 2003accord ex 6 cylinder
engine running or not,,??????
bad battery
or dead charging system.
rusty battery terminals.
check battery voltage parked key in pocket, see 12.65vdc.
if lower , on a warm day the battery is discharged
or at 30F it must be.12.58vdc, rested, if not the battery is discharged
or battery is bad.
if discharged , then charge it.
and fix the bad charging system.
ok you jump start car.
and the battery voltage is 13.3 to 15vdc, if not the charge system is failing, or engine RPM below 800.
if running voltage is below 13.3v the charge system is failing running.
Jan 10, 2014 | 2003 Honda Accord
2007 Yukon XL, 1500 SLT, 4WD, headlights randomly go bright to dim and back very quickly
Yes this can be a normal condition caused by load being applied to the headlights and that lowers the voltage, the lites dim, then the load is removed and the lights brighten. Typical loads that cause this are AC climate control related. Have the Alternator load tested to confirm there is no problem in the charging system. Also have the battery tested, a battery that is starting to fail can cause this problem as well, a failing battery takes a huge amount of charging system power to keep it up, so that makes the lighting see higher spikes in voltage
Sep 18, 2012 | Cars & Trucks
My panel lights are too dim and won't brighten. I checked all the fuses and they are all working fine. I turned the dimmer knob all the way to the right and they still won't brighten. When I first turn...
Your alternator may be going bad. Once the car is running, your battery has done its job and the alternator takes over. The alternator is responsible for firing the plugs, running your lights, your radio, your heater/AC, and anything else electrical, as well as keeping your battery charged. If the alternator is on its way out (or even has a less than good ground), you may experience some lights dimming, or even choppy radio signal. If the alternator is already gone, and your car is running off of the battery full time, you will also get the dimming you describe, and sooner or later the car will not even start. Take your car to an auto parts store (Advance, or Auto Zone, etc) and ask them to test your alternator. This is a free service.
Nov 23, 2010 | 2005 Chevrolet Impala
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
Takes 4 days to charge battery and dim display
you battery has become weak check and replace the battery
Nov 27, 2008 | Compaq Presario M2000 Notebook
How do I charge the philips mp3 player?
Connect the supplied AC/DC adapter/charger to the 5V DC jack on your hdd and the power supply. The AC power icon will indicate on display showing that the Jukebox is now adapter operated. It takes 4 hours to fully recharge the hdd and once the battery is recharged fully, the jukebox can play up to 10 hours of music on the move
Dec 30, 2007 | Philips HDD120 MP3 Player
Compaq presario c-300 charging system
that is normal.. you can change that dim setting to power option in control panel.. it really dim when unplug.. but you can change that if you want, so it will not dim.
Dec 26, 2007 | Compaq Presario R3000 Notebook
Nx 9010
Simply plug the ac adapter into the wall, the laptop will charge the battery itself.
Keep in mind this... in general, a laptop runs at full speed when it is plugged into the wall. When most laptops are running on battery, things are running more at 50% capacity to save on power, this giving you more battery life. A dimmer lcd and slowing the processor down when not needed are common traits.
You can use the FN key (function key) and the corresponding dim control on the keyboard to adjust the brightnedd of the backlight. It should be marked on your keyboard in a different color, like blue or maybe green (not familiar with that models keyboard).
Oct 21, 2007 | HP Compaq Business Notebook NX9010
Compaq Presario M2000 Notebook Logo
62 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
