Question about Microwave Ovens
No power, no lights, no sound, nothing. It's like it's unplugged. It worked and then it didn't. Electrical outlet has power.
  • jbtrucks Nov 26, 2008
    plug is live,oven getting power.but wont turn on ,no lites nothing.
    Sergeant:
    Champion:
  • 338 Answers
There is a Thermal Cavity Overlad on the top of the cavity that is blown.
The microwave needs to come and the shell needs to come off to find it. it is a $10 part that breaks the neutral and maes a "Dead" unit.
Posted on Nov 26, 2008
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
My ge cafe microwave has stopped working after hot oven was on
you are most likely correct . they were not made to withstand extreme heat from the outside
Sep 15, 2017 | GE CVM2072SMSS Microwave Oven
New microwave stopped working after 15 seconds
Possibly the fuse / breaker is tripped, usually all outlets in one room share same breaker. Check breakers (or fuses) or try outlet in differnt room. If the outlet has power, (plugin a lamp to check) and the microwave still does not work, take it back to store for replacement or refund.
May 11, 2013 | Oster OGG61403 1.4 Cubic-foot Digital...
No power at all
Sounds like it has died. Unplug it. Sorry for your loss. Really. You can contact the manufacturer though to be sure. They may have a solution.
Feb 14, 2013 | Samsung Microwave Ovens
Over range microwave model jvm1650wb008 fan works nothing else does
Check to see if circuit breaker is tripped in the electrical panel, or if it is connected to a ground fault outlet, it may have tripped. Sometimes there is one ground fault outlet serving others in series in the kitchen.
Nov 25, 2011 | GE Microwave Ovens
My GE spacemaker xl1400 model JVM1451BA 001 DOES NOT TURN ON, serial # HT9897895 , it wont make a noise or nothing, not lights, someone told me its a fuse, but I dont know what the fuse is called to go to...
First try plugging it in a different power outlet to eliminate a possible defective AC outlet, than if it still does not work, your friend could be correct it could be a fuse, if you have electrical skills you can verify your self. first unplug the power cable, than unscrew the cover to get to the electronic board, locate all the ceramic fuses and with a good multimeter set to (Ohms) check the continuity of all fuses if it reads 0 ohms it's good if it reads nothing than it is bad, replace that fuse with the same amperage and type than put the cover of the oven back, plug the power cable and give it a test if the fuse burns again than the problem is much worse, it could be a defective safety switch on the door frame or a defective circuit board, take it to a good repair shop...
REMEMBER TO ALWAYS UNPLUG THE POWER CABLE BEFORE OPENING THE UNIT!!!
Hope this helps!
Jun 18, 2011 | Microwave Ovens
Purchased an MCO165UB microwave 7 months ago. Ran great for 6 1/2 months and then there was no power. No fan, no light, no cooking. It was like the cord was unplugged but the electrical outlet has...
I would have your house hold supply checked on the socket that it is plugged into. One appliance fail but not two.
I hope you find your fault.
Jan 25, 2011 | GE Microwave Ovens
No power on Whirlpool Microwave MH7110XBG
There is a ceramic fuse inside the unit. You can order it from repairclinic.com. Use your model number to search for it. Sounds like your problem. Simply replace the fuse and you should be good. Remember to unplug the microwave before you open it up.
Let me know how this works out for you.
Benjamin
May 29, 2010 | Whirlpool MH7155XM Microwave Oven
GE Sensor Microwave JES1855 died
Mine went dead after about 6 months. I had problems with my breakers and I found out that it was the microwave that blew all of them. I also found out that this perticular microwave is a fire hazard and should be recalled. It has caused me alot of headache. The breakers in my house are brand new and they are put out by GE also. It caused me to loose the food in my freezer, I did not know my freezer had lost power. It would cause my entire lights to go off and then they would come back on. I have checked around and I found out that the power cord on the back of the unit is very loose. I had a person to come in and look at it, he thinks its the power cord.
Feb 20, 2009 | GE JES1855 Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
