Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
Condensation in refrigerator
We have operated a True Manufacturing Co. two door refrigerator model TS-49 at our church for about a year. We recently observed that condensate water accumulates on the edge of the metal shelves located near the center of one door. What can be done?
    Problem Solver:
  • 6 Answers
Try replacing the seal around the door
Posted on Nov 26, 2008
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
What is the standard defrost timer control setting
Usually every 6 hours will keep the evaporator coil clear of frost. I set the time at 45 minutes per defrost. This unit has a defrost termination control that kicks it out of defrost when the coil reaches a certain temperature. The defrost timer is only a backup if the defrost control fails.
How difficult is it to replace a Door Gasket - True TS-49F Freezer
The old gasket just pulls directly out from its slot in the door. Start about 3" away from a corner, then pull the corner out; the rest is easy. Soak the new gasket in warm water before fitting; it softens the edge and makes it easier to push in.
Apr 23, 2014 | True TS-49F Stainless Steel Freezer 2...
True freezer
Things to check are:
Is the thermostat set to the correct temperature (Low, Med, High)?
Are the door seals in good repair and making a good seal with the freezer cabinet frame?
Is the door warped or distorted in any way, will lead to leaks.
Can you hear the compressor/motor running?
Dec 28, 2013 | True Refrigeration True T-49 2 Door Bottom...
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
Need to replace, buy door lock
find model number , serial. local distributer or factory can get that for you
Aug 28, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Normal Operating pressure for true 2 door Freezer R404A Room Under 80 degrees F Box at -10 degrees F
The pressures depend, somewhat, on the expansion device,i.e. a TXV or Cap Tube. Take a pressure reading, then convert it to a temperature. The evap temp should be right at 10 colder than the box temp. Remember, heat flows to cold so the evap has to "Lead the Load" in order to cool. In many cases, the condensing pressure is usually ambient temp, plus 30, then convert to a pressure. These are general accepted practices that have been used for many years.
Hope this helps
Jul 11, 2009 | True 49 cu. ft. / 1388 liter Commercial...
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
186 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
