Jukebox - 1959 Wurlitzer Jukebox Not working
I took out 3 chassis: an amplifier, a power supply and a switching mechanism.  I purchased the necessary caps and replaced most all of the capacitors.  When I plugged it all back in the power supply and the switching mechanism did not work properly.  The rectifier tube and the transformer on the power supply do not get hot but there is still power going to the switching mechanism.  Meanwhile the amp seems to be working.(the tubes are all glowing) Please help.
mjap
  • 107 Answers
SOURCE: marshall jcm dsl 100 head
try to find any diagram from a website.. then print it and give it to your amp tech. so he could Identify what are the wrong, what the first guy did to your amp and its better to buy a whole new tubes. I know your amp tech is very good. I'm just a noob about tubes yet I want to know how this works. hoping for the best for your amp tube.
Posted on Jan 26, 2008
SOURCE: Luxman LV 105 Amplifier gone dumb
hnfgdgd
Posted on Mar 24, 2008
  • 211 Answers
SOURCE: replace florescent tubes in Wurlitzer
The column tubes can be replaced by turning them 90 degrees using the small black tabs on the end. They then slide out sideways. The top tubes are twist and pull also but hard to get to. One end goes forwards the other pulls backwards. Removal of the yellow plastic light diffuser is often required. It slides out in a spiral motion.
Dave F.
Posted on Aug 09, 2008
Duncan
  • 218 Answers
SOURCE: Puchased A Yamaha DSP-A1092 Amp from Auction turns off
I doubt it. Sounds like it is going into protection due to bad output transistors or some such. Time for a trip to the repair shop it sounds like.
Posted on Nov 14, 2008
  • 211 Answers
SOURCE: Wurlitzer OMT CD Jukebox
It's a blown fuse on the amp.
You have to undo the cover plate at the top and then flex it to unhook the bottom. Once it is off you'll see the fuses.
Posted on Jan 01, 2009
No sound
Check to see if tone arm is in the correct position and did not get jostled out of place during the move.
Be sure needle did not get damaged.
Check to see if cartridge wires came loose during move.
Did turntable slip out of position?
Any cables come unplugged?
Any amplifier fuses blown or mechanism power supply fuses blown?
Aug 26, 2014 | Wurlitzer Rock-ola Jukebox
IM TRYING TO COVERT MY WURLITZER 1015 OMT CD JUKEBOX TO PLAY MY IPOD WHAT DO I NEED TO GET.
To make the jukebox automatically switch between jukebox CDs and the IPOD source, you'll need the background music adaptor. I have these in stock, but need to know which amplifier is in your machine, as different amplifier types require different BGM units. Please email tech@wurlitzer-ohio.com
Oct 13, 2010 | Wurlitzer Jukebox 1015 One More Time...
I am moving house and will be moving my wurlitzer OMT, do I need to secure any mechanisms down in order to move it safely ??
Hello qsteven,
With any jukebox no matter what manufacturer, it needs to be locked down to stop the mechanism from being damaged. This is usually done by some form of tie-down bolts on Rowe Ami two bolts hold down the frame other manufacturers do it slightly different.
It is a good policy to make sure that all the circuit boards and amplifier and power supply are secured to the cabinet.
If I move jukeboxes I also tape across the doors to stop them opening during transit to prvent any damage.
Regards
Alan Hood
ami-man
UK
Sep 27, 2010 | Wurlitzer Jukebox 1015 One More Time...
Flashing 8 on display
A flashing 8 on the display indicates that the Selection and Credit Computer hasn't detected the gripper arm has returned to it's normal rest position over the CD carrier (where the CDs are stored). It can be caused by several factors:
1. Gripper motor switch has been turned off
2. K7 microswitch or actuator is defective
3. Blown fuse in amplifier
4. Defective gripper motor
5. Open latch solenoid coil
6. Defective Selection and Credit Computer
I am the authorized Wurlitzer Jukebox repair center for the US and would be happy to help you over the phone. I can supply parts and repair defective amplifiers and computers, etc. Please email me tech@wurlitzer-ohio.com.
Jan 18, 2010 | Wurlitzer Jukebox 1015 One More Time...
How do i move my wurlitzer 1015 cd one more time
I take it you wish to transport your jukebox.
If this is the case I would remove all the CD's (keep them in the order that they were on the jukebox for installation again)
The jukebox mechanism will have some form of tie down system that locks down the mechanism tight into cabinet.
Check the power supply, amplifier etc to see if they pull off their mounts. If they do usually on these parts are holes to insert wood screws to lock them down (use the correct length of screw so they do not damage the cabinet) On the title racks or tubes tape them down so they do not come loose in the cabinet.
Try if at possible to transport the jukebox upright in or on the vehical, cover the jukebox with blankets before strapping to the vehical.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer model 556
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Nov 04, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wulitzer Jukebox CD - Carnegie has smoke coming out of it. Repairer in Sydney area?
WHAT PART HAS SMOKE COMING OUT OF IT.? MOTORS?AMPLIFIER? COMPUTER SELECTION? POWER SUPPLY?
GOT-TA KNOW WHERE TO GO?
DOCTOR FIX IT.
E-MAIL SEYLEVITT@JUNO.COM
NAME SEYMOUR LEVITT
COMPANY NAME IN-HOME JUKEBOX REPAIR
Nov 04, 2008 | Wurlitzer Jukebox CD Player
Wurlitzer 1015 problem
Most likely the main fuse inside the wurlitzer itself - situated screwed into the lower right hand side of the amplifier panel.
Aug 16, 2007 | Wurlitzer Jukebox 1015 One More Time...
83 people viewed this question
 Grubhead
Grubhead
