Question about MSI KM4AM-V Motherboard
Booting problems My computer boots to bios display screen, then hangs or takes minutes to run through the bios and boot into windows. No beeps, just black screen with bios and press del to enter setupt on the bottom, which does no work.
  • 624 Answers
As you probably have already figured out your motherboard is running into some type of error during the boot process. Try restarting the computer and pressing the del key several times after a second or two. Can you get into the BIOS now? The first thing I would do is to make this as basic a machine as possible: remove and add in cards (except primary video card), remove all USB components, reduce the size of your memory (RAM) and if you have multiple hard drives remove all except your boot drive. Unplug your computer, plug it back in and reboot, paying close attention to anything that is displayed on the monitor and noting any changes from before. If nothing changes can you tell us some more about the status of the computer or what led up to this? Did you just build it; just install a new part, power problems, anything? Let us know what you turn up and please don?t forget to rate the posting.
Posted on Jan 06, 2007
I have IBM P3 and i want to change win xp but its not booting pliz help me and it doen't give me option of booting
Turn the computer on. Keep your eyes glued to the bottom of the monitor screen. This usually comes by fast, so keep your eyes peeled.
When the computer manufacturer logo screen comes up, look for the -> enter CMOS Setup, or enter BIOS Setup, <- key to press.
Write it down.
If Windows loads on your computer, allow it to load, and run for a few minutes.
Turn the computer off normally.
WAIT 20 seconds, or so; then turn the computer back on.
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup key. (Or enter CMOS key)
Tap in 2 second intervals.
If you hear beeps ignore them. They are Stuck Key Error Code beeps, and it is you that is doing it.
Once you get into BIOS. look for Boot Options.
In Boot Options set the first boot device to CDROM.
http://www.hiren.info/pages/bios-boot-cdrom
REMEMBER, you have to Save Changes, or it will be like you have done nothing at all.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 07, 2013 | IBM NetVista PC Desktop
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
My computer is not working....i am stuck in windows system32 drivers disk.sys when i try the safe mode...and the installation stops and just turn into black... can anyone help me ragarding this problem?...
If computer does not start normally, use this checklist to identify specific symptoms and take the recommended corrective actions to resolve the problems.Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge
  1. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.
Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook.
  • Check AC adapter wiring and power connection to the notebook.
  • Connect a different AC power adapter and remove battery, then restart notebook.
  • Connect a different battery and disconnect AC power adapter, then restart notebook.
  • If there is no power available at the notebook, contact HP to purchase a replacement battery or AC adapter.
Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing.
  • Count number of blinking LEDs or beeping tones to help with diagnostics testing.
  • Contact HP for technical assistance. There are no other user-initiated troubleshooting actions until error codes are resolved.
Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure.
  • Connect an external monitor to check if the problem is the built-in LCD display or graphics card.
  • Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset .
  • If memory or hard drive components were replaced, reinstall original components.
  • Remove memory modules and replace one-at-a-time.
  • Remove and reseat hard drive.
  • If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test .
  • On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics .
  • If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition.
    Note: All programs and data are destroyed during recovery.
Symptom 4: Computer may display an error message on a black screen during startup or boot
  • Search www.microsoft.com for terms in error message.
  • Search www.hp.com for terms in error message.
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
  • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
    • Select Disable automatic restart on system failure to view error message.
    • Run Repair Your Computer .
    • Run Last Known Good Configuration .
    • Select Boot into Safe Mode and then select Run a Microsoft system restore .
    • Select Boot into Safe Mode and then select Uninstall recently installed programs .
    • Select Boot into Safe Mode and then run Windows Update .
Symptom 6: Computer displays the Windows logo screen and stops respondingIf no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
  • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
  • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
  • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
Oct 11, 2011 | Computers & Internet
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    Oct 09, 2011 | HP Mini 1000 Netbook
    Screen not displaying. and fun starts and stops, remains stand by when restarted the fun runs and stops stand by.
    hello there,
    I got the same problem but it came gradually...
    In fact for a full month when I first boot the computer, the fans runs, no extra beeps, the light blinked correctly but no bios at the screeen. I remarked also that the fans run full speed doing a lot of noise. Then I stopped the computer and wait 2 minutes and then it always works correclty at the second boot with the bios screen appearing. Also, the fan calm down after 1 second with less noise. So when I start the computer and hear that the fan calm down with less noise after 1 second, I know that the computer will boot correctly. That happens always at the second try after waiting 2 minutes. But since yesterday, the fans never calm down and the noise still remains high with no Bios at the screen. I'm suspecting the Power Supply...
    i hope my i dea can help you.
    Sep 02, 2011 | Dell Inspiron 1545 Notebook
    Compaq Presario V2000 boot up problem
    i have the same problem with mine, the compaq2_bing.gif screen shows and beeps twice and then it says press f1 or f10 but it doesnt respond to anything i press
    Nov 24, 2007 | HP Compaq Presario V2000 Notebook
    Display problem.
    reinstal the os and reformat yur harddisk
    Oct 29, 2007 | Acer Aspire 5500 5570-2609 Laptop
    MSI KM4AM-V Motherboard Logo
    148 people viewed this question
    Top MSI Computers & Internet Experts
    Alun Cox
    Davit Mamyan
    Davit Mamyan
    Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
