Sound verey low no matter what u play aux tape cd phono vcr it is still the same
Instructions:
Evaluate your current receiver. Take a look at the back-panel connections to make sure you don't have a phono input. In most cases, the phono input will be clearly marked. If the connections are not marked, look for a set of RCA-style inputs with a grounding screw next to them; this is a phono input. If there isn't a phono input on your receiver, see if you have an open set of RCA inputs. If they are all occupied by other equipment, you can disconnect one piece of equipment, buy an A/V switcher or get a new receiver--preferably one with a phono input.
Purchase a phono preamp. The voltage output of a turntable is much lower than those of other peripheral devices, including CD players, tape decks and game systems. Although the inputs look the same, connecting a turntable to a standard RCA audio input will result in very faint sound output, if you hear anything at all. The output of your turntable must be amplified to a level of about 150 millivolts (mVs) before it reaches the receiver, so a turntable "pre-amplifier" or phono preamp is necessary.
3. Purchase patch cables. You'll need a set to run from the preamp to your receiver. Measure how long your cables need to be, and purchase accordingly. Resist the temptation to "go cheap," because better-quality cables will provide better sound.
4.
Connect the preamp into the system. First plug the preamp into an AC power outlet. Most models have a small AC-to-DC adapter built into the plug. Then connect the cables from the turntable to the preamp, and connect your new patch cables from the preamp to the receiver.
5.
Adjust the gain of the phono preamp. Most models have a gain control for fine-tuning. Follow the instructions provided by the manufacturer and adjust your system accordingly.
F150 Parts.
SOURCE: I have an old Sansui au999 amp
you can go about this many ways.depending on what you have to work with.are you useing a satilite or cable box?if so assuming they have audio/video out just send the audio to the amp and the video cable to the tv.u could use the aux or the tape in.just put the dvd in the other input aux or tape in.dont matter which.if you dont have a cable box your tv must have some kind of audio out to run to the amp.it can be a rca out or simply a headphone jack.you will need a headphone jack too rca plug cable if you have a headphonejack on your tv.hope i could be of help.
SOURCE: Connecting Pioneer SX-737 Receiver to computer problems
I've been recording LPs for over a year now.
I've got the turntable outputs plugged into the phono inputs on the receiver amp.
I'm taking the Y cord (pair of RCA connectors at one end, mini plug at other) from the Tape Record (these are what you'd use to send a signal to the tape deck for recording) on the amp to the "line in" on the sound card. You may want to look up the specs on your sound card to make certain that you've got the plug in the correct socket. There may be a "line in" and a "microphone" socket. Use the "line in"
What recording software are you using? Audacity is free and is ok. I'm using Goldwave (costs ~$50) and highly recommend it. MUCH better than any other package I've tried. Just google "goldwave" to find it.
The recording software should have an option for selecting / specifying a source. If you have "microphone" selected and the y cord going into the "line in" socket, yoiu won't get anything.
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
SOURCE: Sansui 2000x Phone 1 and 2 inputs produce garbled sounds.
I imagine everything is also VERY LOUD.
Only a Phono (old school turntable) should be plugged into the Phono inputs. It contains a preamp for the tiny signal provided by a Phono cartridge, plus is alters the frequency response drastically to compensate for the RIAA curve applied when they cut the record from tape.
Testimonial: "Thanks for your help and time"
if i play cd the sound will not turn up or downd i can hear it but only just and while playin if i press aux tape phono or vcr the cd sound is still there but very vert low
if i play cd sound will not turn up or down i can hear it but only just and while playin if i press aux tape phono or vcr the cd sound is still there but very very low
