Question about Sony Playstation 3 (PS3) Console
PS3 freezes before HDD reformat
My son downloaded a game before that caused the PS3 to freeze, but we were able to reformat (Full format) the HDD and all was good again. It's happened again, but now the console freezes before it actually begins the formatting process. It says it's calculating the format time, sits for a few minutes, then freezes every time, without fail. We've tried dozens of times, with various combinations of formatting options selected, but it always freezes.
Can you help us?
    Master:
  • 505 Answers
The problem is with the hard Drive. You can try connecting the drive to a computer and then format it. If that doesnt work, you need to replace the drive.
Thanks
Posted on Nov 26, 2008
  • Sony Master
  • 13,433 Answers
Hows the warranty? you could possibly get it replaced or repaired, you possibly have a problem with the hard drive.
  • 4,472 Answers
That sounds like your hard drive is done now. I would recommend replacing the hard drive. If you need further assistance or need help locating a professional if you are unable to perform this yourself let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
My playstation 3 keeps freezing when playing fifa 13.it did not do this when i bought it
You have to delete the cache in the ps3. you have to go to settings and hdd and delete the information about the game if you can, if not you have to reformat the ps3 hdd.
Oct 19, 2012 | Sony Playstation 3 (PS3) Console
When playing for a hour it freezes what can i do
PS3 Freezing
If your PS3 is freezing up on games then it can be solved just by stopping the heat. It is not that tough to fix!
Check out this post to see a full solution:
PS3 Freezing On Games
It should only take you 1 hour to fix this.
Hope this helps?
Sep 20, 2011 | Sony Playstation 3 (PS3) Console
My PS3 freezes whenever i play a game, but i can watch movies with no problems. whats going on
hi there,
it sounds like your ps3 is overheating, this happens more often with games cause they use more graphic power than a movie does thus causing the gpu chip to overheat and freeze on you. It could also be that your hdd is not slotted in fully and this can cause it to freeze also. what you can try is to make sure the fan at the back is well ventillated, clean it of any dust and make sure that its working. remove all cables too and check that none of them are damaged and make sure they are connected properly to the ps3 and tv. Do not play a game for at least half hr after you have done all this, just to make sure it's cooled down and put your ps3 in an open space to allow plenty air to get in at the back if you have not already done so. if the console is still freezing when you try it again, then try removing the hdd and put back in again to see if that's what is causing the problem. Be sure to backup any data on the hdd 1st tho as you will loose this if you going to remove the hdd. you can use the backup manager on the ps3 itself to do this. Hope this helps
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
Game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Saying hard disk corrupt then restores but game freezes
Is this a game on your hard drive or a CD? If it is on your hard drive then it quite possibly had a bad download OR your hard drive is on its last leg.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
GAME WILL LOAD BUT FREEZE MINUTES AFTER LOADING
try doing a factory reset but be warned resetting it deletes all data and restores it back to factory default this should correct the software glich that is causing your ps3 to freez or lock up
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format.. You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset
Jul 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 freezing constantly
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up...
Mar 22, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont format,just freezes??
Try formating it using your pc by taking the ps3 HDD out and connecting it to external case
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Freezing problem
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing Up.You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Aug 02, 2008 | Sony Playstation 3 (PS3) Console
Ps3 console freezing during game
check your HDD of ps3,is it full of memory cause for your kind information there is a program when ps3 needs more memory than its creates short time developed cash as memory on HDD so, if you ahve full HDD than reate some blank space on HDD for memory for barer performance,
i hope so you got mine idea,
if you still have problem than try to contact me .i illl....
THNX
May 17, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
