Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile Ref. Ice despenser motor does not turn. Auger turns
Everything else works fine. When I call for Ice I can hear the lever engage and the trap door open but the motor does not turn the auger. Can trun the motor clock wise by hand and feel the reduction gear resistance. MOD. PSS26SGRD SS
  • 5 more comments
  • imdapapa4 Nov 29, 2008
    Are you talking about the wire at the base of the door by the hinge. Or a connection behind the control panel. If so how do I access the connection.
    Imdapapa4
  • Anonymous Feb 18, 2009
    dammmm thanks ! had the same problem Pulled the light bulb and ice dispner on door worked .Saved 100.00 just for a house call
  • rnobobfromca Mar 27, 2009
    I had the same problem. Pulled the bulb, dispenser worked fine. Replaced old with new bulb. Unbelievable, an old light $1.00 light bulb caused the problem. Thank you.
  • tsvoboda Apr 19, 2009
    Oh my, I can't believe it was that simple!
    I just pulled out the bulb on my fridge and the ice started dispensing right away.
    Thanks chandleg, what a great help - the wife can't live without fresh ice!
  • ReneB Jun 07, 2013
    Took out the light bulb, ice worked like a dream! Thank you, thank you, thank you.
  • Anonymous Mar 14, 2014
    Auger will not turn pellets got damp swollen cleaned out still won't turn won't heat above 48 Motor seems to work but auger shaft seems stuck
    Traeger Auger will not turn pellets got damp swollen cleaned out still won't turn won't heat above 48 Motor seems to work but auger shaft seems stuck
I had this same problem today, and after tearing apart the door and digging with the multimeter, I found that the bulb was drawing to much current {probably due to age} and that pulling it made everything else start working. The high resistance was drawing too much current from the IC on the door panel board.
I'm going to get a new bulb tomorrow, but if you yank the bulb it'll probably work. {If you have the same problem}
Posted on Dec 03, 2008
    Problem Solver:
Just pulled the bulb and it works lie new. Had the ge service guy here before and tried talking me into paying him 4170 to pull the motor out adn thaw it out
Posted on Apr 27, 2010
  • grossgrinch Apr 27, 2010
    Sorry for the spelling. I meant $170 and he wanted me to thaw out the motor. When I removed the bulb everything worked fine and I save $170
  • 74 Answers
Double check the connections on the door light switch before condeming the motor
Posted on Nov 28, 2008
I have a GE Profile (PS29NSTA) Side by Side Refrigerator/Freezer. The unit is making ice cubes just fine. When I press Cube Ice or Crushed Ice, the GE unit does not dispense the cubes. Water comes out just...
Your wire harness at the base of the door could have a broken wire. Might just be a bad auger motor but you should hear it trying to run if that was the case.
Mar 15, 2013 | Refrigerators
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE S/S Refrigerator model GSS20IEBWW auger not turning
Take a hair dryer and heat the auger drive gear. These will sometimes get moisture on them and freeze up.
Turn the refrigerator off first. Then remove the ice bin. The "U" shaped drive will be in the back.
After you have heated it thoroughly, try to move the gear manually. Resume power and try it again.
May 19, 2009 | GE Freezers
Ice dispenser auger does not work.
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Feb 15, 2009 | GE Refrigerators
GE Profile Refrigerator will not dispense ice.
see http://applianceguru.com/view_topic.php?id=13243&forum_id=1&jump_to=76889
Feb 21, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Ice dispenser not working
Scorpio, remove the ice bin itself, dump the ice and see if you can move the bin auger by hand by turning the actuator in the rear. If the bin is ok, with the door open and the door switch held in see if the auger motor is turning when pressing the ice lever. If it's not turning the next logical step is to see whether the auger motor is getting voltage when calling for ice. Make sure the door switch is closed. The part number for the auger motor on the posted model is wr60x0202. Hope this gets you going..Catriver.
Jul 23, 2006 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
1,179 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
