Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
WILL NOT BUILD PRESSURE
STARTED COMPRESSOR UP...PRESSURE BUILT TO AROUND 70PSI, THEN COMPRESSOR SOUND CHANGE AND PRESSURE WOULD BUILD NO MORE PRESSURE. ONCE THE PRESSURE WAS RELEASED NO MORE PRESSURE WOULD BUILD. AIR SEEMS TO BE RELEASED THROUGH THE BREATHER.
  • hw9664 Dec 09, 2008
    I have the exact same problem only my pressure builds to 60PSI and then stops. There is also air coming from the crankcase breather. Did you get your compressor fixed? What it the cylinder and rings or the reed valve?
  • Anonymous Mar 19, 2014
    pancake compressor knocks as it builds up pressure
    President:
  • Craftsman Master
  • 1,388 Answers
Many craftsman compressor are built by champbell hausfeld using a dry type of cylinder and piston (no oil, no crankcase). If dry type, check for worn cylinder and piston ring. Pieces of the vinyl ring can jamb between the reed valves in the head causing air to escape from the intake. If your compressor has a crankcase and oil, check for broken reed valves in head. Spray soap solution on hoses, checkvalve, drainvalve, and fittings to check for leaks. Most likely problem is reed valves broken or open. Parts are available from sears or match parts to chpower.com. enjoy
Posted on Nov 27, 2008
Craftsman air compressor model 191.135131 wont build pressure
I can not find a Craftsman compressor with that model number anywhere so here are a couple things to look into. If the compressor fills to 70psi and keeps on running check the valve plate and piston/cylinder assemblies. Check that the valve reeds on the valve plate are not bent, broken or warped from heat. Then check that the wiper (oil less) or pistion rings (oil splash) are not damaged and that the cylinder wall is not scarred up. Any of these will let the compressor fill up to the point where the air pressure leaks past the valves or piston and won't fill any further. If the compressor fills to 70psi then shuts off the problem is in the pressure switch. Some have an adjustment screw or bolt to control when it turns on and shuts off. If you had a drop from 100 to 70 the springs may be weak or broke and you'll have to replace the switch.
May 22, 2012 | Craftsman Air Tools & Compressors
2004 Mitsubishi Endeavor, The A/C light flashes. The book says its a compressor issue. Got a recharge kit thinking it maybe low on freon, only the pressure gauge reads 60/70psi when the A/C is not running...
try like this frist you want to found the AC compressor relay by using fornt fuse box cover.after that remove the AC relay.then you start the jeep and turn on AC at that time AC switch not blink king you have to replace AC compressor
Jul 11, 2011 | Mitsubishi Endeavor Cars & Trucks
Compressor is building over 70psi.
the air regulator is not working, try adjusting it lower if no change it will have to be replaced.
Jan 02, 2011 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
My SS5 won't make any pressure. I drained the tank to around 10 psi to drain moisture out of the tank and it built the pressue back up to around 120 psi but won't build any higher. The shut-off point is...
Sounds like the pressure regulator has gone bad. That controls how much PSI your system is aloud to have. If this fails it will not fill to max capacity. I would replace that and all will work just fine.
Please rate
Jun 01, 2010 | Ingersoll Rand SS5L5 Ir Electric...
I have sears craftsman 22gal 5 hp air compressor not enough press
hi buddy strip the end off the check valve out and inside is a rubber turn this rubber around and try this if it still downt work it sounds like the pressure switch faulty get back to me
Oct 05, 2009 | Air Tools & Compressors
AC not cooling for 97 Passat TDI
A/c should be charged on the low side while engine is running. Make sure high side valve is turned off. Low side reading should be around 32-35 psi at idle high side should not go above 250. I hope this helps,good luck
Aug 01, 2009 | 1999 Volkswagen Passat
Insufficient cooling in my mercedes 300e 1989. When i hook the manifold gauge and turn on the AC, the low side pressure shows ~70psi and high side 200 - 230psi(low side pressure stays constans and high...
1989 year would indicate the system uses the Old CFC R12 refrigerant. 70 PSI equals about 70°F . This is not enough pressure difference to give you any cooling. Sounds like your compressor has bad valves. Replace compressor.
May 01, 2008 | Heating & Cooling
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
451 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
