Question about Dell W1900 19 in. HD-Ready LCD Television
Problem with changing channel and volume
Everytime I try to change the channell or the volume on the tv everything freezes up and I can't do anything else until I turn the tv off and back on again.
Your TV is having problem in the power supply area or th secondary power supply where the micro processor is situated.take it to a qualified techn to be repaired.
Posted on Jan 27, 2007
How can I change to channel 3 to view cable?
The TV has no manual channel change buttons on it? I have never seen this on any TV ever.
Mar 19, 2016 | Sylvania 6513DF 13" TV/DVD
Everytime I change a channel on my LCD Tv Hi Sense 32
If your using front button to change channel then try to use remote..
If on the remote is fine then the button board of your TV got faulty usually it cause bad contacts of button (vol+,vol-) so that if you press any button the volume button activated due to auto contact..
You can replace the button or replace new button board assembly..
Dec 24, 2011 | Televison & Video
Remote fall on floor and now it is stuck on one channel and I can not turn off the TV or change a channel or lower the volume
Hi, well you can do everything from the axtual TV itself, have a look on the TV you will find a setof buttons/keys. these allow you to controll almost everything that the remote can do.
here you can change channel change volume etc.
The buttons usually there are 6- 7 marked On/Off, Channel up/down, Volume Up/Down, Enter/OK & Menu. Now pressing these will bring up the onscreen display and you can adjust what you wish.
Now with the remote, it's probably best to obtain a new one..
Sometimes disassembly may fix it, but it sounds like it has a bad problem.
To ensure it doesn't interfere remove the batteries.
Aug 19, 2010 | Televison & Video
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sat/cbl button defaults to channel 17
maybe you programmed it with the wrong code sometimes that happen try the other codes that come with it make sure everything works before you think u got the right one.
Jul 01, 2007 | RCA RCR450 Remote Control
Stays on one channel
Obviously ensure your batteries are good. It may well be though that the TV pickup is bad and possibly the micro-controller in the TV has gone as well.
Jun 15, 2007 | Insignia I-LC26Q1 Television
Dell W1900 19 in. HD-Ready LCD Television Logo
102 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
