Question about Lenovo 3000 C200 Notebook
System Restore My 3000N100 Lartop has crashed, that is it when restarting it asks me if I want to set it Safe, Safe Network, Command, Last Configuration or Normal. Prior to this the computer was running slow for an hour and I rebooted the computer, but restart was taking far too long and I powered off the button I have struck F8 and have hit to: not restart, debugger (is it suppose to take a long time?). Lenovo Recovery is limited and I feel I will loose all my files if I am use this program. What do I do? I know my PC you hit a certain number at the top of the keyboard and it takes you to Restore etc. Please let me know. I appreciate your help.
  • Anonymous Dec 08, 2008
    i plugged a usb to my laptop. It told me that i had to reboot so i did. it flashed on the screen that i have a missing operating system. and the window didnt display.
    Sergeant:
    Champion:
  • 258 Answers
You can repair th esystem by using the os(operating system) diskbut first you'll need to set the boot priority in the bios setup by tapping either del or f1 then find th eboo tpriority set cd as 1st priority and hdd as 2nd then save and restart and you should see press any key then it will automatically bring you to the setup until you'll see the option where you can repair the system if there's a problem
questions,question if still unclear
Posted on Nov 26, 2008
  • 55 Answers
U can recover from the crysis by booting in safe mode after that goto control panel -Performance and Maintenance--system--in that select system restore if u hav any previous res points u r safe......otherwise a different procedure is there.............................
Fix acer aspire one wireless
Restart the computer, and keep pecking on the F8 key at the top of the keyboard. Cursor down to Last known working configuration, System Repair, or enter Safe Mode. In Safe Mode you'll be asked if you want to use System Restore. Use Safe Mode to select a date before the problem first arose.
Dec 09, 2013 | Computers & Internet
Dafina zeqiri supernova
What sort of a problem ?
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Aug 24, 2013 | Computers & Internet
Windows cannot find
will the computer boot to an operating system ?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
If this fails you might use the system restore option
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
Jun 07, 2013 | Computers & Internet
Gateway dx4710-05 will not start upgoes to repair , will not repair
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Gateway DX4710-05 PC Desktop
Acer aspire ast180-ud400
You have no stated what sort of problem?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
May 19, 2013 | Acer Aspire™ T180 PC Desktop
How can i get rid of Dxerror 8876086C
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 22, 2013 | Logitech QuickCam Computers & Internet
My pc was restoring with tun up360,restareted,and now windows dose not work
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 05, 2013 | Computers & Internet
Can u restore a emachines pc from the bio or boot logshelp
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
It has crashed , and i need to do a system restart, all i get is a command prompt, can you help me ?
Try to restore your machine first to an earlier time by doing system restore on safe mode if you cant log in to the normal windows.
1. After restart keep pressing F8 or keep tapping F8 until Advance Boot Menu appear
2. Use arrow key to navigate then choose Safe Mode
3. Click Start button then choose All Programs
4. Click Accessories then choose System Tools
5. Click System Restore then follow the intruction on the window.
Your computer will automatically restart when system restore is finish
If this doesnt work then you need a Windows CD to reinstall you Windows again.
Hope This ill be helpful. Than you for using Fixya.
Apr 11, 2011 | Insignia D400a PC Desktop
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
Lenovo 3000 C200 Notebook Logo
94 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
