Question about LG VX5400 Cellular Phone
LG VX 5400 phone keypad is locked
I had my phone in my tool pouch today and since I got out of work I can not dial out. I can recieve phone calls by just opening it when it rings but none of buttons work. Did I enable security or something? How do I shut this off?
  • 1 more comment
  • RooksStrife Jan 20, 2009
    The phone key pad does not respond and there are on options to unlock it??? Is the phone a defect or is there a combination of buttons that need to be press to bring up the unlock option to put in the last 4 digits of my phone number???
  • cafe_latte Jan 20, 2009
    Had similar problem after my kid submarined his phone in the kitchen sink. After dis-assembling and drying it out, the key pad stopped working, until I did the following. Its still working, if not better than before.
    Try removing the battery and re-inserting it.
    hold the power-on/off button, it will chime, continue to hold for 15 seconds - this should reset the fone
    if not, then defect
  • Anonymous Apr 08, 2009
    My cousin locked my phone and forgot the password, how do i unlock my phone.
Bajanguru
  • 7752 Answers
SOURCE: keypad is frozen, cant dial out or recieve any calls
PSYCHMAJOR - take the phone back
guest - replace the flexcable
Posted on Jun 29, 2008
  • 11 Answers
SOURCE: lg vx 9900
first try the last 4 digints of your number if that dosent work then i would try calling custemer support
Posted on Apr 03, 2009
SOURCE: Rumor 2 LG keypad not working
key board doesnt type
Posted on Sep 01, 2009
SOURCE: Push numbers whilst talking on phone
1. FYI, when your call is dailed through successfully - please pay attention as there are two instructions on the screen. It tells you to press which button for dailing and which to press to unlock the screen.
2. To answer your question: On the left hand side of the phone, there are 3 buttons. Press the button at the bottom below the volume up & down buttons. The dailing screen should come up.
This button is also used as a shortcut for changing profiles quickly in the main screen.
Posted on Feb 07, 2010
electrotech1
  • 1126 Answers
SOURCE: How do I retreive my security code, my phone is
Remove the battery for 15Min,
Posted on Sep 25, 2011
I have lg optimus. dial pad works when calling a number but does not work when trying to respond to voice recognition prompts. example if I call my bank an the systems say press 1 for english or entrr...
Had the same problem with a LG Optimus 2X and tried every button but nothing worked until I locked the screen during a call and unlocked it, somehow this un-greyed the buttons for dialpad and I can now dial during a call (i.e. checking answer machine messages). Hope this helps
Mar 22, 2011 | Cell Phones
Wheb dialing touch pad locks with within 2 seconds LG VU 920- Page 8 is not it
The keypad of the VU does lock up when you are on a call, and there is nothing you can do about it.
Jun 27, 2009 | LG Vu CU920 Cellular Phone
Lg vx 9900
Apr 03, 2009 | LG enV VX9900 Cellular Phone
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
My LG VX 5400 only works on speakerphone.
Do you have a Bluetooth headset? If so, your phone may have inadvertantly connected to your Bluetooth headset, resulting in no sound from the phone unless on speaker. You can test it out by making sure the Bluetooth power is off....from your phone's main screen, hit the "menu" button, then go to Settings and Tools, then Bluetooth Menu, then hit the "Set Off" softkey on the lower left side of your screen. If the softkey reads "Set On", then your Bluetooth power is already off. In that case, remove the battery while the phone is still on, wait 30 - 60 seconds, put the battery back in, power up and see if issue is resolved. If not, contact Customer Service for your wireless provider.
Nov 15, 2008 | LG VX5300 Cellular Phone
LG CG225 Cellular Phone
The LG CG225 does not include Bluetooth functionality.
An optional accessory data cable can be used for transferring ringtones or backgrounds to the phone but space for them on the phone is limited.
  • Start syncing your phone with a PC today through this premium quality data cable.
  • Connect your cell phone to your PC/Laptop to access and synchronize your phone book contacts, e-mails, and appointments, change ring tones and background pictures, take advantage of other useful applications!
  • Length: approx. 48 inches (122cm)
  • *Note: Phone & software features are limited to the phone’s capability and the service provider’s default settings. Please consult with your phone’s user manual and your service provider for the availability of these features.
  • Note: Picture for reference only. Actual product may vary.
  • Compatible with: LG 5400 / 5400A / VI5225 / A7110 / C1300 / G4015 / C1400 / L1400 / L1400i / C1500 / C2000 / CE500 / CG225 / CG300 / CU320 / CU400 / CU500 / F7200 / F9100 / F9200 / G4010 / G4011 / G4020 / G4050 / L1100 / L1150 / L1200 / LX1200 / LX-5550 / VX-5550 / VX-4500 / VX-4600 / VX-6000 / VX-7000 / Kyocera SE44 / SE47 / V5 Slider
  • LGs and Motorrola are a nightmare.
    Mar 15, 2008 | Cell Phones
    Can not dial out phone locked
    you need to replaced the keypad or service the keyboard
    Mar 02, 2008 | Motorola Mobility V220
    Keypad doesn't seems to work - seems locked - gets incoming calls
    JOSE18
    under tools there is a record option. erase all things that have been recorded. the button on the top screen on the right hand side allows you to record phone calls. You have probably been hitting it on accident and recording calls and such. Let me know if this works.
    Nov 06, 2007 | Motorola Mobility RAZR V3
    Keypad on ke970 shine
    there is some problem with the keypad for this u need to contact LG care center.
    Oct 18, 2007 | LG Shine KE970 Cellular Phone
    Keypad is frozen, cant dial out or recieve any calls
    Sep 21, 2007 | Motorola Mobility RAZR V3c Cellular Phone
    LG VX5400 Cellular Phone Logo
    1,010 people viewed this question
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Raphael Josiah
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
