Question about HP Blower Fan
Hot point micro wave worked last night not heating today
Heated last night does not work today, key pad works
    Sergeant:
  • 359 Answers
Check door switch very close
Posted on Dec 23, 2008
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
My micro wave is not heating everything esle is working . it was working find yesterday it won't heat water today
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Oct 11, 2010 | Maytag MMV4205 Microwave Oven
My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Aug 02, 2010 | GE JVM1790 1000 Watts Convection /...
Micro wave stopped heating. All other features
Check the door safety interlock switches. Magnatrons are pretty tough but the little switches are not.
Mar 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Central heat does not blow hot air, just warm air weakly
Sounds like some of the elements are not working. You being in Florida they may not have put very many elements in. It was 61 degrees last week. I know because I'm a Dolphin Fan. You will need a current sensing meter to check the elements.
Jan 04, 2010 | Heating & Cooling
KitchenAid KCM2145JSS-1 built-in Doesn't Heat
Everything working is a real good sign. Most likely all thats wrong with your unit is a blown fuse. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=kcms145j&SearchTerm=fuse&RefineSearch=0 and you will find the fuse. It's behind the touch pad with most all the other workings. Very easy to replace and cost only $11.76. It looks like an old round glass car fuse but it's made just for micro waves. It's most likely a 20 amp fuse. To get to it, take all the screws out from the back that hols the case on. once you have removed the case you will be able to locate the fuse. Good luck.
Dec 19, 2009 | KitchenAid KCMS145J Microwave Oven
Amana aco 1840 over stove micro wave. heating not working .
FIK IT THE HEATING ELEMENT IS STRIGHT FORWORD AND COST IS CHEAP, GO FOR IT .
Oct 24, 2009 | Amana ACM1580 Convection Microwave Oven
No heat in oven or on range
when you turn on the top burners do you hear the ignighters clicking please hold my rating for now as i need to ask a few questions
Jan 11, 2008 | Frigidaire FES367 Electric Kitchen Range
Computers & Internet Logo
247 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
