Question about RCA D52W135D 52 in. TV/DVD Combo
DVD will not open
My DVD will not open. It worked fine one day and the next it would not respond to the remote or the buttons. There are no DVD's in it. michwolf.
  • Madrical Tillman Sep 07, 2008
    I have a Trutech tv/dvd combo. The tv was turned off and once I unplugged it and plugged it back in and turned it on, the picture was shifted to the left and i cannot watch anything and my dvd will not open. what can i do.
TV TURNS ON BUT THEN SHUTS OFF SOMETIMES AFTER 5 MIN SOMES TIMES AN HOUR MOSTLY AFTER FEW MIN
Posted on Jul 02, 2008
The TV has tool designed for this problem and allow you to open the DVD. It came with mine when I boughtDVD will not open - 85e80e5.jpg it
Posted on Nov 17, 2007
The buttons on my DVD vcr don't respond
get a remote,it will be cheaper,I had the same vcr,it did the same thing,a circuit board burned up. Samsung 00008A DVD Remote Control for DVDV3650 DVDV3500 DVDV8080 Tested...
May 12, 2017 | Samsung Televison & Video
Tip
If disk door wont open - stays locked
I called Samsung who suggested pushinhg the play button on the panel and the power button on the remote together. "No disc" eventually showed on the screen and pushing the open/close door button worked.
However, my remote wouldn't work, even after changing batteries.
The machine did play. Unfortunately, later that night I tried another DVD and it locked up again. The next day I tried the above 2-step and it worked again, so maybe the other DVD caused trouble. But I cant get my remote to do anything except the 2-step listed above.
I don't use the player very often.
on Aug 02, 2010 | Samsung DVD-P241 DVD Player
Panasonic HT520 remote not responding
Hi.Im Dani from Spain.I have the same pb.To solve this problem-a new one remote.My remote its
a panasonic universal remote control dvd system eur7722x30(i dint find it but i find this:panasonic universal remote control dvd system eur7722x40;i need to see if its compatible(hope so)
This is the link http://cgi.ebay.com/Panasonic-Universal-Remote-Control-DVD-Syste-EUR7722XD0_W0QQitemZ130350261905QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1e597b2691
Good luck
Jan 24, 2010 | Panasonic SC-HT520 System
We had a power blink during the night and the next day our garage door wouldn't go down, with the remote or even the house button, unless we hold down the house button until the door is completely down. No...
sounds like a problem in, i want to say the motor, but it opens fine, check your spring assembly, check your chain, and lastly, replace your opener, BUT FIRST, check to see if your garage door opener has a lock feature. most of them do, it disables all wireless remotes. if its only responding to the push of a wired button, then it may be in lock mode, find your manual. the lock button may be on the opener unit or the wall unit
Jan 05, 2010 | liftmaster Chamberlain Garage Door Opener...
I have the Sony dvd changer that holds 400 dvd's and the remote was working fine one day then just stopped the next. I've changed the batteries and the light turns on but the player just doesn't respond
to test remote shine it into camera ( turn on camera ) press button you should see light flashing if not open remote and clean circuit board and battery contacts
Dec 04, 2009 | Sony Televison & Video
LE26R74BDX TV Not responding to Remote
there is a easier way to check your remote.
Open your radio on AM frequencies, you don't need to be tuned just noise is perfect, then bring your remote near the antenna and press some button. You will ear the frequency in your radio. If it works this way but not on the TV make sure to press the TV button before using it (if the remote is universal).
Jul 01, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Garage Master 1/3 HP 1997 Door Working, not responding to Remote
I have the exact same situation, except my model (139.53607) is older than yours and does not even have an LED. Remotes only works after after shop light goes off (5 minutes or so), but wall button works fine. Did call Sears Service and the tech told me the logic board is probably shot. Don't want to waste money on service call so I'll probably have to buy a completely new unit in the Spring and go through the winter without the use of a remote.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 21, 2008 | Samsung BN59-00599A Remote Control
Remote control "enter" will not respond in DVD mode
I had the same problem. Powering down and rebooting (unplugging) the recorder fixed the problem.
Mar 12, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Polaroid TTM-2003 Locked up.
The same thing happened to me. The manual on polaroid.com says to press and hold the F button (located at the top of the remote) and press the mute button at the same time. This will unlock as well as lock the TV. It's a child safety feature.
Jan 06, 2008 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
RCA D52W135D 52 in. TV/DVD Combo Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
