Question about Kodak EASYSHARE 5100 All-In-One Printer
My all in one center for my scanning will not open
I am not able to open my kodak aio home center softwear I receive a window saying KHC has encountered a problem and needs to close. I was able to use it in the beginning. I have upgraded, uninstalled and re installed\ downloaded drivers\ what else can I do. I cannot use the scanner if I don't have that working. the tech support told me there is something corrupt in my files, I cleaned all I could and have Mcaffee, I bought this piece of work in dec 07...........HELP
  • emdy Nov 26, 2008
    Kodak 5100 easy share all in one.
    Error message
    Could not find file 'c\program
    files\kodak\printer\center data er - us xml'
  • JDTec
    JDTec May 11, 2010
    Have you installed any new programs lately? There may be a conflict. Also, Un-plug everything from you USB ports.Restart the unit. Then re-plug the printer into a port.
    Let me know.
SOURCE: Kodak 5100 AIO Software Installation Problem
Fix a program that will work. We are not getting what we paid for. Same probleum Kodak whats is the probleum.
Posted on Apr 25, 2008
  • 2692 Answers
SOURCE: Kodak 5500 Printer
http://www.kodak.com/global/en/service/software/easyshare/en/dln_ekn026079.jhtml?pq-path=4509
Posted on Jan 16, 2009
  • 55 Answers
SOURCE: I try to open Kodak AiO Home Center from my desk
go to control panel add and remove programs and remove software then reinstall it
Posted on Mar 29, 2009
Mykel_N
  • 315 Answers
SOURCE: Kodak AiO software
Hiya,
Here is the link to the Kodak clear utility tool for removing their software:
http://wwwuk.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?pq-path=12361
Select what software you need to remove from the drop down list, click continue and follow the instructions from there.
I hope this helps.
Mike
Posted on Jun 17, 2009
  • 60 Answers
SOURCE: KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Posted on Jun 27, 2009
I have a Kodak esp 7250 printer that will only scan a picture from my laptop runing Windows 7 using older AIO Home center software (5.4.vs my desktop computer running Windows Vista that rescently had the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Will not scan kodak easyshare 5100
For WINDOWS VISTA/XP Operating Systems:
  1. Go to:
    • C:>Windows>twain_32>Kodak>Kds_aio5000
    • C:>Windows>twain_32>Kodak>Kds_aioesp
  2. Confirm the folders Kds_aio5000 and Kds_aioesp are available in C:>Windows/twain_32/Kodak.
    NOTE: If these folders are missing, the following error codes will be generated:
    • 1-2036 when scanning
    • 1-2037 when printing
If the error condition continues:
  1. Right-click the KODAK AiO Home Center icon.
  2. Click Properties, then select the Compatibility tab.
  3. Clear all checked boxes.
  4. Click Apply, then OK.
  5. Scan a document from the Home Center.
Jun 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Aio Home center will not open up to scan.
  1. Is your drivers properly installed?
  2. Use Paint in windows and try to aquire a imige from there,
  3. Else reload your driver
  4. Still not working reload your O/S windows
Dec 14, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Home Center will not open...Can't scan
On some vista setups the Kodak Software needs to be set to run as administrator
1. Right click the Kodak AiO Home Center icon and select 'Properties'
2. Select the 'Compatibility' tab
3. Make sure the 'Run as Administrator' box is checked
4. click apply and ok.
Hope this helps
Feb 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak EasyShare 5300
Sorry to hear about your trouble. Since I am not sure of the details, let me offer a long review and suggestion. It may work for you, especially if the AiO software is not installing correctly.
If the KODAK AiO Home Center software fails to start or an error message appears, there may be a problem with the Microsoft .Net Framework 2.0 installation. To resolve this condition:
1. Open the Control Panel.
2. Double-click Add / Remove Programs (for Windows XP) or Programs and Features (for Windows Vista).
3. Select Microsoft .NET Framework 2.0.
IMPORTANT: If other versions of Microsoft .NET Framework are listed, do not perform this operation on those other versions. Follow this procedure ONLY for Microsoft .NET Framework 2.0.
4. Click Change / Remove (for Windows XP) or Uninstall (for Windows Vista).
5. Select Repair, and click Next.
NOTE: A progress bar shows the repair progress.
6. After the repair is complete, make sure the Restart the computer check box is selected, and click Finish.
7. After the computer restarts, start the KODAK AiO Home Center software.
IMPORTANT: If the KODAK AiO Home Center software fails to start or continues to display an error message, completely uninstall Microsoft .NET Framework 2.0 and do a clean reinstall KODAK AiO Home Center software. The Microsoft .NET Framework 2.0 will also be reinstalled with the KODAK AiO Home Center software.
1. Follow steps 1 - 4 above.
2. Select Uninstall, and click Next.
IMPORTANT: Uninstall ONLY Microsoft .NET Framework 2.0. If other versions of Microsoft .NET Framework are listed, do not uninstall them.
3. Restart the computer.
4. Perform a clean re-installation of the KODAK AiO Home Center software:
a. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
NOTE: Do not disconnect your mouse or keyboard.
b. Uninstall the Kodak EasyShare 5000 series all-in-one software:
1. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
2. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
3. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
4. When the Install Wizard appears, click Next.
5. Depending on the issue(s) you are experiencing, do the following:
- If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
- If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
6 In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
vii. In the Ready to remove the program window, click Next.
viii. In the Uninstall Complete window, click Continue.
ix. Restart the computer.
c. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
i. Printer folder in C:\Program Files\Kodak
ii. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
iii. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
iv. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
ii. Eastman Kodak Company folder in C:\ProgramData
iii. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
d. Run Disk Cleanup.
i. Open My Computer.
ii. Right-click Local Disk (C:) and select Properties.
iii. Click the Disk Cleanup button.
iv. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
v. Click OK , then click Yes to delete all files and begin the Disk Cleanup.
vi. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
e. Shut down all background applications.
i. Select Start > Run.
ii. Type msconfig in the Open field, and click OK.
iii. Select the Startup tab.
IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
iv. Click Disable All , then click OK .
v. When prompted, restart the computer.
f. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
g. During the installation process, when prompted, select to search for an updated version of the software on the Kodak Web site and install the updated version.
h. Before restarting the computer again, turn on the background applications.
ii. Type msconfig in the Open field and click OK.
iv. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step e-iii.
- If all background items were originally selected, click Enable All, and click OK.
i. Restart the computer.
Jan 31, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
